4.56 or 4.10
Discussion in 'Performance and Tuning' started by johnw, Jan 1, 2012.
what gear ratio should i get?
Poll closed Jan 31, 2012.
  1. 4.10
    47.8%
  2. 4.56
    52.2%
  1. Jan 1, 2012 at 6:54 PM
    #41
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    LoL I am in the PNW and SW area but I do occasionally make a run out to your neck of the swamp for some work.
  2. Jan 1, 2012 at 6:56 PM
    #42
    jandrews
    '09 FourDubDee TRD OR
    I hear he's an okay guy.
  3. Jan 16, 2012 at 7:03 AM
    #43
    johnw
    johnw [OP] Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    I went with 4.56 just letting yall know
  4. Jan 24, 2012 at 5:21 PM
    #44
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
    Let us know how it turns out. How much were your gears? And who from? Install?
  5. Jan 24, 2012 at 5:22 PM
    #45
    johnw
    john
    orlando florida
    complete 3rd member from east coast gear supply. was around 1600
  6. Jan 24, 2012 at 5:23 PM
    #46
    Manwithoutaplan
    ID
    4.56 your going to get more bite when offroadin g
  7. Jan 26, 2012 at 7:38 AM
    #47
    Trapper6speed
    Stock
    Was that after your core charge?
  8. Jan 26, 2012 at 7:44 AM
    #48
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your actually regular travel with a spindle lift. The 5100's arent extended travel shocks.
    FWIW, 4.10's will get you slighty over geard than stock. 4.56 will get you a little more over geard than that.
    Also, having "power to turn the tires" may sound good, and look good on paper, but the engine needs the leverage to overcome the increased rotational mass, as well as the now lower overall gear ratio you now have with taller tires. As jandrews said, gears are more important than all out engine power when turing larger tires.
  9. Jan 26, 2012 at 8:13 AM
    #49
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    You guys talk about regearing like you have a choice in the matter and you can choose any gear ratio you want. Unless things have changed very recently there are only two choices of gears that are made for second gen tacomas, 4.56 and 4.88. Which you choose depends on what you start with. For automatics with the stock 3.73s you can only go to 4:56 unless you buy new carriers in the form of manual truck carriers or ARBs. And for stock 4.91s in the manual trucks you are stuck with 4.88 unless you do a carrier change.
  10. Jan 26, 2012 at 8:18 AM
    #50
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    4.10's from the 2.7 fit.
  11. Jan 26, 2012 at 8:19 AM
    #51
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Interesting
  12. Jan 26, 2012 at 8:20 AM
    #52
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :cool:
  13. Jan 26, 2012 at 8:22 AM
    #53
    PreRunnerSeth
    Apex, NC
    Which one do they fit? Obviously there are carrier differences. It cant fit both.
  14. Jan 26, 2012 at 8:22 AM
    #54
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They fit the SR5 and TRD SPort.
  15. Jan 26, 2012 at 8:24 AM
    #55
    PreRunnerSeth
    Apex, NC
    The carrier difference is between auto and manual and which original gears you have depending on which transmission you have. It has nothing to do with trim level.
  16. Jan 26, 2012 at 8:25 AM
    #56
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah. Well, Im guessing the auto then, as thats what my buddy has, and the gears he swapped in.
  17. Jan 26, 2012 at 2:40 PM
    #57
    johnw
    john
    orlando florida
    i have extended travel icon coilovers since november. im actually mid travel
  18. Jan 26, 2012 at 3:35 PM
    #58
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah.....Your specs in your profile say 5100's
  19. Jan 26, 2012 at 3:36 PM
    #59
    johnw
    john
    orlando florida
    yeah i havent touched that in a while i also have TC lowers
  20. Jan 26, 2012 at 5:12 PM
    #60
    commando
    commando Well-Known Member
    Brandon
    Oregon
    2006 SR5 Double Cab 4X4
    3" spacer lift
    Yup, I am running 33's and I am also getting 4:10's (from a 2.7) installed next week. A front swap, and a rear re-build, so I can keep my factory mechLSD in the back.
    Can't wait.:D
