4.56 or 4.88
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ten Eight Rider, Mar 30, 2020.
  1. Apr 2, 2020 at 6:04 PM
    #41
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I cruise at 2600rpm all the time. It's awesome. It puts the motor in a much better area of the torque curve
    Monkeybutt2000, Sna and EatSleepTacos like this.
  2. Apr 2, 2020 at 6:13 PM
    #42
    MattiveAmerican
    MattiveAmerican Well-Known Member
    2006 White ACLB
    BuiLt 4 OveRLanDiNg
    I have a very similar set up to what you’re going for. I have 285/75R17’s, front bumper with winch, sliders, full skids, all 1/4” except the fuel tank skid, soft top with bed rack, RTT, and my bed is loaded enough for the trips I take that HD Dakar leaf packs squat under the load. I have 4.56’s and I have never once felt like I needed more gearing, even when I towed a Jeep behind the truck which was probably over the towing capacity of the truck. Sometimes I even wish I had gone with 4.30’s, I would strongly suggest you go 4.56 instead of 4.88
    asudevil and MattCowsmasher like this.
  3. Apr 2, 2020 at 6:29 PM
    #43
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you auto or manual?
  4. Apr 2, 2020 at 6:44 PM
    #44
    MattiveAmerican
    2006 White ACLB
    BuiLt 4 OveRLanDiNg
    Auto
    EatSleepTacos[QUOTED] likes this.
  5. Apr 2, 2020 at 7:09 PM
    #45
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    I’ll be going with 4.56 gears with a very similar set up (33’s, armor, roof rack, camping gear, 6MT, etc) when I re-gear. I have no intention of going to bigger tires and know I’ll be slightly over geared. RPM at 70mph should be 2700-2900ish and I’m ok with that since I don’t plan on driving faster. The difference between 4.56 and 4.30 gears is approximately 150rpm at 70mph.
    The below quote is from another gearing thread and I agree.
  6. Apr 2, 2020 at 7:23 PM
    #46
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I would like to know why is it that most of this discussion about RPM's is for highway speeds with a few comments about towing? The reason I ask and this might apply to tire size choice as well. When I think about larger tires and lower gears it is how do I improve off road performance and understanding what I will give up in Hwy. performance. So for those of you that run 33's or 35's what gear ratio's did you choose and where do you use your truck? How does it perform off road? Then what compromise do you except or see in on Hwy. performance.
  7. Apr 3, 2020 at 6:34 AM
    #47
    Ten Eight Rider
    Ten Eight Rider [OP] Well-Known Member
    Central California
    2006 White Tacoma SR5 DCLB 4x4 V6
    Fox 2.5" Coilovers, Fox 2.0 Rear Remote Reservoir DSC, SPC Light Racing UCA, Wheelers Progressive 1.5" AAL, Wheelers Bump Stops, Wheelers Braided Brake Lines, Fuel Revolver 16x8, Toyo AT 265/75/16, ECGS Bushing, Energy Suspension Steering rack bushings/sway bar bushings, All-Pro Sway Bar Links, At the Helm Fabrication bumpers (front and rear), Cali-Raised LED lights, Leer Cap
    I realize it probably sounds like I want the best of both worlds, BUT I have to drive 60-100 miles to get to the places I want to off road and I would like the drive to be good. Once I get to the off road destinations, I don't plan to "rock crawl" but I do plan to drive in some areas where I will likely need 4x4 low. I also just like the visual appearance of the 33.4" tires (California thing I guess! LOL)
  8. Apr 3, 2020 at 6:42 AM
    #48
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    I drive @ 130 miles a day on mostly 60 mph Hwy's, do quite a bit of offroad but no rock crawling, pull a trailer a bit, I like my 456s
    Lifted blue limo and 01 dhrracer like this.
  9. Apr 3, 2020 at 6:47 AM
    #49
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Fuck me, I wish I only had to drive 100 miles to go wheeling. I'm jealous! Minimum 200 miles to get anywhere decent, usually 300-400.
