4.0L SuperCharger
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TimmyHunter003, Mar 19, 2018.
  1. Sep 25, 2018 at 10:09 AM
    #61
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    :rolleyes:
    12TRDTacoma likes this.
  2. Sep 25, 2018 at 10:10 AM
    #62
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    If you want more Horsepower and Torque buy a Full size truck.
  3. Sep 25, 2018 at 10:17 AM
    #63
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    What fun is that?? Why not have a Tacoma with more HP and TQ than a full size truck? :burnrubber:
  4. Sep 25, 2018 at 10:22 AM
    #64
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Not if you tow it ain't.
  5. Sep 25, 2018 at 10:26 AM
    #65
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I think it's worth it. Have the power and torque of a full size in a truck that weighs 1500lbs less. Makes for a fun daily driver
  6. Sep 25, 2018 at 2:41 PM
    #66
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Only person that told me my supercharged truck was a waste of money drove a prius.
  7. Sep 25, 2018 at 3:22 PM
    #67
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Then start over and do the same? It is always relative to the platform you are in. Otherwise we would all be blissfully ignorant with the same vehicle. Like a Lada.
    But then again, you have a 3rd Gen, and are probably suffering from your insufficient power problems.....
    oni06, JacksonTacoma, RyanL and 5 others like this.
  8. Sep 25, 2018 at 3:56 PM
    #68
    daS
    daS Well-Known Member
    People with no supercharger will say they want one.
    People with a supercharger will never say they don't want one.
  9. Sep 25, 2018 at 4:14 PM
    #69
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This thing has the power of a full size without the extra 1500lbs of a full size and the additional real estate space a full size requires. If you ask me, that is a huge win on all fronts.
    RyanL, rmepilot, tinker_troy and 3 others like this.
  10. Sep 25, 2018 at 4:16 PM
    #70
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Clearly they spanked you a little too hard with the belt when you were a kid. :boink:
    rmepilot, Torspd, tinker_troy and 2 others like this.
  11. Sep 25, 2018 at 4:22 PM
    #71
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    I questioned the value of one before finally getting mine.
    The fact is the supercharger is only half the cost. Once you get engine management, intake, exhaust, pulley, fuel pump...it really gets up there.
    After a couple years of boosting I can say that yes, it is 100% worth it. It's on my daily driver so I get to enjoy it every day.
  12. Sep 25, 2018 at 4:24 PM
    #72
    BassAckwards
    Did you upgrade your clutch since you have a 6spd? Or how long has your stock one held up?
  13. Sep 25, 2018 at 4:33 PM
    #73
    findingthingsout
    midwest
    Long story short; I added the URD stage 2 along with the throw out bearing sleeve kit.
    After ~1000mi the clutch failed. Unfortunately it was on the lift at the dealership and I had to get it back together. So now I still have a squealing T.O.B. and a factory clutch.
    Stock power for ~20k mi. and the same with boost. 2.825 pulley... 7-8 lbs.
    It'll burn if I dump it but has held surprisingly well so far.
  14. Sep 25, 2018 at 4:45 PM
    #74
    BassAckwards
    Damn thats surprising. Ive found it to be hit and miss as far as how long the clutch lasts. Ive got a 2.8 pulley on mine, headers, ypipe, full exhaust and about 5k miles on my stock clutch. No problems yet, but i dont dump it ever.. i typically always let the clutch be fully released before i hit the gas. I wanna try to make it last as long as possible before i need to replace it. I do have a stage 3 and lightweight flywheel waiting whenever it starts to go out though
  15. Sep 25, 2018 at 7:59 PM
    #75
    CoyoteRuns
    CoyoteRuns Well-Known Member
    Ben
    2012 TRD Sport Supercharged 4x4 Access Cab
    I'm so happy I bought a Taco with the SC already installed. I only get 13.5 mpg, but I figure that's the price to pay for the extra fun.
  16. Sep 25, 2018 at 9:09 PM
    #76
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    Smiles per gallon = most important
  17. Sep 26, 2018 at 7:31 AM
    #77
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Funny how I enjoy it now as an adult, too.
  18. Sep 26, 2018 at 7:41 AM
    #78
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Familiarity.:bananadance: :rofl:
