4.88’s ordered
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Aug 14, 2018.
  1. Aug 14, 2018 at 4:39 PM
    commbubba19
    commbubba19 [OP] Well-Known Member
    '23 TRD PRO
    no going back now haha
    Ship is also doing ecgs bushing too.
  2. Aug 14, 2018 at 5:19 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    What size tires are you running or plan on running with the 88's?
  3. Aug 14, 2018 at 5:48 PM
    commbubba19
    '23 TRD PRO
    265/70/17
  4. Aug 14, 2018 at 5:49 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Are you manual or automatic?
  5. Aug 14, 2018 at 5:51 PM
    commbubba19
    '23 TRD PRO
    Auto
  6. Aug 16, 2018 at 10:16 AM
    Kona_boy
    Kona_boy Well-Known Member
    Kent
    2017 White TRD OR
    Question for OP as I'm thinking of regearing too and have same tire size. How much extra weight are you carrying? And why 4.88 over 4.3x?
  7. Aug 16, 2018 at 10:32 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    Why re-gear with almost stock tire size?
  8. Aug 16, 2018 at 11:07 AM
    commbubba19
    '23 TRD PRO
    4.88's still put the final drive ratios lower than a manual trans truck. The auto is simply undergeared. hence why even going to a 32-33" tire makes the truck such a dog. Toyota geared the transmission aggressively towards mileage and put it on the edge of practical. The also poorly placed 5th gear causes the drop to 4th to be over 1000rpm jump at times (depending on speed). That's too big of a gap.
    The only real way to solve this is by changing the final drive ratio. No tuning magic can overcome this. This allows 6th and 5th to be much more usable. i'll see both an increase in performance, mpg's, towing capability all with less wear and tear on my truck. Plus opening myself up for running larger tires once my 265/70/17's are worn.
  9. Aug 16, 2018 at 11:09 AM
    commbubba19
    '23 TRD PRO
