4.56 rear axle carrier with stock locker
Discussion in '1st Gen. Tacomas (1995-2004)' started by Silveryota01, Feb 8, 2016.
  1. Feb 8, 2016 at 5:28 PM
    Silveryota01
    Silveryota01 [OP] Well-Known Member
    Logan
    Conway SC
    2020 Silver Sky Metallic TRD 4x4 OR
  2. Feb 8, 2016 at 5:31 PM
    Silveryota01
    Logan
    Conway SC
    Trying to regear on the cheap and still use my locker
  3. Feb 8, 2016 at 5:35 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Doesn't look like it's compatible, the 8" e-locker 3rd member looks like this:
    The one you posted looks like an 8.4", non-TRD 3rd member. You're better off regearing the one you got.
    Silveryota01[OP] likes this.
  4. Feb 8, 2016 at 6:37 PM
    Silveryota01
    Logan
    Conway SC
    Thanks brother do you think 4.56 is overkill for 33's
  5. Feb 8, 2016 at 9:10 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Should be perfect for 33's. I run 4.56 gears with 255/85r16's, which is about the same as the stock gear ratio. Depends on if you're automatic or manual also, the manual is slightly lower gearing.
    I will say if you plan on going bigger than 33's, you might consider 4.88 gears, or if you just want the extra power.
