4.88 and Eaton True trac installed... Underwhelmed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YotaFAB, Jan 7, 2023.
  1. Jan 11, 2023 at 11:33 AM
    #41
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    I'm running the 255/80/17 toyo at3 e loads which are about 50lbs according to their website. Been happy with acceleration and up in the mountains too.
  2. Jan 11, 2023 at 11:45 AM
    #42
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    late to the party but a tune would be the way to go. You can always swap back as needed. Depends on what you were expecting. The truck will feel a bit smoother and quicker than stock it's not going to give you race car feelings. I had 4.56 and a tune, and I thought it was the best combo I have had even with FI (although the truck got a lot heavier). If you are running E-rated, you can go to C rated or go to a skinnier tire, and that will pay dividends. Just read @crashnburn80 response and just that. N/A tune and 4.56 for me was spot on but could have gone 4.1 or 4.3. The current setup wold feel grate on rocks. Now I am 4.56 with FI and its a nice combo. I may go 4.88's on my next change if it comes to it but that is more considering larger tires etc.
    YotaFAB[OP] and crashnburn80 like this.
  3. Jan 11, 2023 at 11:50 AM
    #43
    YotaFAB
    YotaFAB [OP] Well-Known Member
    That makes sense, I was considering going with a bigger tire is the main reason I didn't do lower than 4.88.
  4. Jan 11, 2023 at 11:52 AM
    #44
    nudavinci64
    Robert
    depends which tire. I held off on 4.88 as I was unsure when. Even with 35's 4.56 has been nice. If you are going to 35's are larger should balance out in time.
  5. Jan 16, 2023 at 7:47 PM
    #45
    YotaFAB
    500 miles down, I have been a little more pedal heavy since hitting 500. Eaton is pretty nice, I guess my stock LSD was shot. The acceleration is nice now that I'm getting on it, but I think a bigger tire will smooth this out a lot.
  6. Jan 16, 2023 at 10:15 PM
    #46
    TacoTuesday1
    SD CA
    I wonder if 4.56 vs 4.88 on 35’s makes a difference regarding auto vs 6MT
  7. Jan 17, 2023 at 1:24 AM
    #47
    nudavinci64
    Robert
    It does. Personally have not ran both but the 5 speed is going to be geared differently.
    Rule of thumb I got from a lot of folks when I was reading
    4.56 (Manual), and 4.88 (Auto) would be similar.
    I am running 4.56 now with 35's, and it's been fine (I am also S/C, though).
    Most of the calculators with gear ratio will say 4.88's too much some low-end "power". A lot of folks I know run 4.3 and 4.56 but you will see plenty running 4.88s on either setup. 4.56 has been a nice blend of back-to-stock ratio with a tad more to it than stock.
  8. Apr 4, 2023 at 10:41 PM
    #48
    YotaFAB
    On a 33" tire, truck is really nice. Love being able to chirp tires with my gas pedal. I don't regret the gears. Just wanted more initially!
  9. Jul 12, 2023 at 12:25 PM
    #49
    vanhap
    vanhap Well-Known Member
    Steven
    CA
    97 Tacoma 4x4
    All together need to take our smog tea and pour it into the bay.
    YotaFAB[OP] likes this.
  10. Jul 12, 2023 at 12:35 PM
    #50
    vanhap
    Steven
    CA
    97 Tacoma 4x4
    You did 488 with eaton truetrac? I'll be doing this soon
  11. Jul 12, 2023 at 2:29 PM
    #51
    YotaFAB
    Yea, its great! Gas milage is gone, but that was expected.
