4:88.1 from 4:10.1 Why not?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iitywygms, Nov 17, 2014.
  1. Nov 17, 2014 at 8:18 AM
    iitywygms
    iitywygms [OP] Well-Known Member
    Norcal
    4x4
    Hi all.
    So I am going from stock 30 inch tires with 410 to 32 inch tires with 488.
    2.7 2011 4x4
    I am pulling a trailer on occasion.
    Using this calculator
    http://www.grimmjeeper.com/gears.html
    It seems at 70 mph I will only see a increase of 300 rpm.
    I know there are a ton of threads discussing this.
    I read a lot of people saying that the engine will be screaming going down the freeway with tall gears like this.
    And from what I have read it seems most people would not recommend the 488 gears on this tire size.
    But if the rpm is only increased by 300 at 70 mph, why not?
    300 rpm is hardly anything?
    Or am I missing something?
  2. Nov 17, 2014 at 9:15 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    You'll be ok with the 4 cyl. I'm running 4.88's with 37's and it's just like stock, the speedo is even correct. They will help with acceleration and towing as well.
  3. Nov 17, 2014 at 1:54 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    4.56's would be a better choice if you are only going up to 32's tires.
  4. Nov 17, 2014 at 2:27 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Better choice for whom? If he wants more grunt to tow a trailer 4.88's will work great. They aren't that low. Even 5.29's would be streetable, just waste some gas on the highway.
  5. Nov 17, 2014 at 2:48 PM
    iitywygms
    Norcal
    4x4
    That is what I have read before.
    But from the calculator, 488 is only a 300 rpm increase at 70 mph.
    300 rpm is not much.. Right? :confused:
    Which is why I don’t see the downside of 488 at this tire size.
    Possibly a little bit of gas mileage loss?
    Maybe I should be asking if others have seen a huge jump in rpms and my calculations are off.
  6. Nov 17, 2014 at 2:52 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I have 4.88s and ran them with 33s and my rpms at 70mph were 3k. With 35s now its at 2800 at 70mph. My speedo was also off by 14 mph at 70 mph
  7. Nov 17, 2014 at 3:24 PM
    iitywygms
    Norcal
    4x4
    Now that is different than what the calculator is telling me.
    I wonder if the calculator is wrong? With 32 tires, at 70mph it says i will be turning 2570.
    If you were turning 3k at 70, then I will be turning more, which i do not want.
    The calculator says 2279 with stock gearing and tires. (which is what I see in my truck)
    Maybe I have punched in the numbers wrong. Can someone else double check me?
    Stock. 410 with 245-75 r16
    New setup. 488 with 275-70 r17
  8. Nov 17, 2014 at 3:33 PM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    I think it would perfect. My buddy runs 32's with 5.29's on an older Toyota pick up, and they only place they feel low is on the highway. 4.88's seem like a good compromise, I think.
  9. Nov 17, 2014 at 6:15 PM
    iitywygms
    Norcal
    4x4
    488 is 119% of 410
    So basically, with 488 gears, the drive shaft spins 20% further/more than with 410 gears.
    That would equal a 20% increase in rpm at any give speed.
    So if I run 2250 rpm now. With 488 i will run 20% more rpm. Or 2700 rpm.
    Given that I am increasing tire size quite a bit, I could see that the calculator is correct. I think I just answered my own question.
    488 it is.
  10. Nov 17, 2014 at 7:12 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    All I can tell you is what my tachometer says. 3k isn't that high. I run 80 mph at 3K with the 35s and get 18mpg still. I
  11. Nov 17, 2014 at 8:38 PM
    iitywygms
    Norcal
    4x4
    rpms at 70? Actual from gps if you have them.
  12. Nov 17, 2014 at 11:25 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    X2 on this one.
    4.88 and 33's myself.
    3k at 70
  13. Nov 17, 2014 at 11:26 PM
    numbah57
    kahai
    Maui, Hawaii
    Even wish I went with the next step lower
  14. Nov 18, 2014 at 8:56 AM
    iitywygms
    Norcal
    4x4
    Will re-gearing change the speedometer or is it only read from the tires?
  15. Nov 18, 2014 at 9:17 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Depends if you have a 4 banger or 6 cyl.
  16. Nov 18, 2014 at 9:36 AM
    iitywygms
    Norcal
    4x4
    4 banger
  17. Nov 18, 2014 at 10:13 AM
    numbah57
    kahai
    Maui, Hawaii
    My speedo is off with gears and 33's
    2009 4 banger
  18. Nov 18, 2014 at 12:42 PM
    iitywygms
    Norcal
    4x4
    Now that I think about it, gearing should have nothing to do with it.
    Has to come from the tires. Which is good because with 32 inch tires my speedo is dead nuts accurate according to my gps.
  19. Nov 18, 2014 at 1:03 PM
    numbah57
    kahai
    Maui, Hawaii
    At 70 my speedo is off by 10-12 mph with 33" tires and 4.88 gears.
  20. Nov 18, 2014 at 1:04 PM
    numbah57
    kahai
    Maui, Hawaii
    Speedo shows 70 but gps says 58-60 ish
