4.6i in Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by newtaco18, Dec 18, 2016.
How much more would you be willing to pay for a v8 in your Tacoma?
  1. $1,000
    24 vote(s)
    10.6%
  2. $2,000
    45 vote(s)
    19.9%
  3. $3,000
    71 vote(s)
    31.4%
  4. $5,000
    45 vote(s)
    19.9%
  5. $ 0
    41 vote(s)
    18.1%
  1. Dec 19, 2016 at 7:57 PM
    #121
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Yeah a regear would help a lot.
    4.88 or 4.56 would work perfect with 33s.
    My back up plan is waiting till they have a superchager or putting one on my 2010.
  2. Dec 19, 2016 at 8:15 PM
    #122
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Oh that's definitely confirmed. And likewise with Gen Deuce.
    shr133 likes this.
  3. Dec 19, 2016 at 8:18 PM
    #123
    shr133
    Muskego, WI
    2010 V6 Sport
    After you lift it, add tires, lights, bumpers and maybe a rack, mpg is going down no matter what, so a high torque engine is what is needed.
    At this point it takes X amount or power to accelerate and maintain speed and the more torque the better.
    And I bought a truck not a car, so when I need to tow, I need it to tow and I don't want to rev the crap out of it.
    Why not get a Tundra Because you can't off road or park with that huge beast or I would have one.
    The Tundra gets a kick a** engine, so why not one for the Tacoma???
    The Tacoma is a great truck it just needs an option for more torque, so bigger V6 or small V8 with more torque is not unreasonable.
    The 3.5 is great for stock and an overland build, most everyone else needs a bigger engine and MPG will be about the same.
  4. Dec 19, 2016 at 8:22 PM
    #124
    Construct
    Construct Well-Known Member
    What you're describing here isn't a lack of power. You're describing a throttle response that doesn't match your old expectations.
    If you're not going WOT, then you're already not using all of the power the truck has available to you. You don't need more power, you just need to press the pedal harder and let the engine and transmission do their thing. Under your definition, if we could reprogram the throttle response curve in the ECU to be steeper at partial throttle, you'd feel like the truck was somehow faster despite not actually having any more power on tap.
    This is why I asked above if anyone complaining about lack of power was actually going WOT, or if they were just complaining about a perceived lack of power due to the throttle pedal curves and higher-revving sound of the engine that many aren't yet used to.
    Nedrolls likes this.
  5. Dec 19, 2016 at 8:31 PM
    #125
    Construct
    Honest question: Why do you care? Revving the engine out is just fine. It's designed to handle the revs. There's nothing wrong with letting it spin at a higher RPM.
    The idea that a bigger engine with more power will magically produce the same MPG as the smaller, less powerful engine is pure fantasy. At minimum, if you're actually using any of that additional engine power then you're going to be burning more fuel by definition. But more importantly, the bigger engine will almost certainly be less efficient at cruising speeds. There is no free lunch to be had here.
    Scarab likes this.
  6. Dec 19, 2016 at 8:39 PM
    #126
    StreetTiresJay
    StreetTiresJay Well-Known Member
    Jay
    British Columbia Canada
    '16 Taco TRD Sport DBLcab Alpine White 6M
    Wife in passenger seat, not driver seat :)
    Actually had to Google what WOT is. Want familiar with the term. To answer that, yes I was pedal to the medal. Either way, doesn't matter. Love my truck, still want more power in the future
  7. Dec 19, 2016 at 9:24 PM
    #127
    shr133
    Muskego, WI
    2010 V6 Sport
    After I lift it and add 33s a bigger engine will drive much better and get close or the same MPG...
    A lager engine working less or a small engine working hard will use the same MPG.
    A bigger and heavier chevy silverado with a 5.3L or a 6.2 gets better MPG than our 3.5 so engine size doesn't matter.
    When the 4.0 came out it had class leading power.
    So did the tundra.
    I know they can have more power and at least the same MPG.
    Toyota is just being cheap. I sold Toyotas for 7 years so I know when they are not trying.
  8. Dec 19, 2016 at 10:54 PM
    #128
    Scarab
    Scarab Well-Known Member
    2017 White Tacoma TRD Pro
    So why don't you transplant a V8 into your Tacoma after you lift and put bigger tires on it. Then come back and let us know how that worked out for you? You say Toyota is being cheap? Do you think that if they offered the V8 option they would keep the price the same? Obviously they would charge a premium so they wouldn't lose any money. So how is that being cheap? They don't put a V8 in it because it would start creeping into the Tundra price point as well as other full sized trucks. Tacomas have built a niche for itself in the mid sized segment if you haven't noticed. You say you sold Toyotas so how is this a mystery to you?
