4.56 Yukons unused still in box
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Unbrakeable, Feb 18, 2013.
  1. Feb 18, 2013 at 9:13 PM
    Unbrakeable
    Unbrakeable [OP] Member
    I have a set of 4.56 yukons for the rear of a taco. Bought for a 4cyl but as far as I know all the gears used are the same. Asking 180 Obo.
  2. Feb 19, 2013 at 4:49 AM
    Snorkie
    Snorkie JEEP LYFE
    Jeep
    Rubicon
    Prius
    What diff are they for? 8" or 8.4"?
  3. Feb 20, 2013 at 9:16 AM
    Unbrakeable
    As far as I know all the tacoma diffs use the same gear sets so it would fit either.
    http://home.4x4wire.com/erik/diffs/
  4. Feb 20, 2013 at 9:20 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    dont think thats true. i think5 lug and prerunner/4x4 use different gears. and the diff is different from a trd and an open diff.
  5. Feb 21, 2013 at 4:30 AM
    Snorkie
    Snorkie JEEP LYFE
    Jeep
    Rubicon
    Prius
    That's a negative... 8" and 8.4" diffs are different.
  6. Feb 27, 2013 at 10:04 PM
    Unbrakeable
    What I have from Yukon is as follows. YG T8-456
  7. Feb 27, 2013 at 10:13 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    How may spline? 27 or 29?
  8. Feb 27, 2013 at 10:15 PM
    Unbrakeable
    From East Coast gear Supply's Chase Perry:
    The difference between 4cyl and V6 gears is .130. A v6 gear pinion head is .130 longer. Therefore you can run 4cyl gears in a elocker v6 diff by
    adding .130 to the factory shim for proper depth. A factory shim is .080
    so when running 4cyl gears the starting shim should be .210.
  9. Feb 27, 2013 at 10:18 PM
    Unbrakeable
  10. Feb 27, 2013 at 10:20 PM
    ColtsTRD
    Scott
    AZ
    Free bump anyway! GLWS!! This is a awesome deal! If they were 29 I'd buy them for sure!!!
