4.0L consuming 3 qts of oil every 5,000 miles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FFWTacoma2013, Dec 29, 2014.
  1. Dec 30, 2014 at 1:13 PM
    #41
    PeterT
    PeterT Well-Known Member
    Peter
    Plymouth, NH
    15 TRD O/R Super White!
    AP APEX aluminum bumper, AP APEX Sliders w/fill plates, Full AP skids, OME 886/ Nitros dakar leaf pack, 33" BFG muds, Relentless 50" curved Light bar, PIAA fog lights, Fog lights anytime, tailgate lock, LEDs inside, tech deck, URD Spec U exhaust
    +1 Sumting Wong here
  2. Dec 30, 2014 at 1:14 PM
    #42
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    Sorry, It was posted "Tongue in cheek" in the past Fram filters have really taken a hit from the members, using a fram is generally considered a No-No & the root of all evil! (not I, I have used Fram with confidence for years)
    If you want to know what I really think of this problem, read my post from a little earlier. (post 32)
  3. Dec 30, 2014 at 1:14 PM
    #43
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
  4. Dec 30, 2014 at 1:16 PM
    #44
    PeterT
    Peter
    Plymouth, NH
    I stopped using Fram filters years ago, although I thought I heard they were better now. I cut one open once and 1/8th of the filter part was missing, you could see the metal core that it should have been covering. so the filter was not even filtering. and they used to use cardboard check valves.
  5. Dec 30, 2014 at 1:17 PM
    #45
    FFWTacoma2013
    FFWTacoma2013 [OP] Member
    Brad
    Texas
    13 doublecab/trd pkg/4x4/spruce mica
    Trd bronze wheels, Trd short shift w/trd nob, trd exhaust
    well thats what it looked like on the stick, thats how much I drained and that is how much wasn't there. me being a mechanic really has nothing to do with any of this.
  6. Dec 30, 2014 at 1:25 PM
    #46
    FFWTacoma2013
    Brad
    Texas
    thanks man I like that link and considering I've only drove 40 miles with this filter I'll stop by toyota and throw their filter on it.
  7. Dec 30, 2014 at 1:29 PM
    #47
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I don't see the correlation between the filter and oil use. Care to explain how that works.
  8. Dec 30, 2014 at 1:35 PM
    #48
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Post #32 is a complete failure in regard to identifying what happens to the oil.
  9. Dec 30, 2014 at 1:42 PM
    #49
    DocD
    Mn./SoCal
    09 access cab
    THE FILTER WAS A JOKE,,, post #32 is what I think of this, a mechanic loosing 3 qts of oil, 5,000 miles!! Twice!!!! a 2013 Toyota & doesn't contact the dealer?????? come on people!!!!!!!
  10. Dec 30, 2014 at 1:43 PM
    #50
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
  11. Dec 30, 2014 at 1:47 PM
    #51
    File IFR
    Central MA
    ... said the 5 year member with one green rep block. Now I understand. ;)
  12. Dec 30, 2014 at 1:49 PM
    #52
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  13. Dec 30, 2014 at 1:52 PM
    #53
    GoldyLocks
    GoldyLocks Well-Known Member
    Mesa az
    97 caged 4x4 tacoma, SR1 Rhino
    LOL
    say what?
    rep really means nothing. also look at how much he has posted. not much.
  14. Dec 30, 2014 at 1:55 PM
    #54
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    Exactly my thoughts. Although, where in the Toyota manual did you find the warning against synthetic oil?
    OP: Did you allow a break-in period before switching out the dinosaur oil to synthetic? (And get rid of the FRAM!)
  15. Dec 30, 2014 at 2:46 PM
    #55
    DocD
    Mn./SoCal
    09 access cab
    03f5sp likes this.
  16. Dec 30, 2014 at 5:24 PM
    #56
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    I had 175,000 on my '06 V6 and it didn't use a drop but I did have that problem with my '07 Camry I4. The oil return holes clogged in the Pistons and it pushed the oil out with no noticible smoke. My engine had to be rebuilt by Toyota.
  17. Dec 31, 2014 at 7:37 AM
    #57
    Jimmyh
    SC
    2012 Prerunner SR5
    The pistons do not have oil return holes.
    The oil return "holes" are in the engine block and heads. You must have had the oil gelling problem...
  18. Dec 31, 2014 at 8:46 AM
    #58
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    +1
  19. Dec 31, 2014 at 9:49 AM
    #59
    bubba353z
    bubba353z Titles? We don't need no stinkin' titles.
    Columbus, Oh
    Former owner of a 12 TRD Sport AC 4x4
    The filter has nothing to do with it.
    The bypass does just that - bypasses the filter media if it's clogged / too high a pressure. It just sends the unfiltered oil back into the block
  20. Jan 1, 2015 at 8:25 AM
    #60
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    I reco this.
    1)Pull your fram filter & replace with factory. I do not believe this is your issue esp. Because it is more than one filter.
    2)top off oil level.
    3)return to dealer & tell them of your issue.
    4)if they balk,have them perform oil/filter change & notate mileage.
    5)return after 2-3K miles & leave the truck until they find & fix the issue.
    Good luck & keep us informed.
