4.88 front and rear gears
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tommytomtoes, Nov 28, 2023.
  1. Nov 28, 2023 at 7:31 PM
    Tommytomtoes
    Tommytomtoes [OP] Active Member
    Thomas
    2016 trd sport 4x4 Tacoma
    Those who have installed 4.88 gears, did you notice a big difference? I’ve recently had 4.88’s installed and I’m not noticing much aside from I don’t have to push the gas pedal as much to get it to downshift and the city gas mileage has increased a little. Still seems sluggish. Still gets shit highway gas mileage. For what it cost, almost doesn’t seem worth it. I’m really just curious as to what you guys noticed. Thanks!
  2. Nov 28, 2023 at 7:37 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I noticed a huge difference. Was your truck already re-geared? Did you buy it used?
    Junkhead likes this.
  3. Nov 28, 2023 at 7:57 PM
    Wwjvd
    Wwjvd Well-Known Member
    Jimmy
    2022 TRD Off-road 4wd
    Lift? What size tires? What are you carrying?
    Chew likes this.
  4. Nov 28, 2023 at 8:01 PM
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    Definitely worth going to 5.29's. The reason is the double overdrive on the Tacoma's, and lack of low end torque. Have you done a tune alongside the gears?
  5. Nov 28, 2023 at 8:04 PM
    YotaFAB
    YotaFAB Well-Known Member
    I felt the same way, in a 2wd sport on 285x75x17. I've heard tune is the way to get the most out of it.
  6. Nov 28, 2023 at 8:44 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    4.88’s and a tune for me. Running pizza cutters and I’m not heavy
    Junkhead and OffroadToy like this.
  7. Feb 8, 2024 at 9:45 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    I'm not sure how anyone that's done this switch wouldn't notice a difference UNLESS maybe you just bought the truck and hadn't driven it for any length of time with the stock gear ratio.
    It helps for sure but if you're expecting the truck to feel like an 5.3 v8 LS.. it doesn't.
    71tattooguy likes this.
  8. Feb 8, 2024 at 11:17 AM
    Darkice
    Darkice Well-Known Member
    4.88 makes 1st and 2nd gear noticeably shorter IMO. getting a tune will make it even more noticable.
    I would recommend getting a tune. i think a tune + 4.88 gearing is perfect.
    71tattooguy and YotaFAB like this.
