4 & 5 inch lift MAX TIRES
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Misterfillmore, Aug 17, 2017.
  1. Aug 17, 2017 at 9:08 PM
    Misterfillmore
    Misterfillmore [OP] Member
    If I get a 4 or 5 inch lift. What's the max tire size I can fit without trimming?
    The wheel size is 16.
  2. Aug 17, 2017 at 9:11 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Do you already have an lift in mind? Are you 2wd or 4wd?
    With these types of threads, it's truly impossible to say what will and won't rub. There are too many variables between type of suspension, alignment, wheel specs, and the tire itself.
    Midknight likes this.
  3. Aug 17, 2017 at 9:23 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    265/70/17 Or 265/75/16
    pcledrew likes this.
  4. Aug 17, 2017 at 9:23 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    35's cause no one makes bigger tires in a 16" wheel.
    Well, there are some, but Not a lot of options.
    erok81 likes this.
  5. Aug 17, 2017 at 10:29 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    It's not just a lift, what wheels are you using, what is the offset or backspacing, how wide are the wheels etc.
    You're asking a question that is not really possible to answer without more information. You would probably still have to cut with 33's.
  6. Aug 18, 2017 at 1:12 AM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    4 or 5 inch lift requires a bracket drop and IIRC none of those lifts can run anything smaller than a 17 inch rim
  7. Aug 18, 2017 at 4:17 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    4 or 5 inches of lift on a 4x4 requires a DB lift like already mentioned and once you get over 3 inches (if you go with a suspension lift), you start running into problems with your cv axle angles, which is why drop bracket is required. However, if you have a prerunner (6lug 2wd) you can get maxtrac spindles which give you 4 inches of lift, then you can swap out coils/strut assemblies up front to gain more height without having to replace UCAs
