4.0L fuel pump fuel pressure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bobsnotnose300, Apr 18, 2025.
  1. Apr 18, 2025 at 3:12 PM
    bobsnotnose300
    bobsnotnose300 [OP] New Member
    Hi all,
    My 4.0L engine is running lean in both banks. I did a fuel pressure test and it seemed to be around the ~41 psi mark, but it would rapidly fluctuate. I can’t tell if it’s because the gauge is low quality or because the fuel pump needs replacement. For reference the tank did have 1 yr old fuel in it, some of that fuel was run through the car but it has been about 500-1000 miles since and I’ve been running premium with some cleaner as well. Car seems a little weaker but not very noticeable to be honest. Any help would be greatly appreciated
    https://drive.google.com/file/d/185eC4XF9gwJuGlCDLX3nOOV57QXFqmIg/view?usp=drivesdk
  2. Apr 18, 2025 at 3:59 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    From Alldata..
    pressure w/ engine idling - 41 psi
    After the engine shuts off, wait for 5 minutes and it shouldn't be lower than 21 psi
  3. Apr 18, 2025 at 4:07 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    From Toy service data
    Key on Engine off with service diag computer(but I don't think you really need that, look up jumping fuel pump relay)
    • Measure the fuel pressure [with the pump running]. Standard: 281 to 287 kPa (2.87 to 2.93 kgf/cm2, 40.8 to 41.7 psi)
    • Check that the fuel pressure does not change for 5 minutes [after the pump is turned off]. Standard: 147 kPa (1.5 kgf/cm2, 21 psi)
  4. Apr 18, 2025 at 8:44 PM
    bobsnotnose300
    Yup, if you look at the video it’s kinda there? I just don’t know how perfectly stable it’s supposed to be. The leak down test showed that the pressure held well after 5 minutes above 21 psi.
  5. Apr 18, 2025 at 8:51 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Running lean as you're getting lean codes?
    The fuel pump has a filter sock in the tank that is known to get dirty/clog.
  6. Apr 19, 2025 at 8:17 AM
    bobsnotnose300
    I checked for vacuum leaks and I don’t hear or see any thing. Poked around the entire vacuum system too with propane to see if rpms go up and nothing. I’m fairly confident it’s a fuel issue. Think I should replace the fuel pump?
  7. Apr 19, 2025 at 8:20 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You need to drive it with the fuel pressure gauge on it and see if it maintains fuel pressure under load, if it does then your fuel pump is fine. If it doesn't then the fuel pump is suspect.
