4.56 vs 4.88 Gears
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Manwithoutaplan, Jan 10, 2011.
Thread Status:
Not open for further replies.
  1. Jan 10, 2011 at 2:10 PM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    I Debating between whether to get 4.56 gears or 4.88 gears. IF people can give me the pros and con on each that would appreciated.
  2. Jan 10, 2011 at 2:11 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    4.56 would bring power back and you'll have lower highway rpm's than 4.88's
  3. Jan 10, 2011 at 2:13 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I was considering over gearing to 4.88s until Chris4x4 mentioned something that I had overlooked. With gears that steep, the pinion is going to be tiny and the ring teeth are going to be necessarily thin. Thinner gears generally mean less strength.
    Something to consider if you wheel hard.
  4. Jan 10, 2011 at 2:18 PM
    Manwithoutaplan
    ID
    IS the cost of both pretty much the same ??
  5. Jan 10, 2011 at 2:19 PM
    Manwithoutaplan
    ID
    Regeared and if so what are you at?
  6. Jan 10, 2011 at 2:21 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah when i re-gear I'm going with 4.56 I don't want to be at 3500rpms at 75 with the 4.88
  7. Jan 10, 2011 at 2:28 PM
    cameronlane
    cameronlane Well-Known Member
    cameron
    Anywhere but there
    2014 Dbl Cab TRD OR 4x4
    True the teeth are smaller, but there are also more contact points and you really do not loose strength.
    When talking about re-gear, you have to look at your purpose for doing so. If you are staying on the street you might want to have 4.56 for your 35" tires. If you are going to be doing any kind of wheeling you may strongly want to consider 4.88 to give you more slow control over obstacles.
  8. Jan 10, 2011 at 2:33 PM
    Manwithoutaplan
    ID
    IF you talking about 100% i am wheeling about 20% of that. SO should i consider 4.56 gears?
  9. Jan 10, 2011 at 2:43 PM
    mjp2
    NJ
    4.56s will serve you very well with 35" tires.
  10. Jan 10, 2011 at 2:47 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Overall, 4.56 vs. 4.88 is a pretty small difference. And you didn't tell us what size tires you're running.
  11. Jan 10, 2011 at 3:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Correct about the contact points. The 4.56 ring gears has 41 teeth, while the 4.88 has 39. More importantly, The 4.88 uses an 8 tooth pinion, vs. the 9 tooth pinion for the 4.56. Therefor, the 4.56 is the stronger of the 2, as there is more engauged surface area, and (by haveing a little larger pinion gear), less chance for damage due to shock loading of the diff.
  12. Jan 10, 2011 at 4:33 PM
    Manwithoutaplan
    ID
    I have 315/70/17 which are pretty much 35 inch tires.
  13. Jan 10, 2011 at 4:36 PM
    Manwithoutaplan
    ID
  14. Jan 10, 2011 at 4:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  15. Jan 10, 2011 at 4:44 PM
    Manwithoutaplan
    ID
    so what is the reason in the east coast gear supply it say 4.56 thick? Does that mean the gear is casted from strong steel?
  16. Jan 10, 2011 at 5:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont understand.
  17. Jan 10, 2011 at 5:29 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    go 5.13
  18. Jan 10, 2011 at 6:16 PM
    Manwithoutaplan
    ID
    The 4.56 gears are available in a thick cut gear to allow you to retain your factory 3.73
  19. Jan 10, 2011 at 6:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok...This confuses the shit outta me. Why do you want to get 4.56 gears, if they are going to stay 3.73?? :confused::confused::confused::confused:
  20. Jan 10, 2011 at 6:22 PM
    boonduff
    boonduff Proud American
    Gordie
    Chandler, AZ
    2011 DC TRD OFFROAD
    Bone stock brand new
    They made the ring gear thicker so you wont have buy a new case when you swap to the lower gearset.
Thread Status:
