4.0L RMP vs MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toy 2, Dec 27, 2014.
  1. Dec 27, 2014 at 8:44 AM
    toy 2
    toy 2 [OP] Well-Known Member
    Dave
    Reno, NV
    Ok I have read a lot on this and everyone tells you speed and MPG but tire sized and transmission choice have a lot to do with mileage. I recently bought a 06 DCSB with 4.0L V6 and a 6 speed manual transmission. I'm only getting about 16MPG. I live in an area that freeway speeds are 75 to 80 MPH and mostly flat. With the manual tranny and stock tires my RPM is about 2700 to 2800 when driving 78 MPH. My question is what is the ideal RPM for good gas mileage from this 4.0L???
  2. Dec 27, 2014 at 8:50 AM
    toy 2
    Dave
    Reno, NV
    I have read that already and 55 MPH around here will get you ran over. Reason I ask this question is the only reason the manual gets worse mileage is due to the short 6th gear meaning the RMP is higher. I plan on adding taller tires and would like to have a good idea of what RPM is best for this tranny/engine combo??? Speed means nothing when you look at the many differences of trucks.
  3. Dec 27, 2014 at 8:58 AM
    toy 2
    Dave
    Reno, NV
    Thats not true. lugging the engine will not get you very good gas mileage and is not good for the engine.
  4. Dec 27, 2014 at 9:35 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Anything after 65 mph, will give you shit for gas milage. Just because it says 75 mph speed limit. Doesn't mean you have to run 75.
  5. Dec 27, 2014 at 9:40 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Anything below 2000 rpm is where mileage rests. My 04 automatic double cab is at around 2300 at those speeds, those 6 speeds are geared way too high.
  6. Dec 27, 2014 at 9:41 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    I'm a bit confused on what you are asking about.
    Are you asking what size tire to go with to increase efficiency by dropping the RPMs?
    or what to regear the diffs to?
  7. Dec 27, 2014 at 9:48 AM
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    1500 - 2000 RPMs seems to be the sweet spot for efficient cruising. Even though you get taller effective gearing, in my experience, bigger tires equal worse mileage in all situations.
  8. Dec 27, 2014 at 11:24 AM
    toy 2
    Dave
    Reno, NV
    say tire size. All Im asking is where is the sweet spot(RPM wise) for these 4L engines. I plan on lifting it some and going bigger tires. So im thinking maybe a 33" tire would put me in the 2200 RPM range at 75???... Just guessing with the lift and weight of bigger tires my mileage MIGHT not change and MAYBE even get better due to the RMP I will be turning at 75 mph.
    One day if I decide to go 35" tire I will more then likely regear as well but for now let just say I want to know what tire size will net me 2100 to 2200 rpm at 75 mph?
  9. Dec 27, 2014 at 11:32 AM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    Increasing unsprung weight will ruin your gas mileage. Decreasing unsprung weight will help it.
    Bigger tires means heavier tires/rims = added unsprung weight = shit for gas mileage.
  10. Dec 27, 2014 at 11:44 AM
    xtyfighterx
    xtyfighterx Master Shredder
    Ty
    CDA Idaho/ Deadhorse Ak
    09 DC SW TRD OR/ 2015 tundra CM off road sr5
    3in lift, 5100s front and rear, OME 887 springs 2in aal, 285 75 16 Duratracs, mb 352 black wheels, white sport grill, derp'd lower valance, derp'd front toyota emblem white, tinted windows, tinted tail lights, trd shorty antenna, trd hitch cover, trd valve stem caps, trd neoprene covers, trd all weather floor mats, kenwood double din, stampede window visors, flyzeye interior leds, anytime fog light mod, flashlight mod, kool vue intake, LED dome light, Lund bug shield, TRD shift knob,front mud flaps removed, Debadged, truxedo roll up bed cover, led fog light bulbs, led parking light bulbs, led dtrls bulbs, led headlight bulbs, led back up light bulbs, led license plate bulbs, tinted license plate covers, 18" magnaflow muffler, 32in ebay, light bar, coverking neoprene resr seat cover, oem trd skid plate, trd decal on center caps, oem trd exhaust tip, blacked out pinch welds, color matched mirror covers.
    If you wanted good mileage you should of got a prius. The tacoma sucks on gas mileage no matter what you do.
  11. Dec 27, 2014 at 11:47 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    The MT gets worse mileage than the AT due to a number of reasons, one being the OD in the AT keeps the RPMs low at freeway speeds.
    I get 19-21 regularly, my RPM at 65 is around 2k. I find anything less than 65 to be good for MPG, the moment I get above 65 it starts droppping, rapidly after 70.
  12. Dec 27, 2014 at 11:58 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Like some had said already. If you want to get good mileage.... slow down. Just because other drivers are going 75-80 mph doesn't mean you should. Consider how high the MT is already geared, it is best to keep speeds at 65-70 mph for highway speed.
  13. Dec 27, 2014 at 11:59 AM
    Fightnfire
    Marysville, WA
    There's nothing wrong with someone trying to improve their MPG in any vehicle they drive.
    Plus, if you want to shit on someones thread at least put an ounce into the creativity and come up with something more original and less cliche.
  14. Dec 27, 2014 at 12:06 PM
    xtyfighterx
    Ty
    Just stating the obvious.
  15. Dec 27, 2014 at 12:08 PM
    Fightnfire
    Marysville, WA
    Sorry, I just realized you're 23 and still think everyone deserves to hear and read your words.
    You should try being helpful, or not posting.
  16. Dec 27, 2014 at 12:14 PM
    tomtom
    The Desert SW
    2012 FJ
    You're going to be constrained by what you can fit on the vehicle. I've seen guys fit 33" with some minor body work and a lift. 35s will take a bit more. They may not get you what you want either as the added weight will take more work to move. Also, as you eluded to, the lift will decrease efficiency as well.
    If you go 33"s, you'll want skinnies (255/85R16 or similar). They'll save you on weight and rolling resistance over a 285/75r16.
  17. Dec 27, 2014 at 12:15 PM
    xtyfighterx
    Ty
    My post was helpful. Tacomas don't get good mileage. Nothing to help that. Except trading it in for a prius.
  18. Dec 27, 2014 at 12:16 PM
    toy 2
    Dave
    Reno, NV
    Im just trying to gain info about the 4L tacoma engine. IF I was worried about gas mileage I would have KEPT my TDI jetta!!!
  19. Dec 27, 2014 at 12:17 PM
    xtyfighterx
    Ty
    I understand didn't mine to sound like a a**hole. I've tried many things and can't really get over 16mpg. That's with stock tires 31s and 33s.
  20. Dec 27, 2014 at 12:28 PM
    toy 2
    Dave
    Reno, NV
    Out of all this I have gathered that keeping the RPM close or under 2000 RPM will net me the best MPG. I think after driving this truck for a week that anything under 2000 RPM there is no power at all. Now I just have to do the math to figure out what size tire to run to gain that kind of RPM. Reguardless of MPG the engine will be better off not running at 2800 RPM for hours on end. And for you guys that say slow down to gain better mileage. not going to happen here:p... I have had this truck for a week now and have over 1100 miles clocked on it:eek:... speed limit says 75mph I will be doing 80mph:p:p..... but I would rather my engine spin at 2100 rpm rather than 2800 rpm. Thanks for all the helpful information guys..
