4.11 vs 4.56 Gears
Discussion in 'Performance and Tuning' started by MrZoggs, May 13, 2010.
4.11 vs 4.56 Gears
Poll closed Jun 12, 2010.
  1. Play it safe, go with 4.11's
    5 vote(s)
    26.3%
  2. Mo Power, Mo Better, go with 4.56's
    14 vote(s)
    73.7%
  1. May 13, 2010 at 6:15 PM
    MrZoggs
    MrZoggs [OP] Ainokea
    Zach
    Alaska
    13' DCLB Sport
    Some Stuff...
    Hey guys I'm looking to re-gear my truck in a week or soo..
    Just wanted some thoughts and opinions on whether I should go with 4.11's or 4.56 gears.
    I'm going to be up on a 4" Spindle lift with 33's.. I would like to retain my factory power x weight ratio with the lift but wouldn't mind gaining some extra power out of it. My only concern in going with the 4.56's is that my rpm would be too high on the freeway.. I average between 75-80mph on my longer trips. Soo as long as I'm not running 2750-3000+ rpm's on the freeway cruising at 75-80 then I'll be happy.
    Anyone have any experience with the 4.56's??
  2. May 14, 2010 at 6:38 AM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    i'm not positive but i thought you could only get the 4.11 for the second gen if it came factory or you take it out of another truck. someone correct me if i'm wrong
  3. May 14, 2010 at 6:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    From what I have calculated, if your truck is a daily driver, the 4:10's (or 4:11's) would be a good option. If you want a little bit more power, at the expense of some hwy mpg (if any), get the 4:56's.
  4. May 14, 2010 at 6:56 AM
    SilverSeven
    SilverSeven Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
    4.56 with 33s and our engines is good
  5. May 14, 2010 at 7:20 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  6. May 14, 2010 at 7:21 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I would go 4.11 IMO, I think 4.56 would be a little too extreme but its a good option if your not willing to sacrifice the highway mileage
  7. May 14, 2010 at 8:02 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Subbed for later. Ill post another calculator that's a little more accurate than the one on this site. The one on this site doesn't take into account overdrive, it gives you rpm's based off of a 1:1 gearing which overdrive is closer to .85 therefore one on this site gives you a much greater 65 mph rpms than you should expect
  8. May 14, 2010 at 8:56 PM
    08pretaco
    az
  9. May 14, 2010 at 9:04 PM
    tacomakid89
    tacomakid89 Awesome Member
    William
    Austin, Texas
    2010 Black, 4x4, TRD Sport Tacoma
    Hard Wired GPS, Scan Guage II, URD Short Throw Shifter, AFE Pro Dry S Air Filter, LED Mag Lite on seat side,Tailgate Theft Prevention Mod, Removed Front License Plate, Tint Cover Over Rear License Plate, Removed Secondary Air Filter, 13" Shorty Antenna, 5% Tint Rear, 20% Tint Front, Bed Extender, TRD Cat Back Exhaust, Fog Light On Anytime Mod, Dual Halo Projection Headlights, Disabled Seatbelt Chime, King coilovers with remote resi in front, Kings with remote resi in rear, Deaver J66 leaf packs, TC UCAs up front.
    How much is that going to cost ya. If you dont mind me asking.
  10. May 14, 2010 at 9:05 PM
    08pretaco
    az
    250 for gears, up to 250 for a master install kit, and i think its about 200-300 for gear install
  11. May 14, 2010 at 9:14 PM
    tacomakid89
    William
    Austin, Texas
    Ok. Thanks.
  12. May 14, 2010 at 9:35 PM
    08pretaco
    az
    but the op will probably post what his costs are, i just gave the ball parks. trying to be helpful :eek:
  13. May 15, 2010 at 7:59 AM
    MrZoggs
    Zach
    Alaska
    13' DCLB Sport
    Some Stuff...
    Went to a buddies shop yesterday to get a quote...
    That dip-stick wanted $1500.00 for gears plus install...
    (I laughed and walked away) Looks like I'm just gona get a Master set from ECGS and find a better shop that actually knows what they're talking about to do the install.
    I've also decided that I'm going to go with 4.56's... I figured that if I'm shelling out the money to regear, why not go all the way and get the bigger gain from it. I don't think the 4.11's would do enough justice for me.. I'm also still up in the air about a supercharger.. Might just get the X-One + my other mods and leave it at that after the gearing..
    Keep you guys posted~
  14. May 23, 2010 at 3:09 AM
    dwntwnall4u
    dwntwnall4u Well-Known Member
    Kevin
    san diego
    2013 4x4 Dbl cab Auto
    Did you get the gears yet?
  15. May 23, 2010 at 12:33 PM
    dwntwnall4u
    Kevin
    san diego
    I believe you meant URD "supercharger" kit.
  16. Jun 12, 2010 at 7:09 PM
    KRS1
    KRS1 Active Member
    Windham, ME
    07 Tacoma 4X4
    6" Pro Comp Susp. Lift 3" Body Lift 35 x 12.50 Cooper Tires CAI (home made) Doug Thorley Long Tubes Flowmaster (44 series) mufflers 150'x3/8 Blue Steel syn. wire rope Wet Okole neo. seat covers
    i have the same question but a little diffrent.... i have an 07 taco... 4x4 and do a lot of off roading... live on an island now (GUAM) but moving back to the states next year... so more highway miles.... i have 6" pro comp sup lift and 3" body and running 35x12.50................ i need to know whats going to be better from me... what does everyone thing 4.11 or 4.56................ i am all about going big or going home..... let me know what you guys think
  17. Jun 12, 2010 at 7:23 PM
    mattcombs
    mattcombs Well-Known Member
    matt
    hazard kentucky
    SR5 tacoma 4wd
    3in revtec lisf westin step bars and westin bull bar and some other odds and ends
    i thought prerunners and sr5 models even 4 cyl came stock with 4.11 . .if not what is it . .i have 285 75 and no regear with the 4 cyl
  18. Jun 13, 2010 at 4:04 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    In your case,4.56.
  19. Jun 13, 2010 at 9:21 AM
    75thrangertaco
    75thrangertaco Sua Sponte! RLTW
    charles
    casper wyoming
    procomp 6 inch co lift ,305/55/20 xtreme a/t tires,4.88 gears ,,grill shell painted white billet inserts.Trd cat back ,
    i have 4.88s with 33s i run about 2900 at 80mph. but im rarely on the hiway. i think 4.56s should do you well
  20. Jun 13, 2010 at 9:42 AM
    mpleitez
    mpleitez Well-Known Member
    valencia
    03 toyota tacoma double cab 4x4
    Rear E-Locker TRD supercharger w/URD 7th injector 3 in. lift (soon) Icon coil overs front (soon) Icon UCA (soon) K&N air intake DT Headers (one day)
    I'm runing 4.56 and yes at 75 or 80mph you will be at 2500 or plus rpm I didn't think theymade 4.11 for our trucks you can however possibly get them from a 4cyl 2nd gen they come With 4.11
