4.0L Headers?!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ravistae, Dec 27, 2015.
  1. Mar 6, 2018 at 12:40 AM
    #101
    Blandino
    Blandino Well-Known Member
    Damien
    2011 Double Cab Tacoma
    Whistle Tip Exhaust
    I have the URD long tubes with the full URD Mk3 exhaust with no cats. Between 2.5-3.5k RPM's it gets pretty raspy. It needs modified for the rear cage & links, so will probably start tinkering with it after that is done until it sounds better. At idle/low RPM's it sounds really good in my opinion. A few folks have asked if I did an engine swap.
  2. Mar 6, 2018 at 3:56 AM
    #102
    eppy
    eppy Well-Known Member
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Homer M3 thin lip Satoshi, BAMF Light Bar, BAMF Batwing Tie Downs, Coupe Custom Battery Hold Down, Mattgecko Bed light kit, nj636 hub/wheel bearing set-up,Shorty Antenna, JL Audio & Boston set-up, 4x4 switch light MOD, Icon 2.5 coil overs and rear shocks, All Pro flip kit, Wheelers AAL, OcTaco SS brake lines, Light Racing UCA's and custom 6 speed Ellis Precision Shift knob. Coupe modified short shifter, AISN clutch pack, URD TOB kit, and Sachs flywheel. Mobtown's rocking tailgate skin!
    Yeah, I already installed Gibson's stainless set-up and the muffler has a subdued rumble to it that is really nice. Its Quite at idle, but noticeable when you get on it. So I don't want to mess with to many mods when it comes to eliminating the Cats completely. Just want to find out if the Magnaflow cats are the better route to go and if they are a little more free flowing. If so, that's how I'm leaning to avoid any headaches. Going to call Magnaflow today and get the lowdown and will let ya know what I find out after I get the results from Toyota's scan check back. Hoping its a bad sensor because she just hit 148,000, but we'll see and hell I've basically replaced everything else.
    :spending:
    mach1man001 likes this.
  3. Mar 6, 2018 at 4:33 AM
    #103
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    :popcorn:
