4.0L consuming 3 qts of oil every 5,000 miles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FFWTacoma2013, Dec 29, 2014.
  1. Jan 5, 2015 at 7:30 AM
    #81
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    i think the word backyard was misplaced in his first statement. it should have read as "I am a backyard mechanic."
    bluezzy likes this.
  2. Jan 5, 2015 at 8:25 AM
    #82
    SprtBkr
    SprtBkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 5.7L Double Cab 4x4 Inferno
    I almost said that, but didn't want to add more insult to injury. :eek:
  3. Jan 25, 2015 at 5:48 PM
    #83
    06 Tacoma 4 cyl
    06 Tacoma 4 cyl New Member
    06 4 cyl
    Bed covver nav sys
    Just got this used of course, had it for 3 months, i drive it 3,000 miles per month.
    Looks like its burning somehow, 1-2 quarts of mobile 1 per month / 3,000 miles
  4. Jan 25, 2015 at 6:42 PM
    #84
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Or maybe "backward" mechanic.
  5. Jan 26, 2015 at 2:41 AM
    #85
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    With that many miles on it, I would start looking for why, and that much oil will kill your cat converter...
    Howard
  6. Jan 26, 2015 at 4:15 AM
    #86
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    You would think a mechanic would be smart enough not to let his truck get 3 quarts low?
  7. Jan 26, 2015 at 4:39 AM
    #87
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    :stayontopic:
    You guys are getting too focused on bashing the guy for making a statement. Who cares if he is a mechanic. You're filling this thread with chatter that makes it difficult for someone with a similar issue to find answers.
    We get it, but regardless, someone posted an issue with oil loss and at least one other person has come in stating they have the same problem.
    Now, to keep my post someone on topic as well, I think I might have some minor oil loss, but I rarely get to put the oil into an empty container to check the actual amount that comes out. On top of that, I'm not sure I could ever really empty out the container. I think some residual oil is always left in there, so I'm not sure that is an accurate way of measuring. However, after reading this thread, I'm going to keep a closer eye on the dipstick.
  8. Jan 26, 2015 at 6:45 AM
    #88
    SprtBkr
    Scott
    Denver, CO
    At 230,000 miles I'd do a compression test. You're most likely losing oil through rings and valves (burning it) if you're not leaking it. You might also consider switching to a high mileage oil.
  9. Apr 24, 2015 at 4:44 PM
    #89
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    Anybody have more info on this^^^?
    I changed my 50k oil today and was a qt low. I bought the truck new in 12, let them do Toyota Care up to 30k(I think it was). Then switched to Mobil 1 with Toyota filters every 5k since. Am going to wait until next oil change to see if it's low again then approach Toyota if so. I've never looked forward to an oil change but right now it can't come fast enough. I can't even fathom having to pay for a fix to this. This truck is driven but well maintained. Makes my blood boil just to think about this. Hopefully its just a fluke.
  10. Apr 24, 2015 at 5:03 PM
    #90
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Same here 2009, 55000 miles with no oil missing.
  11. Apr 24, 2015 at 5:26 PM
    #91
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    quart / 600 miles per manual
  12. Apr 24, 2015 at 8:41 PM
    #92
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    As per "Most/All" vehicle manufacturers specifications this would be considered normal oil use. Regardless of what any of us think is right. If it continues I would go back to dino oil and see if it improves. Chances are that it will.
  13. Apr 27, 2015 at 2:07 PM
    #93
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    That is not normal!
  14. Apr 27, 2015 at 2:15 PM
    #94
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    My 2008 with 116,000 consumes *0* quarts per change. Even my first vehicle, the '77 in my sig pic, leaked more out of the seals than it actually burned. My '87 MR2 didn't leak a drop or consume a drop and it had 212,000. I know what Toyota considers "normal", but that much consumption is a problem.
  15. Jan 30, 2017 at 1:51 PM
    #95
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    An update on my situation, when I changed my oil at 32,000 miles several months back it was still burning a little but not as bad as it had been (down a quart or so but not 2 - 2.5 quarts like previously). Yesterday at 37,000 I changed it again and it's virtually not happening - I was down maybe a half quart. Someone suggested that as these 4.0L get closer to 30K miles they taper burning oil if you experienced that so maybe there's some merit to that. I dunno. The only other change is the addition of the SC but I don't see how that would make a difference.
  16. Jan 30, 2017 at 7:14 PM
    #96
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    FWIW: Per the OM from the lower to upper dots on the dipstick is 1.4 qts for the 2.7, 1.6 qts for the 4.0 (see below).
    If the 4.0 dip stick drawing is to scale (may not be I have not verified it) then the very end of the stick would be by my guesstimate approximately 2.7 qts "low".
    Also the OM states that 1 qt/600 miles is the upper limit of acceptable oil consumption--maybe for them, not me!
    This is about as far as I get into engine oil discussions, however 'twas I the OP I'd load that suck'a up with 10W-30 or 10W-40 and see what happens. I am not a big fan of 5W- or 0W- (anything). They help manufacturers better meet CAFE requirements, but do so at the expense of ultimate engine life...
  17. Jan 30, 2017 at 8:33 PM
    #97
    Shark18
    Shark18 Well-Known Member
    Daniel
    2007 White dbl cab Tacoma 4x4 TRD
    I use about 1/2 quart 6-7 k miles Mobil 1 5-30 synthetic with 250k miles.
    R0dzilla75 likes this.
  18. Jan 30, 2017 at 9:10 PM
    #98
    cliffyk
    Cliff
    Saint Augustine, FL
    My new-to-me '09 with 137.5k miles has not used a drop in the 2500 miles I've owned it. The dealer changed the fluids before I bought it so I assume the engine is loaded with Toyota's 5W-30. I plan on replacing it with 10W-30 synthetic in another 1500/2000 miles...
  19. Jan 31, 2017 at 3:30 AM
    #99
    stump jumper
    Bill
    Texas
    I would stick with specified 5w-30 in syn
    Sugar Silva likes this.
  20. Jan 31, 2017 at 7:20 AM
    #100
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    "Also the OM states that 1 qt/600 miles is the upper limit of acceptable oil consumption--maybe for them, not me!"
    Most OEM's do that, I went through that in the late 90's with Saturn, for them, 1 quart per 1000 miles was acceptable, if you didn't exceed that, they did nothing...I put 300,000 plus on that car, was adding 4 quarts between changes...Saturn knew for years the piston skirt design was poor and contributed to the bottom oil ring getting miserably clogged with carbon build up to the point where is could not keep the oil from bypassing to combustion...
    As far as mine goes, never used oil up until just recently, but the oil is a leak from upper rear intake manifold, not combustion....completely happy with Toyota..