  9. Dec 19, 2016 at 11:24 PM
    #129
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This is not a conspiracy or some unwillingness to respond to the market. The reality: CAFE 2025 standard will kill the midsize v8 pickup truck.
    Toyota (and others) have 8 years to get the fleet average to 54.5mpg. That is only one more generation of the Tacoma at best. There is no chance they will squander precious mpg average ratings on the Tacoma which has no actual need for it, and sells fine without it. Everything will go to small displacement mpg friendly designs, saving only the true work horses for the mpg hits to be subsidized by the rest of the product line, aka the Tundra.
    Hank Heel, Sharpish and shr133 like this.
  10. Dec 20, 2016 at 5:58 AM
    #130
    wxm8562
    wxm8562 Well-Known Member
    I haven't driven the automatic, but I don't feel the manual transmission truck lacks power at all. It gets 4.30 gear from the factory. I think it feels great. I never want for power in my '17 DCSB M/T.
  11. Dec 20, 2016 at 6:03 AM
    #131
    croixman
    croixman Well-Known Member
    Brian
    Illinois
    2014 D-Cab 4x4 TRD SR5
    I currently drive a 2016 chevy 5.3 and it's getting me 2 mpg worse than my 2014 4.0 Taco was getting. Driving the same route to work everyday. So I would guess a 2017 Taco 3.5 would be better. I think adding some juice to a v6 such as twin turbo's or something would be a better option then a v8 for the Taco. But that's simply my opinion. Has anyone tried a programmer or Dyno work on the current Taco v6 ? Would be interesting to see those results.
  12. Dec 20, 2016 at 6:41 AM
    #132
    Taco16LB
    Taco16LB Well-Known Member
    Hey Toyota ! Can you gear me now ?
    StreetTiresJay likes this.
  13. Dec 20, 2016 at 7:50 AM
    #133
    Construct
    No, that's not correct. A bigger engine will have higher parasitic losses and reduced efficiency at light loads. You spend 90-95% of your driving time at light loads, so any losses in the light load region (cruising) will have a greater negative impact on your fuel mileage than any hypothetical (and questionable) efficiency gains you get for the 5-10% of time you're accelerating, passing, or climbing a steep hill.
    Bigger tires and a lift reduce your fuel efficiency by increasing drag and parasitic losses. You can't just put a bigger engine in the vehicle to make up for that. The bigger engine must also generate more power, which uses more fuel.
    I'm not sure why this myth is so prevalent here, but no, an equally-equipped (4x4 vs 4x4) Silverado does not get better gas mileage than a Tacoma. The Silverado is actually a pretty good truck for what it is and they've done a good job with fuel efficiency. If you're looking to tow on-road, it's a really good choice. But it's still a heavy truck, which is why city fuel efficiency is worse than the Tacoma in every engine configuration. Take a look at the front-end of the Silverado and how low that front air-dam sits to see one of the ways they improved highway mileage. That low front air dam is the opposite of the Tacoma's high front ground clearance and as far as you can get from the 33s and lift you were talking about above. You're comparing apples and oranges, but either way it's incorrect to suggest that the 3.5L Tacoma gets worse gas mileage than the V8 Silverado.
    The outgoing 4.0 has less power than the 3.5L in the 3rd gen. If you look in to the design papers for the 2GR-FKS, it's obvious that Toyota did not go the cheap route with the engine design. There's just no free lunch when it comes to pickup trucks. If you want a tall, off-road capable, high-ground clearance pickup with a full-featured (heavy) interior, then it's going to be unfriendly to gas mileage. Toyota actually did a pretty good job of matching up the requirements with the engine.
  14. Dec 20, 2016 at 8:38 AM
    #134
    Kevindust
    Kevindust Well-Known Member
    Kevin
    Ottawa, Canada, eh
    16 DCSB 6M 4x4 TRD Sport Upgrade BBM
    My truck sometimes feels under powered when I'm towing (5000 lbs travel trailer), specifically when merging onto a highway at WOT. However, it still tows well overall and the 345 days a year when I'm not towing, the 3.5 certainly has adequate power. Since I have a manual, it's easy to rev it out and it really comes alive above 3500 rpm to the redline. It's more fun to drive and noticeably more powerful than the 4.0 I'm still really happy with the truck and do not want a full size.
