4.3 regear for AT thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NOLAMedic, Sep 2, 2018.
  1. Sep 2, 2018 at 9:49 PM
    NOLAMedic
    NOLAMedic [OP] Well-Known Member
    2018 Quicksand DCLB TRD Off Road
    Who's done it and what were your results? Improved MPG? What performance gain? Why did you do it?
    I'm looking to regear to 4.3's at some point. I went from 22ish mpg to 14.5(per the computer)mpg when I went to 255/85/16 cooper ST tires. That sort of MPG is just terrible. Even on the highway I'm only getting 15.8-16.2. Has anyone else had terrible MPG with their truck that was fixed with a regear? I'm also running the OVTune.
    Lastly, if I thought regearing to 4.56 would fix my MPG woe's I'd do that instead. Does anyone even make 4.56 gears for the taco? Or just the 4.88?
  2. Sep 2, 2018 at 11:26 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No it won't fix it. You will simply have more torque. The reason your mpgs suck is you added weight and unsprung mass. Can you get a bit better than what you have with a regear? Sure, but it will never be back up to stock numbers.
    Sorry man.
  3. Sep 2, 2018 at 11:29 PM
    ninernation
    ninernation Well-Known Member
    WA
    TRDOR
    OME, ALUCAB, RCI
    Those numbers are drastically different then what others are reporting. Anything else different?
  4. Sep 3, 2018 at 3:39 AM
    Weirich
    Weirich Drunk_taco
    Travis
    2016 Tacoma access cab TRD Offroad
    OvTuned 4.88 R&P Hypertech speedometer calibrator Rough country 6" lift Toyo open country 285/75R17(old) Cooper STT Pro 315/70r17 Archive garage shackle flip Tough country uni ball uppers Icon 2.5 6" front coil overs Icon 2.5 CDC 6" rear shocks OME cs047r rear leaf packs AllPro HD Sliders Tom woods double cardin single piece drive shaft Magnaflow exhaust Black rock D window rims(old) ICON 17x8.5 Rebound CBI T3 full guard front bumper Smittybilt x20 10k winch HEISS 20" single row light bar ARB on board air compressor
    It might give you better gas mileage, but a speedo calibrated will help more than anything if you haven't done that yet. I'm running the 4.3 gears and I like it but it's not perfect. I'm running a 285/75r17 which it about .7" taller of a tire but it's a load E, i also have a 6" lift. The ovtune helps a lot(hopefully it gets better with the next release of 1.05) I can get about 20 on long trips that allow the transmission and fluids to get warm, but that's doing about 65-70 and driving mildly. Around town I get about 16mpg. Mpg with tires and lift depends heavily on how much skinny pedal you use.
    RevivalOL likes this.
  5. Sep 3, 2018 at 4:25 AM
    RevivalOL
    RevivalOL Well-Known Member
    Pete
    Berkley, MI
    2017 TRD Off-Road DCLB
    ^ This. Get the Hypertech speedo calibration unit first and then see where you’re at. Also, how many miles on the truck? My mpg went up by about 2mpg shortly after I hit 16k miles
  6. Sep 3, 2018 at 5:00 AM
    NOLAMedic
    Ditch lights.
  7. Sep 3, 2018 at 5:40 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Yeah, everything is based on the original tire OD. Your mileage won't be right until you fix calibration.
    Are you on BS?
    commbubba19 likes this.
  8. Sep 3, 2018 at 5:51 AM
    NOLAMedic
    Not sure what BS means, so probably not. What’s the percentage difference between stock at 255’s?
  9. Sep 3, 2018 at 6:24 AM
    NOLAMedic
    Have you done this mod?
  10. Sep 3, 2018 at 8:14 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No. I understand math though.
    Hobbs likes this.
  11. Sep 3, 2018 at 8:17 AM
    SpeySquatch
    2016 TRD OR DCSB
    What size tires were you running to get 22 mpg?
  12. Sep 3, 2018 at 9:23 AM
    SpeySquatch
    2016 TRD OR DCSB
    Technically you should close to the same mpg. Here is why my theory (to me) is sound.
    You have a tall skinny tire that weighs 3lbs more per tire than let’s say a 265/75 r16 Falken AT3. 1/2” less width equals less surface friction so that alone should net a little increase. Second the taller tire will allow lower RPMs so when cruising you should get about the same mileage since weight in tire is not much more than a cooler full of food.
    Can someone chime in as to why or why not this is incorrect?
  13. Sep 3, 2018 at 9:26 AM
    NOLAMedic
    With stock tires I was Getting 22-23.
  14. Sep 3, 2018 at 9:28 AM
    SpeySquatch
    2016 TRD OR DCSB
    Ok well if it helps, I was getting 20-25 with stock tires and only went up one size to 265/75 r16 and that drop to 16-20mpg and I’m OVtuned
  15. Sep 3, 2018 at 9:56 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    He’s likely getting the same but his computer is not recalibrated to the new size.
    -40 likes this.
  16. Sep 3, 2018 at 9:56 AM
    Woodrow F Call
    Colorful Colorado
    Bayou Shooter recognize the user name from some forum.
  17. Sep 3, 2018 at 9:59 AM
    NOLAMedic
    Nope not me.
  18. Sep 3, 2018 at 10:04 AM
    NOLAMedic
    Not even close to the same. 8 percent difference. I’m getting under 16mpg daily average
  19. Sep 3, 2018 at 10:09 AM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    Not an OV tune person but regeared to 4:88’s locked front . Fox 2.5 DSC all around , Dakar’s , Nitto ridge grapplers 295/70/17 Camburg UCA’s, skids 2 Arb Twins front and back plumbed to bumpers.
    Drives great! Did the regear mainly for offroad and it does help the tranny situation make no mistake there.
    But the auto trans never bothered me in the first place.
    If you're going to do these types of mods your MPG will suffer. But I just did a Las Vegas to Carmel the long eastern route via 395 and lots of summits and got 18.8 mpg’s.
    But to be clear it effected the MPG’s which is neither here nor there to me, and should not matter to those doing these mods IMO.
  20. Sep 3, 2018 at 10:28 AM
    JoeCOVA
    Joe
    Colorado Springs
    Have you divided the number of miles you have driven in a tank by the gallons needed to fill it?
    That’s your true MPG
    commbubba19 and Tacomamike mike like this.
