4.56 or 4.88?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DirtyMyrtle, Jun 8, 2015.
  1. Jun 8, 2015 at 12:49 PM
    DirtyMyrtle
    DirtyMyrtle [OP] Active Member
    Jordan
    Myrtle Beach
    12 Pro Comp Taco
    6in Pro Comp es9000 rear shocks Bilstein 5100 adj 37x13.50x22 Toyo M/T 22" Fuel Full Blown Thule MOAB basket Yakima Racks
    Yes I am a 2wd tacoma owner.. that is currently running 37s.
    If you're going to hate on it, i don't really care.
    I need to know if 4.88 is going to be overkill. I see all these guys are saying that 4.88 is overkill for 35s, but will it be for what I'm running? I'd really love to get the stock ratio feeling back.
    And another question of mine is.. when ordering the gears it's going to be for 7.5" correct? They are for a 2012 tacoma TRD sport.
    https://www.tacomaworld.com/media/xxl-taco.458750/
  2. Jun 8, 2015 at 2:51 PM
    Pigpen
    Dan
    Northwest Montana
    From what I've read, 4.88 seems to be the ticket. You'll have good torque.
  3. Jun 8, 2015 at 3:53 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    4.88 all the way. Maybe even 5.29 if you do a bunch of slow city.
    For non e locker 8.4 ring gear
  4. Jun 8, 2015 at 4:01 PM
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    Here is a gear ratio calculator: http://grimmjeeper.com/gears.html If you know your transmission gear ratios, you can plug them, diff ratio, and tire size into the calculator and figure out your rpm in different gears at different speeds.
  5. Jun 8, 2015 at 4:35 PM
    DirtyMyrtle
    Jordan
    Myrtle Beach
    12 Pro Comp Taco
    Thanks for the help guys!
  6. Jun 8, 2015 at 6:54 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I have 4.88's with 37's and it is exactly like stock. The speedo is even accurate within a mph or two.
    DistortedAxis likes this.
  7. Jun 8, 2015 at 6:55 PM
    DirtyMyrtle
    Jordan
    Myrtle Beach
    12 Pro Comp Taco
    exactly what I was looking for. that makes my decision right there.
  8. Jun 8, 2015 at 6:56 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    4.88 with 35s and I like it. It's not overkill.
    Speedo is way off though.