    01 dhrracer and Sna like this.
  10. Apr 3, 2020 at 6:55 AM
    #50
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    @ME OFF Rd an interesting thread you might want to read through
    01 dhrracer likes this.
  11. Apr 5, 2020 at 10:14 PM
    #51
    5150Bronco
    5150Bronco Well-Known Member
    Bay Area, Ca.
    2013 Tacoma 4x4 Access Cab-Special Order.
    I think 456 will be the sweet spot.
    I just finished doing research for my build. 488 if you will go 35’s.
    you got to calculate all the weight that you put on the vehicle as well.
  12. Apr 6, 2020 at 4:35 AM
    #52
    ME OFF Rd
    ME OFF Rd Well-Known Member
    Jim
    Maine
    2013 TRD Off Road Edition
    - Digital Fit WeatherTechs - OME 885x Coils w/ Bilstein 5100's @ 0" - Rear Bilstein 5100's with ToyTec 2" AAL
    Are you happy with your 4.88s with 35s or do you wish that you would have gone 4.56s?
  13. Apr 19, 2020 at 3:46 PM
    #53
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    Only want to do this once.
    09 4.0 Auto 4x4
    Double cab long bed
    Front bumper with winch
    Sliders
    High clearance rear bumper with swing out and spare
    Prinsu rack
    Bed cage with RTT
    270 degree awning
    King 2.0 coil overs
    King 12” rear shocks
    4” Deavers (+300lb) springs
    33” Discoverer STT Max
    I’ve been wanting to regear for a while now. I try to use my truck only on the weekends and daily my other one. I am looking to go to 34s and possibly 35s if I can manage the clearance (not looking to cut fenders and bedsides). Would love to go with ARB air lockers but I keep hearing of leaky seals and I don’t feel like swapping them back in and out over an over
    I’m thinking of just doing the full clam shell and third with 4.88. After core charges and all come back should run 1800-1900
    Sna likes this.
  14. Apr 19, 2020 at 5:05 PM
    #54
    Sna
    Alberta
    Sounds like 4.88’s are the right choice.....Buy once, cry once so get lockers at the same time, all from ECGS.
  15. Apr 19, 2020 at 7:17 PM
    #55
    4x4Taco09
    Dane
    Louisiana
    I wanted to go the locker route. But I’m honestly not sure when I would ever use them. I know it’s better to have it and not need it, I haven’t used my winch either. But that’s another 1600 easily. Have they fixed the leaky ARB deal issue yet?
  16. Apr 19, 2020 at 7:29 PM
    #56
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Double cab longbed with 35’s and a bunch of stuff on it and I opted for 4.56 after talking with the nitrogear folks. Only have about 100 miles on it so far but I can definitely feel that it got some power back.
    4x4Taco09 likes this.
  17. Apr 19, 2020 at 8:28 PM
    #57
    Sna
    Alberta
    I don't need the lockers right now either but I don't like doing things twice. I'd like to get off road more and lockers are great to have if/when you need them.
    I believe ARB has fixed the issues they had with bad seals.
    Satisifed or regret not going to 4.88's?
  18. Apr 19, 2020 at 9:15 PM
    #58
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    So far totally satisfied.
    Sna[QUOTED] likes this.
  19. Apr 19, 2020 at 9:21 PM
    #59
    5150Bronco
    Bay Area, Ca.
    Just did 456 and rear ARB. Might as well put locker in if you are re-gearing and you do a good amount of wheelin...
    4x4Taco09 and Sna like this.
  20. Apr 20, 2020 at 4:22 AM
    #60
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    If it ain't much trouble, eng. & trans info. would go good with the gear ratio. The 4 cyl. with appx 85 hp less than the 6 cyl. will need lower gears than the 6 cyl. & the auto trans., being geared higher than the MT will also use lower gears for the same results. Your 4.0 with an extra 85 hp more plus a MT trans. that's geared lower from the factory than auto. My little 4 cyl. auto. can't pull as high of rear gear as your Taco.
