4.0L towing 22' boat question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dustinclm, Aug 29, 2011.
  1. Aug 29, 2011 at 3:17 PM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    hey guys, im strongly considering getting a second gen tacoma in the next year, either the V6 4x4 or the V6 2WD TRD off road. My only question is how easily would be able to tow a 22' boat (total weight would range around 1600-2000lbs)? I currently tow my 18' boat with my 1st gen 4cyl but i am looking to upgrade both rigs and dont want to be under powered. I think the standard towing capacity for the 4.0L is 3500lbs but can anyone give me an idea how the truck handles this weight when towing it?
    Thanks
  2. Aug 29, 2011 at 3:18 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    you will be fine.... i tow more than that with my 2.7l.
    and the tow rating is 6500lbs IIRC
  3. Aug 29, 2011 at 3:26 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    Theres a post on here about what people tow with there trucks, and get one guy who tows bobcats and tractors, so your pretty safe!
  4. Aug 29, 2011 at 3:27 PM
    dustinclm
    Thibodaux, La
    i figured it would be fine but since ill be getting the truck before the boat i didnt want to end up under powered and struggling to get up to speed.
    thanks
  5. Aug 29, 2011 at 3:32 PM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    What 22' boat do you tow that only weighs 2000 pounds?
  6. Aug 29, 2011 at 3:36 PM
    97yota4wd
    Eric
    Mesa, AZ
    and this also..^^^
    my 18 foot all aluminum pontoon boat is like 2000lbs.
    but it may be a aluminum V hull boat
  7. Aug 29, 2011 at 3:43 PM
    Titleist07
    Titleist07 Member
    Satellite Beach, FL
    2016 TRD OR DCSB 4x4
    It will tow it no problem. I tow a 23' boat that is approximately 5000 lbs. and the Tacoma does great.
  8. Aug 29, 2011 at 3:45 PM
    dustinclm
    Thibodaux, La
    22' xpress bay boat aluminum hull. that's the range the website gave me and the 2000lbs was for boat/motor/gear/persons.
  9. Aug 29, 2011 at 3:57 PM
    fishntaco
    Josh
    Mobile Al
    The boat will weigh closer to 4000 pounds ready to fish. The 2000 pounds is for boat, motor, and gear in addition to the dry weight of the boat. Either way it should tow fine.
  10. Aug 29, 2011 at 4:21 PM
    deerslayer75
    deerslayer75 Well-Known Member
    Tim
    jersey shore
    11 TRD sport Dblcab Lngbed
    pop-n-lock, mcgard tailgate lock, chrome tube steps, bed extender, chrome brush guard, Fold a cover (G-4) tonneau, weather tech floor mats and rain gaurds, sock monkey: TRD 3rd brake light and whitetail decals, LED bed lights, blue map & dome, 3rd brake light and license plate LED mod, illuminated 4x4 switch, fishing rod holder mod, scangauge II, Remote start & alarm, TW sticker, Flyzeye cupholder light mod
    I would say get the towing pkg and the 4x4 you don't want to start to slip when on a wet ramp.
  11. Aug 29, 2011 at 4:27 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The other option is to get a front hitch, so your rear wheels are not submerged in the water. It has the added advantage of keeping the boat in full view when lowering the trailer down the ramp.
  12. Aug 29, 2011 at 6:37 PM
    dustinclm
    Thibodaux, La
    thanks for the imput. figured it would be fine. just wanted to make sure before I started seriously looking into getting this set up
  13. Aug 29, 2011 at 6:52 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    You'll be fine, I tow my 21ft Four Winns Cuddy, approx weight 6k loaded and it does fine. You will most likely need to replace the rear leafs with something a little stronger or do some air bags. but make sure you get a sec. gen w/ the tow package.
  14. Aug 29, 2011 at 6:53 PM
    MattS67
    MattS67 Well-Known Member
    I tow a 20' Bay Scout and I honestly can't even tell it's there aside from when I'm braking.
  15. Aug 29, 2011 at 6:56 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    i pull a 21 foot checkmate loaded and the taco does fine, even up a 9% grade.
  16. Aug 29, 2011 at 7:05 PM
    kcrob1
    kcrob1 Choot It!
    Casey
    Montgomery, TX
    TRD SPORT CC/LB
    Adjustable Billies, Debadged, Painted emblem on grille Kenwood Double din, polk components, co-ax, polk 8" sub & polk amp, TSB springs, 6000K hids, FJ Wheels
    I pull all kinds of boats with mine and my gas mileage SUCKSSS as soon as I hook one up. It takes a little bit to get up to speed but it does the job better than most. You should definately look into stiffer springs if it doesnt have them already. I hauled an empty pontoon trailer with about 70 lbs of tongue weight and the truck squatted 1 1/4". Getting my new springs next week... I build custom aluminum boat trailers and we deliver them to Corpus Christi all the time (5hr drive) and we tandem 2 trailers down there and last time I got 12mpg :eek: Aluminum is light too.
  17. Aug 29, 2011 at 7:11 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    I tow a 22' Boston Whaler and a 22' Catalina Sailboat and have no issues. Obviously it is going to be a bit slower from a stop, but after that I don't notice they are there.
  18. Aug 29, 2011 at 10:48 PM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    wow thats pretty bad, my 70 year old mom could fairly easily wire up trailer lights. it is a simple process especially if your not wiring for electronic trailer brakes.
  19. Aug 29, 2011 at 11:15 PM
    Tigahshark
    Isaac
    True but terrible at pulling with the rear wheels facing that way, thats like pulling a boat with a front wheel drive car
  20. Aug 30, 2011 at 3:49 AM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    That's pretty big boat for a single axle trailer! In SC anything that heavy would be on a tandum.
