4.10? Or 4.56?
Discussion in '5 Lug' started by Mel05, Oct 31, 2017.
  1. Oct 31, 2017 at 7:59 PM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    I had 31 on my 5 lug auto and it sucked balls. Mpg sucked, no up hill speed unless I could a running start. I have 31 now on my manual 5 lug n its a little better, mpg are about the same, rpms stay fairly low so freeway driving isn't bad, accelerating it lags, i rarely use 5th gear (mainly cuz my work commute is 2 miles of freeway) I'd plan to get 4.10, any gear bigger for bigger tires then you'll be redlining on the freeway
  2. Oct 31, 2017 at 8:04 PM
    Mel05
    Mel05 [OP] Member
    So you’re power isn’t all that bad? And if you do end up getting 4.10 update me on that please, because with all these responses I’m just going to settle for make a cold air intake and see if that can get me some power back
  3. Oct 31, 2017 at 8:09 PM
    la0d0g
    running for the hills
    For crawling not hauling
    CAI intakes are only for sound, not performance gains.
    5 Lug Fury, EatSleepTacos and HackD like this.
  4. Oct 31, 2017 at 8:10 PM
    BikerinBlak909
    SoCal
    96 LT 5 lug
    If your manual then you'll be ok, if your auto regear
  5. Oct 31, 2017 at 8:11 PM
    BikerinBlak909
    SoCal
    96 LT 5 lug
    Do a deck plate mod its cheaper the CAI n better gains
  6. Oct 31, 2017 at 8:46 PM
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    If you are going to go be going much above 29" .. make the plans to re-gear at some point. The regearing issue really depends on your personal situation and driving style - If you are higher altitude.. it's going to suck. If you are in hilly or mountainous terrain, it's REALLY going to suck. If you like taking your time getting up to speed.. leave it alone, because that's what it'll do, take it's time (relatively speaking).
    The Tacoma does pretty good with the 2.7L .. but the 5-lug setup is optimized for the smaller diameter, lighter tires. You just can't look at tires and go, 'that'll do'... because it likely won't. It's not going to do well with the 159hp it has to work with, to balance things out on it's own. Doing one mod, can also throw things out of wack elsewhere, which in turn then needs to be dealt with. Ask me how i know that.
    Gearing also comes down to driving style. If you are a 'sunday drive' kind of driver, no sense of needing to hurry.. then it might be ok. If you need throttle response and relatively responsive acceleration, you aren't going to be happy. I'm a bit of a lead-foot, so things needed correction - sooner or later.
    I went from 29.3" tires with the stock 3.31 MT gearing to 31.7" tires with a 4.10 re-gear recently. 29.3" was onerous enough. An LCE header (this is where you'll find the major intake/exhaust performance gain for the 2.7L in the form of a shifted torque curve) was installed as an interim measure before a re-gear .. it helped - but total benefit of the LCE header was only realized, when the motor had the correct gearing to put the power down without driveline strain, as it should.
    FWIW .. i think you need to look at the total package, and decide what you want out of truck - choices may lead to unintended consequences and costs, leading to further choices needing to be made shortly down the road... know what i mean?
  7. Oct 31, 2017 at 8:48 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Rehearing a 5lug.. just get a 6lug v6..
  8. Oct 31, 2017 at 8:49 PM
    HackD
    William
    You are in the 5-lug section. Tread lightly.
  9. Oct 31, 2017 at 8:50 PM
    Oreo Cat
    6lug is life.
  10. Oct 31, 2017 at 8:51 PM
    HackD
    William
    Don't be a douchebag.
  11. Oct 31, 2017 at 8:51 PM
    Oreo Cat
    If you're putting bigger tires on especially. I'd get a 5lug as a dd. And keep the 6 for fun
  12. Oct 31, 2017 at 8:54 PM
    Oreo Cat
    I'm not. I'm just saying it's a lot of work to regear, probably not worth it when there's trucks that can fit easily fit and move 31s no problem.
  13. Oct 31, 2017 at 8:56 PM
    HackD
    William
    Hi - and if you are reading this thread - you will note that i've done all those not worthwhile mods myself. I'm sure the OP can count his own pennies. I personally found it worth it.
    Brice likes this.
  14. Oct 31, 2017 at 9:01 PM
    Oreo Cat
    @Mel05 i believe there's also 4.30 gears. I'm no t entirely sure though. Might be worth looking into
  15. Oct 31, 2017 at 10:45 PM
    #35
    BikerinBlak909
    SoCal
    96 LT 5 lug
    If you get a 6 lug rear end then you'll have 2 different lug patterns. But finding a rear end n swapping it would be the cheapest way to go. And the 8.4 have more options for gears n lockers
  16. Oct 31, 2017 at 11:01 PM
    #36
    Oreo Cat
    I Meant it as it might be better to find a new truck if he wants something with big tires and is worried about power.
  17. Nov 1, 2017 at 12:31 AM
    #37
    5luggertaco
    5luggertaco Active Member
    Gio
    California
    2015 Storm Trooper White Base
    2.5 Icon Coilovers Total Chaos Control Arms 265x75r16 All Terrain 16 Blk Method Wheels Limited Slip
    I'm currently running 265s are those things are beefy (All-terrain). I just had my truck regeared to 4.10. and ohhh baby so much better
    HackD likes this.
  18. Dec 3, 2017 at 1:41 PM
    #38
    5lugturtle
    5lugturtle Well-Known Member
    Conner
    San Diego
    2012 Silver Tacoma 5 lug regular cab 2x4
    Lift,31s
    I am getting mine to I can't stand the stock gears lol.
  19. Dec 3, 2017 at 2:13 PM
    #39
    HackD
    William
    Still gotta decide whether you are still saving for that 4x4 TRD, or going for broke? ;)
  20. Dec 3, 2017 at 6:26 PM
    #40
    5luggertaco
    Gio
    California
    I suggest it, well if your not going to go 4x4. Before 5th gear was worthless and had it at 4th all the time. But now its perfect, well besides the speedometer off by 5-8mph :facepalm:
    BikerinBlak909 likes this.
