4.10 gears and 33's
Discussion in 'Performance and Tuning' started by Volcom21, Feb 17, 2012.
  1. Feb 17, 2012 at 12:46 PM
    Volcom21
    Volcom21 [OP] Member
    Inland Empire
    05 white prerunner
    I was told if i went with 4.10 gears with 33's that my top speed would be 85 mph. Is that true? Thanks
  2. Feb 17, 2012 at 12:53 PM
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    False , whoever said that was definitely wrong,if you only had three gears yeah that would your top speed
  3. Feb 17, 2012 at 12:57 PM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Theoretically you could hit 184 mph in 5th gear.
    Might need a little more motor though......
  4. Feb 17, 2012 at 1:23 PM
    Volcom21
    Inland Empire
    05 white prerunner
    So basically i would just get the power back as if i was stock and maybe a little better mpg? And my rpm's would just be a little higher on the freeway? thanks
  5. Feb 17, 2012 at 1:29 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Your mpg will never be the same as stock. It will just be closer. You don't gain power, just a little of what you lost
  6. Feb 17, 2012 at 1:38 PM
    MadToy
    Nick
    Huntersville, NC
    Yep. You get your gearing back close to stock - but you're still pushing more rotating weight, with a bigger contact patch.
  7. Feb 17, 2012 at 2:18 PM
    commando
    commando Well-Known Member
    Brandon
    Oregon
    2006 SR5 Double Cab 4X4
    3" spacer lift
    Dude, i just put 4:10's in my 2006 4.0L DC (with 33's) and it is freaking awesome.
    DO IT!
    Top speed 85???:crazy::crazy:
  8. Feb 17, 2012 at 3:19 PM
    Volcom21
    Inland Empire
    05 white prerunner
    Yeah idk thats the what shop said and it didnt seem right
  9. Feb 17, 2012 at 6:57 PM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    I have 4.10's waiting to be installed. How much did it help your MPGs?
  10. Feb 17, 2012 at 7:02 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    U should kick the person who told you that square in the nutz!!!! 4.10 are perfect with 33's will drive just like it was stock ....4.56's will make it "feel" like it has more power but you would be revving to high at 65mph an would kill ur mpg's
  11. Feb 17, 2012 at 8:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    FWIW, WHen I regeared my Dodge ( I know, different vehicle, etc.), after larger tires, Stock MPG was 12, after the larger tires, and re gear to 4:10s MPG went to 14. RPM's went from 1600 @ 60 mph, to 1850 @ 60. @ 70, I was around 2200 to 2300 rpm.
    4.10's with 33's would make the truck just a tad "over geared" as opposed to stock. MPG should be about the same, and in town, a little better.
  12. Feb 17, 2012 at 8:53 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Regearing does not improve mpg, it just makes your odometer accurate again.
  13. Feb 17, 2012 at 8:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It improved my MPG. On my Dodge, the speedo, and ODO work off the wheel speed sensors, and are unaffected by gearing changes. The only thing I had to re calculate was tire size, and factor that into the millage.
    Edit: To add, every gas vehicle I have re geard, has shown an improvement in MPG, if larger tires were also installed.
  14. Feb 17, 2012 at 8:57 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    so, u'd just be at a higher rpm to maintain speed? i currently run very close to 3k RPM doing 80MPH. so if i geared to 4.10's, i'd be running higher rpm's at same 80MPH -is this correct?
  15. Feb 17, 2012 at 8:58 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    False, odometer is completely unrelated bro
  16. Feb 17, 2012 at 8:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    yes.
  17. Feb 17, 2012 at 8:59 PM
    worthywads
    Yep. so your mpg will go down.
  18. Feb 17, 2012 at 8:59 PM
    tacobo670
    Ray
    Las Vegas
    so logics suggests ... higher RPM = more gas consumed = less MPG?
  19. Feb 17, 2012 at 9:00 PM
    tacobo670
    Ray
    Las Vegas
    got it. ok. thanks. i was thinking of regearing but since my pmg already sucks as it is, n i would have to get front n rear assy's i think i'll pass.
  20. Feb 17, 2012 at 9:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    With 33" tires, a manual tranny in 6th gear, and 4.10 gears, my calculations of a 70 mph speed give an RPM of about 2500.
