4.0L Valve Cover gaskets
Discussion in '2nd Gen. Tacomas (2005-2015)' started by glk21c, Apr 14, 2020.
  1. Apr 14, 2020 at 6:02 AM
    glk21c
    glk21c [OP] Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    I didn't find this specific answer.
    For those that have replaced the valve cover gaskets on the 4.0L, is it necessary to remove the intake manifold when replacing the PASSENGER side valve cover gasket? It does not appear so but I wanted to ask.
    The drivers side valve cover gasket replacement is pretty obvious that the intake manifold needs to come off.
    Thanks in advance.
  2. Apr 14, 2020 at 6:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Not necessary.
