4.0l Serpentine Belt
Discussion in 'Technical Chat' started by mjp2, Sep 5, 2008.
  1. Sep 5, 2008 at 7:40 AM
    mjp2
    mjp2 [OP] Living vicariously through myself Moderator
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Changed mine last night. Typical design with the tensioner pulley, but the belt routing is a pain.
    The attached pdf file shows the proper routing and will hopefully help someone in the future.
  2. Sep 5, 2008 at 7:50 AM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    That doesn't look too bad. On my '96 Bonneville the serpentine belt actually runs through an engine mount. You have to jack up the engine a little and take the mount apart to get the belt through it. To do that you have to remove a tire & part of the inner fender & sit under the wheel well. The Taco looks pretty simple by comparison.
  3. Sep 5, 2008 at 8:04 AM
    mjp2
    NJ
    Through an engine mount? :eek:
    I won't complain about this again. ;)
  4. Sep 5, 2008 at 8:15 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I think you meant to say "I payed a mechanic to change mine last night"
  5. Sep 5, 2008 at 8:35 AM
    mjp2
    NJ
    I pay fabricators. Mechanic stuff is easy. :p
  6. Mar 13, 2013 at 12:04 PM
    merldoug
    merldoug New Member
    illinois
    07 taco
    Great to see the diagram on here. Do not know why they don't just put in where everyone else does. Thanks
  7. Mar 13, 2013 at 3:41 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Yeah, maybe I missed it but I couldn't find a diagram under the hood or in the manual so I printed out a big copy, laminated it and placed it in my manual.
  8. Mar 14, 2013 at 6:01 AM
    BamaToy1997
    Bill
    Navarre, FL
    Yeah, pretty much all of the late 90s GM cars with the 3800 engine had that problem. And even after customers knew what needed to be done, they still complained about the labor charges to replace the belt for them. So many time you just want to walk up and slap the piss out of a customer. lmao.
  9. Apr 17, 2013 at 1:13 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Subbed
  10. Apr 17, 2013 at 1:16 PM
    mjp2
    NJ
    me too.
  11. Apr 17, 2013 at 1:22 PM
    JLink
    Josh
    Ocean, NJ
    Wow quick response.. Haven't seen you in a while. I'm getting ready to place an order for some spare parts for the trip to Moab.
    I've been meaning to ask you about tie rods.. Ill pm you.
  12. Apr 23, 2013 at 6:23 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Does anyone know if just the pulley on the tensioner can be changed or am I forced into buying the whole tensioner assembly? Replacing the whole tensioner just seems like an unneccessarily difficult process that I'd like to avoid if possible.
  13. Apr 23, 2013 at 6:27 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Typically they come as an assembly. You will get the bolt flange to mount it and the spring loaded pulley
  14. Apr 23, 2013 at 6:56 AM
    Pugga
    Massachusetts
    Are you following me? :D
    Thanks for the help, might not mess with that one for the time being... :eek:
  15. Apr 23, 2013 at 6:58 AM
    BostonBilly
    Easton
    Just trying to help and work is slow so bouncing around TW
  16. Apr 23, 2013 at 7:02 AM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    Hopefully I can remember this when it comes time to change mine..
  17. Apr 23, 2013 at 7:12 AM
    Pugga
    Massachusetts
    beriman10 likes this.
  18. Sep 3, 2013 at 4:47 AM
    SamSin
    SamSin I can resist everything except temptation
    Jersey Sam
    NJ
    Longbed 4x4 SR5
    Oil Free AFE Pro Dry S Air Filter, Nitrogen filled tires, Tonno Pro Tri-Fold Hard Tonneau Cover BLU Logic Handsfree
    Great idea with the lamination Maxamillion. I folded my copy in half and trimmed it before laminating, now it fits very nicely in the manual. Great reference, thanks for the posts and links.
    I understand it is very hard to tell with the newer belts if they need replacement they don't necessarily have to show cracks to be wearing, and they appear to be good visually. But at around 80,000 I will probably change mine.
