4.56 gears with 265/75r16
Discussion in '4 Cylinder' started by GDT, Sep 8, 2017.
  1. Sep 8, 2017 at 5:00 AM
    GDT
    GDT [OP] Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    Anybody regeared to 4.56, with 265/75r16 (or similar 32" tire)? Interested in hearing your feedback. Did it feel overgeared on the highway? Yes, I've used the gear calculators, but I'm interested in hearing real world feedback from those that have run these gears with 32" tires
    TacoHilux likes this.
  2. Sep 9, 2017 at 5:10 AM
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    Are you manual or automatic?
  3. Sep 9, 2017 at 6:28 AM
    GDT
    Manual
  4. Sep 9, 2017 at 6:29 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Important question! He's got a base 2.7L 5 speed in his signature, so he's coming from 4.10 gears. I'd say 4.56 would be about right.
    My only experience is with the old truck, which had a 5 speed and 22R-E. When I went to 33" tires I regeared to 5.29 and that was really low but nice in the mountains. But top speed was 70 MPH. The right ratio was 4.88 for them, so for a 32" tire 4.56 would be a good choice IMO.
    BTW, in the old trucks Toyota used 4.56 with 31" tires and stick shifts in the V6 trucks and 4.88 with automatics and V6, also with 31" tires.
    RedRed likes this.
  5. Sep 9, 2017 at 8:43 AM
    BDL5589
    NE Georgia
    '14 MGM 4WD RC
    Yep, the manuals have a lower fifth gear vs automatics is why I asked, so automatics can get away with lower gears.
    I'd say 4.56s would be fine, only about 5% lower than stock gears with stock tires.
    Personally, I always go lower than needed though as to me, even stock trucks are geared too high. I'd personally do 4.88s, gears aren't cheap and they'll be more noticeable than 4.56s.
    DaveInDenver likes this.
  6. Sep 13, 2017 at 7:12 PM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    I'll put it this way I've got 4.88s in my 4cyl 5spd and I run 35s. It's just about perfect. When I went to 265s years ago it feels like there was little to no difference over the 245 series tires. It wasn't until I added plate bumpers it felt sluggish
    austin2009 and TACOVRD like this.
  7. Sep 22, 2017 at 12:50 PM
    GDT
    Hey guys, thanks for the feedback. I also think that first (and reverse) is geared a little high stock. I don't do any hardcore wheeling, but spend a lot of time running on steep rocky forest roads, and my truck keeps getting heavier, with a pretty heavy utility cap w/ toolbox on the back. There have been times when I have really wished for a 2-low option to get up a really steep incline when loaded down. And here in wv, even the highways are steep. I think I will eventually regear, probably to 4.56, down the road. I'd be concerned about Rpms being too high on the interstate with 4.88s, but I'll consider them when the time comes. I may also consider a r156f swap, when their junkyard prices hopefully come down in a couple years. It has a lower 1st and 2nd gear.
    Nomad_Pilot likes this.
  8. Sep 22, 2017 at 12:56 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    At the point you're worried about 4:88s being too high at highway speeds, just go with a bigger tire!
    I went with 4:56 on a 32" and it was nice but at highway speed the RPMs sat in the power band. Nice for pulling but kills mileage. My experience isnt really comparable though because I'm V6 auto.
    If you're a 4 cylinder and driving a lot in the mountains, I'd probably go 4:88 with a 33". Just for the extra pull with weight.
    TACOVRD likes this.
  9. Sep 22, 2017 at 1:34 PM
    GDT
    I'm building my truck for function and utility, and for my purposes, i think a 33" is overkill. 285 would kill my mileage and I don't want to deal with rubbing. I might consider 4.88 w/ a 255/85 if they were available in anything but an e-load. They're all too heavy. For now, I think a c-load 265/75 has been a good compromise, but even that was a very noticeable change from p-rated 245/75 when at highway speeds, both in power and mpg.
  10. Sep 22, 2017 at 3:27 PM
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    My truck (2.7/auto) with 4.88s and 285/75-16s runs about 2800 RPMs at 75-80 MPH on the highway. I think it is just fine. Don't have any idea about MPGs cause I don't care. Love my set-up, but next time, I'll probably get 255/85-16s.
    '14RC, bigfella13 and tacoburrito like this.
  11. Sep 22, 2017 at 5:04 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    That's about where the manual 2.7 runs at 80 with stock gears/tires.
  12. Sep 22, 2017 at 5:08 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    4.10s should be fine with a 2nd gen 4cyl manual trans. 265/75r16 are 31.5" tires, and 1 size over stock. You're gonna be over geared highway with 4.56s, and they shouldn't really be needed. For the money it's gonna cost, not worth it IMO.
    hunter357mag likes this.
  13. Sep 22, 2017 at 5:14 PM
    GDT
    Yes, 4.10s are "fine", and I know how big the tires are, I rounded up. Just like 285s aren't really 33s. There's definitely something lacking when you're working the truck in the hills sometimes though. You may be right about the cost/benefit though.
  14. Sep 23, 2017 at 7:50 AM
    smmarine
    Melbourne FL
    I have 4.56s in my 1st gen on 31s and it's overgeared on the highway. I'm at 3,000rpm at 80mph and my gas mileage took a hit. It would be even worse with the manual trans
  15. Sep 24, 2017 at 5:19 PM
    tacoburrito
    tacoburrito Well-Known Member
    boston
    2013 regular cab
    5100s. eibach coils. 285/75/16 km2s. leer cap
    maybe just do the LCE headers?
  16. Sep 24, 2017 at 6:52 PM
    GDT
    Already did it. Definitely made a noticeable, but not dramatic, improvement in low end torque. Able to hold a gear better when climbing on the highway. But, just thinking about other improvements that I could make. I think the gearing is a little off for where I live and how I use it
  17. Sep 25, 2017 at 1:06 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    What elevation do you live at and do most of your driving? I think that makes a big difference. When I was looking at regearing, a lot of guys said 4.56 with 33's worked well with the 2.7 but they were closer to sea level. I'm at ~5000ft and only go up from there when I go out of town. 4.88 and 33 I felt were barely enough gear up hills on the HWY. IMO, I think that 4.56 will probably be a good set up with 265's but it's just something else to take into consideration.
    Hartford likes this.
  18. Sep 25, 2017 at 5:34 PM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Did you regear before or after you installed your turbo setup? Now that your turbo setup is in do you feel that the 4.88s are overkill?
  19. Sep 25, 2017 at 8:10 PM
    boostedka
    James
    NM
    I regeared before. Now with the turbo I would probably be good with 4.56's to lower the RPMs a bit On the hwy and would still have plenty of low end off-road. I've actually considered switching to 456 but I can't justify the cost. Maybe if I find a deal some day...
  20. Oct 1, 2017 at 4:18 AM
    TYetti
    Mat
    You guys are nuts. The thousands of $ spent regearing fòr a basically stock tire size. Could be well spent on other mods. If you want 2lo do a fj tcase swap and twin stick it. I know a lot of this is all personal preference but I've pushed my truck well over 9000ft with no issues. I was in 4lo the whole time but that's what you get when you buy a 4cyl 4lo is your best friend. With 4.88s and 35s my 4cyl 5spd sits at 2700 rpm at 70 I don't often drive faster than that, and I do the 4-3 dance a lot on the mountain highways here because they are punishing. I would also say the weight difference on a e tire to a c tire is negligible. I've only run e cause I'm a bfg guy and honestly the rocks and roots here shred lesser tires.
