4.3 regear for AT thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NOLAMedic, Sep 2, 2018.
  1. Sep 3, 2018 at 10:30 AM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    He put oversized tires on ...so ??? Needs the math for that.
  2. Sep 3, 2018 at 10:32 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    It can help mpg as the engine no longer has to work as hard to get the vehicle to speed. He effectively lowered his gearing and also added some weight that the engine now has to work harder to overcome, but using more fuel. The extra gearing from a regear will allow the engine to relax a bit, using less fuel.
    hiPSI[QUOTED] likes this.
  3. Sep 3, 2018 at 10:39 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Two important truths of the universe:
    1: you don’t get something for nothing.....ever, not ever, never.
    2: guys on Tacoma World will always exaggerate their fuel economy numbers after lifting and larger tires.
    TSAVO, Weirich, hiPSI and 1 other person like this.
  4. Sep 3, 2018 at 10:54 AM
    Tacomamike mike
    Michael
    Lol Amen
    hiPSI and Stocklocker[QUOTED] like this.
  5. Sep 3, 2018 at 11:44 AM
    Rus$
    Rus$ Well-Known Member
    Russ
    2018 Tacoma DCLB AT TRD Off Road
    True. I can vouch for Weirich tho since he's my roommate. His averages 19 mpg on the highway when I've borrowed it. The taco box truck up at Marlin Crawler was getting 17 mpg on the highway and he's on 40s. Gearing and recalibration are huge.
  6. Sep 5, 2018 at 5:25 AM
    solarguy2003
    solarguy2003 Active Member
    Just as another data point, the best tank I ever got was just a touch over 25 mpg, and that was using a bunch of hypermiling tricks. My typical fuel economy is 23+ unless I tow a lot. My typical commute allows me to drive between 45 and 60 mph most of the time.
    Bone stock, manual transmission, but I do run the tires a bit fuller than typical, between 45 and 50 psi. No, I don't have treadwear problems.
    If I don't limit the speed, and don't limit the acceleration from a stop, and don't coast up to stops as much as possible, the fuel economy drops to 18-19. It only has 8,500 or so miles on it.
    On the highway at >/= 70 mph, the aerodynamic drag becomes the overwhelming factor and F/E drops to 19'ish.
  7. Sep 5, 2018 at 5:43 AM
    lamia2super
    lamia2super Well-Known Member
    Frank
    Miami Beach, FL
    2016 Tacoma TRD Off-Road, (sold) 07 Tacoma xRunner
    ouch, I have 285/70/17 with 3in lift and averaged ~17mpg from Florida-Tennessee (1800 miles round trip going 70-75mph). In Florida driving around town keeping it slow I average 16mpgs. No tsb or ov tuning yet
    my factory tire was a 265/65/17 and i would average 18 around town and ~20mpgs on florida flat highway roads
    I would like to go up in tire size and gearing
  8. Sep 5, 2018 at 6:16 AM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    Did you use the hypertech tool to correct your speedo? If not, that is why your MPG's are reading so low.
    The stock calculations are very generous on stock tires. I was getting 23-24 on avg and that seemed rather high. Went to a 265/70/17 and my mileage is about 20 per the computer. Over the last month i've done the check manually and been almost spot on with the cluster reading at 20.
    Your actual mileage likely isn't as bad as being displayed. Don't regear just to improve mileage, do it for a performance benefit.
    Read through the 4.88 thread. 4.88's for the auto still put your overdrive gears lower than the manual guys with 4.30's.
    My 4.88's are being installed this weekend.
  9. Sep 5, 2018 at 6:20 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    And 5.29s on an AT have almost the exact same final drive ratios for 5th and 6th gear as the MTs on 4.30
    commbubba19[QUOTED] likes this.
  10. Sep 5, 2018 at 6:27 AM
    SubCultureNM
    SubCultureNM Well-Known Member
    Brian
    Houston, TX
    2017 DCSB
    '17 DCSB on 285/75R16s with 4.88s gets 19.5mpg on Houston freeways. Get it out on the open road, especially in wind, and that will drop to as low as 14.5 at 80 mph.