    Speaking of which, the "if you don't like it, sell it and buy a full size" argument is juvenile. Most of us in this thread aren't whining or saying the truck is an under powered piece of crud, we're just offering constructive criticism that a little more power and torque would be really nice to have and we'd be willing to pay extra for it.
  15. Dec 20, 2016 at 10:19 AM
    #135
    wxm8562
    I very much agree with you. I have the manual transmission and have not one complaint about the power. I have complete control over the power delivery at all times. It actually feels quite powerful to me. I think Toyota did a fine job putting this engine in the Tacoma. It may not tow like a full-size, but it still does tow well. But at the same time, I think Toyota knows that most who buy a Tacoma aren't really towing anyway and they know the limitations vs a full-size in this regard.
    I am very happy with the new Tacoma on all fronts. However, I would not complain if they offered an engine with more abundant low end torque to make it a little more truck like engine. That said, I certainly have nothing to complain about with the 3.5L
    Kevindust[QUOTED] and Taco16LB like this.
  16. Dec 20, 2016 at 11:00 AM
    #136
    docsg
    docsg Well-Known Member
    South Alabama
    2020 White TRD OR SBDC
    Raptor 4" oval rails, OEM door sill protectors, totally debadged, OEM mud guards, OEM bed mat, OEM S/S tail pipe extension, BDT tailgate letters, Weather Tech sun screen.
    Damn...I don't know where you are getting those mileage numbers. My '16 Tacoma V6 SR5 gets easily 23-25 on the highway. It will drop to 22+ at Interstate speeds (75-80). In town (many stop signs/short trips) it never gets below 17 mpg and usually averages 18-19. I sold a '12 SR5 TRD Tundra with the 4.6L V8 to get the Tacoma. The in-town mileage sucked (13-15) but on the highway it easily got 19-20 mpg. In all honesty it was under-powered for the Tundra but I never really noticed it that much as I only towed a 5 X 10 enclosed m/c trailer with a Harley on occasion. Then the mileage would drop to a consistent 15 mpg. I rode in a friend's 5.7L Tundra and the difference was night and day. That damn thing would pull a building down. Would I like the 4.6L in my Tacoma? You're damn right! I honestly don't think the drop in mpg would be all that significant. IMO, if mpg is an issue then this thread is useless to you. But then again, I only drive about 1000 miles a month and gas in LA (Lower Alabama) consistently stays below $2 per gallon (current price $1.88) so my outlay for gas is only $50-60 per month. Bottom line, I'm happy with my 3.5L Tacoma. I was reading a thread about the ECT?...never even used it...worthless option IMO (yes, I know MANY use it often..some consistently).
  17. Dec 20, 2016 at 12:08 PM
    #137
    Taco16LB
    I do not get the dislike for the 3.5L we have .
    Are my memories of my 84Toyota 22R (22re?) misguided ? I had a 84 -manual and it had a lot of low end torque , BUT , it fell on its face in a hurry . It seemed as if the clutch was slipping at higher rpm's after 30 feet because it was all noise and no go . I prefer the new 3.5 , as it kicks in like a turbo at 3500 rpm . For stock tires and 3.5 ,it would benefit from a little higher gear of say at least 4.30 or even 4.56 and this truck would be perfect.
    TacoFister likes this.
  18. Dec 20, 2016 at 12:14 PM
    #138
    TacoFister
    TacoFister Well-Known Member
    Josh
    2016 QS TRD 4x4 Off Road
    I just want a boost in power. Honestly the 3.5 can make good power. Think it's rated at like 300+ in the lexus variant. Toyota just detunes them for longevity. I would like a turbo or supercharger....No need for a v8...
  19. Dec 20, 2016 at 12:15 PM
    #139
    TacoFister
    Josh
    Totally agree
    Taco16LB[QUOTED] likes this.
  20. Dec 20, 2016 at 12:27 PM
    #140
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Lots of folks poo poo'd GM for sticking with a pushrod V8, but truth is, they don't need big ole Big Block Hemi sized heads on a small displacement engine to make gobs of power. The LSx is a great platform for making power even with push rods. Plus it's small in overall size.
