4.0's inaccurate dipstick
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Idlewild294, Nov 3, 2014.
  1. Nov 3, 2014 at 8:04 AM
    Idlewild294
    Idlewild294 [OP] Well-Known Member
    Texas
    2009 Tacoma TRD Off-Road SR5 4x4
    I recently changed my own oil for the first time and I added exactly 5.5 quarts and I even let the old oil drain out for 3 hours. After sitting overnight, the oil level on my dipstick shows about 1/4" (or less) above the full dot. I've read how these dipsticks are inaccurate so what does everyone here do? Do you put in the recommended amount of oil and call the dipstick a rough measuring tool? Does going over the full dot freak anyone out? I know I have 5.5 quarts in my truck so I'm comfortable, but it does bother an OCD person like me.
  2. Nov 3, 2014 at 8:05 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    did you change your filter too?
  3. Nov 3, 2014 at 8:09 AM
    Idlewild294
    Texas
    Yes
  4. Nov 3, 2014 at 8:11 AM
    Bball
    Bball Member
    Glendale,az
    2015 Trd sport 4x4 dcsb v-6 white
    5.5 qrts is the amount on a totally dry motor, even though u drained it, theres still a little oil in the motor, alot of valleys and spots that dont drain. I usually add a half qrt under what the manuel calls for, then run the motor for a few minutes, shut it off, and add more oil till the dipstick is at full
  5. Nov 3, 2014 at 8:14 AM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    Did my oil change this weekend as well. After a 30 minute drain, a new filter, and 5.5 quarts of oil, the dipstick was 'dead on balls accurate'. Don't let your OCD get the best of you. I'll be fine.
  6. Nov 3, 2014 at 8:15 AM
    Idlewild294
    Texas
    I've thought about that. Why would Toyota put 5.5 quarts in the manual? Does the 5.5 already compensate for that? We may never know
  7. Nov 3, 2014 at 8:15 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I only put in 4.6 quarts (4.4L). Sits just perfect on the dipstick. Too much oil is just as bad as too little as it'll fuck with the VVT-i and thus the engine performance. (Since it's run off oil pressure.) I once had Castrol fuck up with a batch of oil at Costco and put 5W50 in a 5W30 box. I noticed it too late and wow...it was almost like my truck had to build boost to go it was so sluggish. Same thing happens if you over fill your truck with oil.
    No Beuno.
  8. Nov 3, 2014 at 8:17 AM
    Bball
    Bball Member
    Glendale,az
    Thats why the dealerships and oil change shops always overfill motors, they just look at the book and set the gun at that amount.
  9. Nov 3, 2014 at 8:42 AM
    high voltage taco
    high voltage taco Well-Known Member
    Monticello, Ky
    05 TRD 6 speed 4x4
    so far, URD throwout bearing kit(sleeve), weathertechs, 285/70/17's on Ion 17x9 and OME 885s and Dakars and nitro sports. BHLM
    Mine is inaccurate as well. After adding 5.5 quarts and a new Toyota filter, I start it, let it run a few minutes, shut it off, wait a few minutes and check the dipstick and it looks like I'm .5 quarts shy of full. There's oil all the way past full but there's also dry spots on the dipstick down about halfway between full and add. I've wondered if anyone else has this problem.
  10. Nov 3, 2014 at 8:43 AM
    Idlewild294
    Texas
    Thanks for the replies, keep them coming. I think it comes down to either Toyota screwing up the dipstick or screwing up and not putting the right capacities in the manual to compensate for trapped oil. I've never owned a vehicle that showed too much oil after following the manual.
  11. Nov 3, 2014 at 8:45 AM
    Idlewild294
    Texas
    I have to let mine sit all night to get an accurate reading. Only the first pull on the dipstick is the most accurate for me.
  12. Nov 3, 2014 at 8:47 AM
    Round II
    Round II Member #12005
    Where can I find the dip stick so I can check mine next time?
  13. Nov 3, 2014 at 8:50 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    The 4 cylinder (2TR) has the same issue. The owners manual calls for 6.1 qts but that much puts it at least an inch above full in the dipstick. I usually use 5.5, which puts it at 1/8 to 1/4 inch above the full mark.
  14. Nov 3, 2014 at 8:59 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    I never had an issue with my 4.0. My wifes Subaru though, that's another ballgame. Good luck checking the oil on a 2.5 boxer engine.
  15. Nov 3, 2014 at 9:01 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Was always 5.5 on my 2006.
    Just did the first change on my 2014 (yes, DIY) and put in 5.5qt.
    Overnight check shows dead on at the mark. Just sharing info, haven't heard about the inaccuracy of the dip stick.
  16. Nov 3, 2014 at 9:25 AM
    Pool Runner
    Pool Runner Well-Known Member
    Nor Cal
    '14,TRD/OR, Entune & Nav '13 Subaru Outback
    Lowes Slimline Tool box, OEM Bug shield.
    Lol, so true. Have a '13 Outback 2.5, the level can be all over place depending on when you check it.
    My 4.0 Tacoma's dipstick is fairly reliable in that regard.
  17. Nov 3, 2014 at 9:30 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    I don't think it's inaccurate, but it's just hard to get a good reading.
    For me, one side of the dipstick is better than the other. One side puts oil all up and down the thing and the other I can actually get an idea of where it's at.
  18. Nov 3, 2014 at 9:37 AM
    Blze001
    Blze001 Breaks things.
    Virginia
    2013 TRD Sport DCSB
    Reading the title, I thought it was implying the truck's owner had a rough time at the shooting range...
  19. Nov 3, 2014 at 10:40 AM
    Idlewild294
    Texas
    So we've gathered that some take less than 5.5 to hit the full mark, some take 5.5 to hit it, and mine is over the line with 5.5. Should I crack the plug and drain a 1/4 of a quart out and recheck?
  20. Nov 3, 2014 at 10:46 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Nah. Just leave it. If you put in 6 or 6.5 absolutely. But a little over won't hurt it.
