4.56 vs. 4.11 MPG
Discussion in '1st Gen. Tacomas (1995-2004)' started by ChiefThickums, Jul 1, 2010.
  1. Jul 1, 2010 at 10:32 AM
    ChiefThickums
    ChiefThickums [OP] Scrub
    Tyson
    San Luis Obispo
    Bad Ass Gen I
    6 in' Trailmaster, 33x12.50's, TRD supercharged, flowmaster, K&N. Used abused and put away wet.
    I finally made the switch from 4.11 to 4.56 and here is my findings...
    I have a 3.4l 5spd 99 taco with a 6in lift, supercharged, flo master, K&N, intake. and run premium gas. Most importantly I run 33X12.50's which put me on the edge of 4.11 gearing or 4.56 gearing.. I pulled the trigger and made the switch and here is the mpg differance...
    with 4.11 gearing I got:
    Between 210-230 a tank
    Between 13 - 14mpg
    With 4.56 gearing I get:
    Between 230 - 250 a tank
    Between 14 - 15.5mpg
    I've never seen anyone post a after gear change results thread , I mainly saw speculation of what you "should and probably will get" instead of numbers. so here are the acctual numbers that i got from my 4.56 cut over. Not a huge diffence but it is some improvement. Hopefully it helps in some people that are on the edge desiding :cool:
    *Note. The speedo on my truck is off by +.05 per mile after the change to 4.56 and 33X12.50's. So in a 10mile block my odometer will read 10.5. So the gas mileage is even better the qouted. accounting for the difference I should get about 262 miles a tank and 16mpg. I just gave real numbers of my trucks current condition with out the variance of the speedo/ecu.
  2. Jul 1, 2010 at 10:48 AM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Wait... You got better fuel economy? I had always thought switching to 4.56 would give move your power lower at the expense of fuel.
  3. Jul 1, 2010 at 10:49 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    good info
  4. Jul 1, 2010 at 10:51 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    it's puts you back to factory specs, yes you'll be at a higher rpm but it is less strain on the motor....
  5. Jul 1, 2010 at 10:52 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Depends on your driving patterns and habits. Lower gears (higher number) make take-offs easier, bumps city/low speed mpg. While higher gears should help bump highway milage.
  6. Jul 1, 2010 at 10:53 AM
    PLC721
    Patrick
    Chandler, Az
    precisley
  7. Jul 1, 2010 at 11:07 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Nifty. Now I just wish i could throw 4.56 gearing into my truck and then have a super-high top gear. That would rule.
  8. Jul 1, 2010 at 11:38 AM
    ChiefThickums
    Tyson
    San Luis Obispo
    Bad Ass Gen I
    Yeah Better mileage, honestly i was shocked to. I figured higher RPMs would result in lower gas mileage, especially on the hwy only makes sense right... but no like they said, the way it worked out the motor is working less and i'm getting and brings you back to stock mpg. the result even with a mix of 80% hwy 20% street driving (roughly) I'm getting 1 - 1.5 Better gas mileage.
  9. Jul 1, 2010 at 5:05 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    nice, good information. just curious to how much it costs for some 4.56 gears, i know i would definitly benefit from a set.
  10. Jul 1, 2010 at 5:07 PM
    PLC721
    Patrick
    Chandler, Az
    4wheel parts is having a sale right now on install
  11. Jul 1, 2010 at 11:47 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Hate to pop ya'll joy bubble there, but how does the ECU "know" that you've changed gears? Or tire size for that matter. The odometer is fly by wire, meaning there isn't a rotating cable any longer like the old days. IIRC the sensor that reports to the odometer is at the output shaft of the tranny. It reports driveshaft rotations. Far as the odo is concerned, your still running stock gears and stock tires, yet you are relying on what the odo is telling you.
  12. Jul 2, 2010 at 12:34 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    ^yeah wut he said....
    toytaco112 likes this.
  13. Jul 2, 2010 at 2:29 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    If you look up on TTORA about Gearing and MPG. Most guys will tell you that going from 4.10 to 4.56 while running 33x12.5 will Improve you gas mileage.
  14. Jul 2, 2010 at 8:56 AM
    ChiefThickums
    Tyson
    San Luis Obispo
    Bad Ass Gen I
    Digiratus,
    You are right my speedo/ECU is off I already tested it against the California highway patrol White Mile Dashes that are put on the road for air craft ticketing. The difference isn't much I think it was .95 in a 1 mile, I hit the mile marker on my speedo just before the pyshical marker. but that means my truck thinks I'm going further then i really am and that means i'm getting Better gas mileage then qouted not worse. I'll get real numbers today while i'm driving around and post them later.
  15. Jul 2, 2010 at 9:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    When I re geared my Dodge from 3.73's to 4.10's, I went from 12 to 14 mpg, and a good boost in performance. I personally feel that if you change tire size by more than 10%, you should re gear accordingly.
  16. Jul 2, 2010 at 10:26 AM
    PLC721
    Patrick
    Chandler, Az
    i'm seriously considering it since you brought that to my attention at the meet
  17. Jul 2, 2010 at 10:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    IMHO, If anyone goes to 33's on the Tacoma, a re gear is in order.
  18. Jul 2, 2010 at 10:41 AM
    PLC721
    Patrick
    Chandler, Az
    mine are 35's
  19. Jul 2, 2010 at 10:46 AM
    81shark
    81shark Well-Known Member
    did you account for the gear change in your mileage calcs? ie you mileage reported on your odometer isn't the same as it once was unless you recalibrated it.
    for me, in my car, i went from 2.87 to 3.55 which is like 20% change, and i saw gas mileage drop about the same %
  20. Jul 2, 2010 at 2:50 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    Definitely in a First Gen, Going up the Cajon Pass with 33's bed loaded with gear for the weekend is pretty tough for me.
