4.0's inaccurate dipstick
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Idlewild294, Nov 3, 2014.
  1. Nov 4, 2014 at 11:38 AM
    #41
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I just changed my oil today. I let it drain for about 45 minutes to 1 hour. Filter replaced. I refilled and followed owners manual instructions. It states to let sit for MORE than 5 minutes after running it to allow oil to drain back to the pan then check level.
    5 quarts exact is what I used. That put me a little shy of the top dot on the dip stick.
  2. Nov 4, 2014 at 2:41 PM
    #42
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    2011 4.0 5.5 qts works in mine.
  3. Nov 4, 2014 at 3:10 PM
    #43
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This ^^^
  4. Nov 4, 2014 at 3:27 PM
    #44
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    Wow, there is a dipstick.... who knew....
    :cheers:
  5. Nov 4, 2014 at 4:12 PM
    #45
    tl4x4
    tl4x4 New Member
    I've changed oil in numberous 4.0's they all take 5.5 qts of 5w30 with a wix 1348 filter or equivilant, dont check your oil after your engines hot, oil expands with heat, you just need to start it up for a few seconds after your done your oil change, all that does is puts oil into the filter, so you can get an accurate reading, when your red oil light goes out your good. If your dipstick is reading high try this trick clean oil off stick then spray it with parts cleaner or a penetrating oil and wipe it off good, then check your oil, the oil residue wont stick to the dipstick only the new oil will.
  6. Nov 4, 2014 at 7:10 PM
    #46
    vram74
    vram74 Well-Known Member
    05 Prerunner SR5
    I always check oil at the gas station, after filling up. Thought that's what the manual recommended. Didn't think it was accurate reading to check it cold, like the tranny.
  7. Nov 4, 2014 at 7:17 PM
    #47
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Yes, a process of trial and error, and error, and error. :D
    This. Anywhere between 3.9 and 5.5 qt is fine for the engine. No need to overthink it. More oil just means a slightly bigger heat sink.
  8. Nov 5, 2014 at 4:30 AM
    #48
    moondeath
    Pa, Gardners
    You've got it backwards. The manual states to check the oil when it's warm. Wait 5 minutes after engine runs to let the oil drain to the bottom of the engine.
  9. Nov 5, 2014 at 5:05 AM
    #49
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    I'm not so sure that's fair--------reading the manual.;)
  10. Nov 5, 2014 at 5:14 AM
    #50
    moondeath
    Pa, Gardners
    Lol. Those pesky informative manuals.
    It also states that 5.5 quarts is a reference only. To warm motor, wait 5, check dip stick.
  11. Nov 5, 2014 at 12:28 PM
    #51
    xbxb
    Jim
    O.P. Kansas
    Well there you go again. It really screws up a thread of mis information when you present facts. Now this whole thing is going to go down hill. Oh well, back to reading How much should I lift my truck threads.
  12. Nov 5, 2014 at 5:35 PM
    #52
    KenLyns
    Belly of the Beast
  13. Nov 5, 2014 at 5:40 PM
    #53
    moondeath
    Pa, Gardners
  14. Nov 5, 2014 at 5:54 PM
    #54
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    Just be thankful our trucks even have dipsticks. My BMW doesn't have one, you have to rely on a sensor. That sucks, knowing how often damn sensors go bad.
  15. Nov 5, 2014 at 6:32 PM
    #55
    KenLyns
    Belly of the Beast
    ^Maybe a victim of arcane BMW engine way layout. i.e. if they put in a dipstick, it'll probably be unreadable. The Mini Cooper suffers from this, so much that Cravenspeed makes an "enhanced dipstick" for it that costs $75 :eek:: http://www.cravenspeed.com/mini-dipstick/
    Does your BMW have a transmission dipstick though? :p
  16. Nov 5, 2014 at 6:43 PM
    #56
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Never do that, (fallow to the letter) For me a 5quart bottle is good enough. This includes a new oil filter always. It is true, my trucks get exchanged just before 100.000
    miles.
  17. Nov 6, 2014 at 10:29 AM
    #57
    cheech1
    Kaneohe, HI
    No dipsticks at all. But I figured the reason for this is that the dipsticks that own BMWs never check their fluid levels.
  18. Nov 6, 2014 at 11:47 AM
    #58
    KenLyns
    Belly of the Beast
    ^And you think the practical-minded Corolla appliance drivers check their fluid levels? :p
  19. Nov 6, 2014 at 2:01 PM
    #59
    Round II
    Round II Member #12005
    Ok oh sensitive one dont get em in a bunch.;)
  20. Nov 6, 2014 at 2:54 PM
    #60
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    OP: in my experience, up to about 1/2" (or 1/2 quart) above the full mark is not a big concern, but beyond that may cause issues. I'm not advising you to overfill, I'm saying don't freak out if it goes a bit above.
    If you are towing or racing or other severe service, sure you want to have as much in there as possible without going way over full. But in everyday normal driving it does not have to be exactly at the full mark, only between the add and full marks. Just change the oil and filter regularly, and check the level every fuel fill.
    Of course this is assuming you are not burning or leaking oil.
    Put on a new filter and add one 5-quart jug (no more), run it and see what the level is. It should be right there in the sweet spot between add and full. Done. No messing with half quarts.
    This refers to a factory new or freshly rebuilt engine that hasn't been fired yet and there's no oil in any valleys or other internal hiding places as there would be after draining used oil. Toyota put this in the manual just to cover their asses under all conditions. Although I give Toyota some credit for thoroughness, this information is not really necessary and (obviously) is causing more problems than it's solving.
    Edit... LOL I just realized why you asked about the dry motor thing - the OP doesn't have this situation so that is largely irrelevant in this thread. Derp.
