4.6L 1ur-fe swap into 04 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wloomis, Jun 20, 2018.
  1. Jun 20, 2018 at 12:08 PM
    Wloomis
    Wloomis [OP] New Member
    Most people are gonna start by saying whyy.. I have a crashed/rolled 2012 tundra that runs and drives and want to tak the motor and drop it into a 2004 tacoma. What are the biggest issues with doing this? Has anyone else done it? Will the motor and trans fit? Let me here everyone's thoughts.
  2. Jun 20, 2018 at 12:13 PM
    TacoHank1998
    TacoHank1998 Well-Known Member
    Will
    Panama City, FL
    1998 Green Tacoma Base
    Got engine transmission and ecm...?!
    Wonderful now you have to figure out a way to fab everything up to the Taco frame.
    Please let me know how this turns out as it sounds rather awesome.
    Abeyancer likes this.
  3. Jun 20, 2018 at 12:28 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    I think the biggest problem is getting it to actually fit with the frame and the engine compartment then getting a fan and radiator. Then theres the transmission which is considerably larger and getting it to fit then theres the drive shafts that are also way bigger in diameter so theres going to be custom drive shafts. Thats just off the top of my head.
  4. Jun 20, 2018 at 1:01 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    maybe it would fit with a small body lift?
  5. Jun 20, 2018 at 1:03 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Honestly it would be easier to just put the Tacoma body on the Tundra. If you’re looking to swap the Tundra components you’re looking wiring, fabrication, and trial and error for days.
  6. Jun 20, 2018 at 2:02 PM
    TacoHank1998
    Will
    Panama City, FL
    Wait... taco body on Tundra frame....
    That's possible?!?!
    Comatose likes this.
  7. Jun 20, 2018 at 2:03 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Anything is possible with a lot of welding and fabrication.
    RattleTractor and Comatose like this.
  8. Jun 20, 2018 at 2:05 PM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Doctors are trying to do head transplants right now. I think a Tacoma body on a Tundra frame is very plausible.
  9. Jun 20, 2018 at 2:17 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    @COMAtized99 did it with the older version of the Tundra 4.7 but with the 2012 you're looking at different ECM/components that all need to report back in order to run. time is your only ally :)
    COMAtized99 likes this.
  10. Jun 20, 2018 at 4:10 PM
    TacoHank1998
    Will
    Panama City, FL
    I think the head transplant sounds more plausable... and easier.
  11. Jun 20, 2018 at 4:42 PM
    mlcc
    Oregon
    Now theres thinking outside the box. And worth a shot.
  12. Jun 20, 2018 at 6:06 PM
    Kerby J
    Kerby J Well-Known Member
    Kerby
    Lincolnton, NC
    1998 Quicksand Tacoma
    I say go for it! There is always a first time for everything.
  13. Jun 20, 2018 at 6:12 PM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    Yeah right.. Guys who are capable of a v8 engine swap don't make posts asking if it's possible or not.
  14. Jun 20, 2018 at 11:17 PM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    "They put a pig heart in some guy in Russia" -Ricky Bobby
  15. Jun 21, 2018 at 6:02 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    The biggest issue I see is physical size of all the UR engines. The dual VVTi heads are massive. Just take some basic front to back, and side to side measurements. Compare to your engine compartment now.
  16. Jun 21, 2018 at 6:04 PM
    Bishop84
    Bishop84 Well-Known Member
    Argree with Coma, UR's are massive and have wide angles. You'd probably end up with no fenders and a custom rad support by the time you were done.
    I've thought about taking donar tundra engines into other cars but they have such a large foot print that its not worth it.
    LS1 are famous due to the tight packaging.
  17. Jun 21, 2018 at 6:05 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    Possible, sure, but honestly, picturing it in my head, it would look hella funky.
    Think about how wide, and long the average tundra is, and compare it to how narrow and short length wise our gen Tacoma's are..
  18. Apr 19, 2022 at 1:02 AM
    dpanibratets
    dpanibratets Well-Known Member
    Denis
    Vancouver, WA
    2005 DCSB soon to be with V8 1UR-FE
    I am going to put a 1UR-FE into a 2nd Gen Tacoma. I plan on using a gx460 drivetrain. The GX460 is sold at a GX400 in china with the 1GR-FE. The engine mounts are very similar and I wouldn't be surprised the 1UR-FE bolts into the Tacoma. Additionally what I have found that a Tacoma automatic A750F and the GX460 A760F share the same bell housing. I plan on using the A760F trans. Essentially this means that the 1GR-FE and 1UR-FE have the same bolt pattern on the back of the block.
  19. Apr 19, 2022 at 1:08 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    The bellhousings are different if I remember right. But they can be swapped between the two transmissions.
    The 1gr starter is on the driver side, all the UR engines are on the passenger side.
    dpanibratets[QUOTED] likes this.
  20. Apr 19, 2022 at 1:12 AM
    dpanibratets
    Denis
    Vancouver, WA
    Good catch, well it shouldn't be a problem in my case considering the GX transmission is going in also.
