4.10 gears!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05RedTaco, Jan 14, 2011.
  1. Jan 14, 2011 at 7:17 PM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Will 4.10 gears from non-elocker 05 Taco fit my 08 base 5lug Taco with 8" rear end? As far as I know only TRD off-road e-locker equipped Taco has 8.4" rear end....
    Any insight on this?
  2. Jan 14, 2011 at 7:21 PM
    05RedTaco
    Tony
    Scottsdale
    Well I am going of this;
    All 2wd and 4wd T100's, '00-06 Tundra's, and ?? Sequoia's use a newer/stronger 8" 2-pinion diff. Tacoma 4x4's and Tacoma PreRunner's that don't come with the electric locker (aka "non-TRD), as well as V6 Tacoma 4x2's also came with this diff.
    This diff commonly and mistakenly called an 8.4" or 8.25" diff, possibly to imply its extra strength. The ring gear actually measures 8". The extra strength of this diff comes from the bearing cap/truss and large diameter pinion gear shaft.
    LSD's available is the TRD/Kazuma clutch-type 3-pinion LSD, the OEM 4-pinion Tundra TRD LSD, and the Detroit Trutrac.
    Lockers available are the Powertrax "Lock-right," "No-Slip," ARB Air Locker, Detroit Softlocker.This diff cannot be fitted to an older style 8" axle because it uses a larger diameter mounting bolt pattern and because more space inside the housing necessary to accommodate the large bearing cap. The different bolt pattern also makes it very impractical to swap in an electric locking Toyota diff (the whole mounting flange would have to be re-done using a special jig).
    - Carrier bearing truss and newer housing adds significant strength over V6 and 4cyl diffs
    - Uses V6 carrier bearings, larger pinion bearings
    - Uses shims for backlash adjustment instead of threaded adjusters
    - Twelve 12mm Ring gear bolts
    - 10mm axle housing studs with 14mm nuts
    - 30 splilne axles
    - 30 spline pinion
    * 4Runners do NOT use this diff at all. Late-model 4Runners still use the V6 8" diff above.
    ** This diff is NOT swappable with V6, 4cyl, high-pinion, or electric locking diffs. This diff cannot be fitted to an older style 8" axle because it uses a larger diameter mounting bolt pattern and because more space inside the housing necessary to accommodate the large bearing cap.
  3. Jan 14, 2011 at 7:23 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    whipper is right. and to add, v6=3.73 and 4cyl=4.10...at least that is for the 6 lug versions
  4. Jan 14, 2011 at 7:29 PM
    05RedTaco
    Tony
    Scottsdale
    These gears would be from 04 V6 Taco TRD.
    Hrm... Now that I think about it the only TRD package in 04 was TRD off road with e-locker.. These won't fir my truck....FUCK
    The guy wants $35 shipped for them on ttora.com Damn, I thought I was going to snatch these for cheap :(
  5. Jan 14, 2011 at 10:25 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    Your truck already has 4.10 gears...
  6. Jan 15, 2011 at 7:07 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    No, he has 3.31's.
  7. Jan 15, 2011 at 9:22 PM
    all.on.black
    Auburn, WA
    You're right. I didn't see that he has a manual transmission. Automatics come with 4.10s.
  8. Jan 16, 2011 at 6:59 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Auto 5 lugs have 3.58's.
    PreRunners and 4x4's have 4.10's.
  9. Jan 16, 2011 at 7:04 AM
    mattcombs
    mattcombs Well-Known Member
    matt
    hazard kentucky
    SR5 tacoma 4wd
    3in revtec lisf westin step bars and westin bull bar and some other odds and ends
    mines a 4 cyl sr5 and i have 4 10s on an 8 inch diff. not 8.4
  10. Jan 16, 2011 at 7:10 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    The non-TRD diff's in tacomas are commonly referred to as 8.4" even though the ring gear still measures 8".
  11. Jan 16, 2011 at 1:06 PM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Does that mean the TRD Sport has the 8.4?
  12. Jan 16, 2011 at 3:00 PM
    jhodge83
    SC
    17 XLT Sport
    yes
  13. Jan 16, 2011 at 10:27 PM
    all.on.black
    Auburn, WA
    You're wrong there. All 4x4 2.7s come with 4.10s. All 4x2 (PreRunners as well) come with 3.58s.
