4.75 backspacing and 11.2 wide tires
Discussion in 'Wheels & Tires' started by luk8272, Apr 30, 2008.
  1. Apr 30, 2008 at 3:38 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I have heard that we need 4.5 backspacing to accomidate 33" tires.
    Will this be sufficient?
  2. Apr 30, 2008 at 3:42 PM
    08Tacoma
    08Tacoma Well-Known Member
    Arizona
    2008 Tacoma, DblCab, 4x4, TrdSport, BlackSandPearl, 2.5" Toytec, TubeSteps, WindowTinting
    U should be ok!!
    Whats the width of the wheels??
  3. Apr 30, 2008 at 4:30 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    285/70/17 32.7" Tall and 11.2" wide.
  4. Apr 30, 2008 at 4:37 PM
    08Tacoma
    Arizona
    Thats the tire size, I mean the wheel, are they 17x8, 17x9???
  5. Apr 30, 2008 at 4:42 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    The wheels are 9 wide sorry I miss read your previous post.
  6. Apr 30, 2008 at 4:50 PM
    08Tacoma
    Arizona
    Yeah, you should be ok with that backspacing to clear the control arm.
    But you might have some rubbing issues in the fender, the tire is to big!!!
    Did you lift it your truck??
  7. Apr 30, 2008 at 4:54 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    Yep installed a 3" toytec with 884 coil springs and blocks in rear.
  8. May 1, 2008 at 7:34 AM
    08Tacoma
    Arizona
    Ok, you should be fine, theres maybe a chance that you might need to cut a litle bit on the plastic in the front and back of the fender.
    Post some pictures when youre done with your truck and good luck!!
  9. May 1, 2008 at 2:30 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    I sure will. I am offshore right now for about 2 weeks. But when I get home I'll put up some pics.
