4.10 gears
Discussion in '4 Cylinder' started by coltkid, Aug 10, 2011.
  1. Aug 10, 2011 at 5:31 PM
    coltkid
    coltkid [OP] Member
    Randy
    N.H.
    Hello all, does anyone have a 2011 tacoma reg. cab 4x4 with 4.10 gears? im looking to buy one and have not had this ratio on a truck in over 20 yrs. i had a 1987 s-10 with this gear ratio and really liked it..any info would be a help, thank you..
  2. Aug 10, 2011 at 5:34 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i have a 2010 reg cab 4x4 with 4.10 gears, not a 2011 so... bye
  3. Aug 10, 2011 at 5:34 PM
    Yoytoda
    Roland
    completely stock
    lol just kidding im back... What do you want to know?
  4. Aug 10, 2011 at 9:02 PM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    If you dont like your 4:10's i will trade you for some factory 3:73's...
  5. Aug 10, 2011 at 9:25 PM
    PR45
    PR45 Well-Known Member
    Los Angeles
    PreRunner SR5 4cyl
    The 4.10s work well, and putting on a 32" (31.8" according to Tire Rack) tire corrected the speedo. 2.7 Prerunner AC.
  6. Aug 11, 2011 at 8:05 PM
    Yoytoda
    Roland
    completely stock
    What?
    :confused:
  7. Aug 12, 2011 at 7:14 AM
    jdmjerry
    jdmjerry Well-Known Member
    what rpm are you at with 4.10's at 65? and were do you go about buying the gears.. cause i want to do the same..
  8. Aug 12, 2011 at 7:48 AM
    Yoytoda
    Roland
    completely stock
    are you a 05+ 4 banger? prerunner or 4x4? if yes then you already have 4.10 gears
  9. Aug 12, 2011 at 11:37 AM
    PR45
    Los Angeles
    PreRunner SR5 4cyl
    x2 on the 4 cylinder PR and 4x4 already having 4.10s.
    The calculated rpms at 65 with 32" tires would be:
    2253 in OD (.805)
    2798 in 4th (1:1)
    or
    29 mph per 1000 rpm in OD
    23 mph per 1000 rpm in 4th.
  10. Aug 13, 2011 at 8:59 PM
    BP348
    BP348 Well-Known Member
    San Diego, CA
    2004 DC 4x4
    i believe gear ratios are different between manuals and autos
  11. Aug 17, 2011 at 12:30 PM
    jdmjerry
    i have a 2006 4 cycl 4x4 standard cab... i have 4.10's?
  12. Aug 17, 2011 at 12:48 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    2011 4x4 AC 4banger 5speed with 4.10 gears
  13. Aug 17, 2011 at 12:50 PM
    rcfreak201
    rcfreak201 Well-Known Member
    does anyone in here want some 4.10s i have some for sale... pm me if so
  14. Aug 17, 2011 at 12:51 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Post this in the 5-lug section and someone will buy them for sure!
  15. Aug 17, 2011 at 12:52 PM
    rcfreak201
    ok thanks:cool:
  16. Aug 17, 2011 at 1:05 PM
    afd23a
    The Dynamo of Dixie
    No problem, they're a hot commodity for lifted 5-lugs and hard to find on the used market.
  17. Aug 17, 2011 at 1:22 PM
    rcfreak201
    how much have you seen them go for?
