4 7/8" BS w/ 285s
Discussion in 'Wheels & Tires' started by dually, Jan 26, 2012.
  1. Jan 26, 2012 at 7:16 PM
    dually
    dually [OP] Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Well I dont want to completely ditch the wheels that came on the truck just yet, but it definitely needs bigger tires. Its lifted 3" and has 265/70-17s now but they just look too small. The wheels are Ultra Drifter 17x8 with 4 7/8"BS and +10offset. I know most guys are saying 4.5" and you'll be safe with no cab mount rub, just a little trimming. But would I be safe for a while with 4 7/8" BS? Does that 3/8" make a difference?
    The tires I found are 285/70-17s. Dick Cepek Crushers. I was planning on putting them on tomorrow, but I want to make sure it will fit without rubbing on the strut tower and cab mount.
  2. Jan 27, 2012 at 5:50 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    That's definately too little backspacing. The 4.5" you have heard is for second gen tacomas to run 285's.
    for first gens, the stock wheels are 4.5" BS. You'll want something at or less than 4" BS to run those.
  3. Jan 27, 2012 at 6:50 AM
    dually
    Oops this is on my 2nd gen
  4. Jan 27, 2012 at 6:52 AM
    KPT
    09 Prerunner
    Ah okay. It's going to be close. There are a few guys running 285's on 5" BS wheels (rockstars), but the wheels are also 9" wide so they pull the tire slightly further away from the UCA in comparison to an 8" wide rim with the same backspacing.
  5. Jan 27, 2012 at 7:03 AM
    dually
    Hmmm. These wheels could be 4.5 or 4 7/8. Im not sure until I take them off. Ill have the tire shop pull one off and im going to check
  6. Jan 27, 2012 at 2:43 PM
    dually
    Wheels turned out to be 4.5". Tires fit great, minimal rubbing at full crank.
  7. Jan 27, 2012 at 4:04 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Silverado Z71
    Readylift, Truxedo, Husky Liners, Carven
    That looks real good!
  8. Jan 27, 2012 at 4:08 PM
    Sunner
    Sunner Well-Known Member
    Does look very good OP
