4.5 backspaci.g plus spidertrax ok?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Twiostaco, Jan 19, 2012.
  1. Jan 19, 2012 at 3:00 PM
    Twiostaco
    Twiostaco [OP] Well-Known Member
    Austin
    Utah
    08 White DC TRD Sport
    5100's front set to .85 w/eibach springs, 5100 rear w/toytec 2"AAL, Light Race UCA, 17" Black Rhino Ocotillo wheels, 265/70/17 KO2's, K&N drop in filter, Grill Craft front mesh, one piece driveshaft (vibes gone) rear diff breather mod, BHLM, Fog anytime, 886 reverse bulbs.
    I have 265 on 4.5 -12 offset wheels I would love a wider more aggressive stance. Was thinkimgjust about 1.25 " spidertrax....Is that gonna put to much strain on my truck or is it ok? If you've done it and have pix please post!!!
  2. Jan 24, 2012 at 9:37 PM
    Twiostaco
    Austin
    Utah
    Anyone?
  3. Jan 25, 2012 at 6:02 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    It's going to push the wheels too far out, increasing your turning arc, and leading to rubbing on the outside of the tire when turning. We have a couple of members on here who have tried it and could barely get out of their driveways.
    And for future reference, we have a wheels and tires section. Thats why it took 5 days for a response because the wheel and tire folks usually hang out in the wheels and tires section :thumbsup:
  4. Jan 25, 2012 at 9:52 AM
    Twiostaco
    Austin
    Utah
    So do you know if they were running 285's?? With my 265s I figured it would make them stick out about as far as 285s. My tires are almost flush with my fenders
  5. Jan 25, 2012 at 10:05 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Width difference between a 265 and 285 is 20mm, which is about 3/4 of an inch, so your going quite a bit further than 285's... with the backspace on your wheels, you can afford to get 285's.
  6. Jan 25, 2012 at 10:44 AM
    TexasTacoma37
    Chadderkdawg's right, and only half of that width difference will be seen on the outside of the tire. So 285's only stick out 10mm further than 265's.
  7. Jan 25, 2012 at 12:59 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    me :wave:
    I had 285's though. I took a angle grinder to my fender wells and cut all kinds of shit out and it still rubbed. I took them off after a couple days bc I couldnt turn without hearing the tires rubbing all over the cab mounts, front bumper, who knows what else. I had a 3" lift as well.
