(4) 4Runner Off-Road wheels w/ Bridgestone Dueler H/T P 265/70 R17 tires
Discussion in 'Wheels & Tires Marketplace' started by EatsInPDX, Sep 13, 2018.
  1. Sep 13, 2018 at 7:30 AM
    EatsInPDX
    EatsInPDX [OP] Well-Known Member
    SOLD!
    (4) 17" Toyota Tacoma 2017 2018 TRD Off-Road Premium / Trail OEM wheels and tires
    -Rims are in perfect condition. No scratches, curbs, dents, etc.
    -Tires are BRIDGESTONE DUELER H/T 684 TIRES 265 70 17 P265/70R17 with only 1500 miles on them. No patches.
    -TPMS are not included but wheels are mounted and balanced with standard valves from Les Schwab.
    -Bolt pattern 6x139, 6x5.5
    -Wheels are 17" x 7.5"
    -Offset 15 mm
    -Fits all Tacoma, FJ Cruiser, GX470, GX460, 4Runner
    -Also Fits first gen Tundra and Sequoia.
  2. Sep 13, 2018 at 7:57 AM
    busy13b
    busy13b Well-Known Member
    Omaha, NE
    2005 Speedway Blue TDR Sport Access Cab
    What is your location?
  3. Sep 13, 2018 at 8:12 AM
    EatsInPDX
    Portland, OR
  4. Sep 13, 2018 at 3:26 PM
    DrRoboto
    DrRoboto Well-Known Member
    David
    Salt Lake City, UT
    <s>2017 AC Off-Road</s>
    GoFastCamper. OME 886. Medium Dakars. SSO slimline bumper + Warn VR10-S. OGE dual battery system. Mobtown skids.
    Is the width 7.5 or 8 inches on these wheels? Also I think the offset is 5 mm. If I'm wrong please let me know because I'm about to pull the trigger on a set of these same wheels here in Utah.
  5. Sep 13, 2018 at 3:49 PM
    busy13b
    Omaha, NE
    I've got a set on my Tacoma (they look AMAZING, in my opinion, and should have been a factory option).
    The wheel width is 7.5in and the offset is +15. Perfect stock fit, no fuss, no hassle.
  6. Sep 13, 2018 at 3:50 PM
    busy13b
    Omaha, NE
    Here is a pic:
    mc_advrider and DrRoboto like this.
  7. Sep 13, 2018 at 7:04 PM
    DrRoboto
    David
    Salt Lake City, UT
    Offset or inset? I think the stock wheels are typically inset. What’s your tire width and how much does it stick outside the fender?
  8. Sep 13, 2018 at 8:01 PM
    busy13b
    Omaha, NE
    Wheel spacing specs are always stated as offset (the wheel offset is measured in millimeters and results in a positive, negative, or zero offset from the wheel hub). Yes, depending on what a wheel offset is, a wheel can be inset from the fender line. But that's not really the case here.
    The wheels here are the exact same specs as the stock 17" TRD Sport package wheels. I am running a stock sized tire for an '05 Tacoma TRD Sport (265/65 R17) and the wheel faces sit almost dead on flush with the fender flares.
    DrRoboto[QUOTED] likes this.
