4.88 gear install On 03 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by stinkyspice, Apr 5, 2017.
  1. Apr 5, 2017 at 5:31 PM
    stinkyspice
    stinkyspice [OP] Well-Known Member
    I've been reading and searching for a while can't find a definitive answer. Me and my buddy want to regear my 03 Tacoma 4x4 to 4.88 gears. He is the tech in the situation and is wandering if we are going to need to grind away on the inside of the diff at all or if they are direct replacement in front and back diffs? Im trying to look for a write up on 1 gen gear swaps but couldn't find one. Any help would be much appreciated!!
  2. Apr 5, 2017 at 5:33 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Direct swap. No modification needed. There's a write up on here somewhere for the rear and another on expedition portal for the front. It's fairly strait forward
    Tdoo likes this.
  3. Apr 5, 2017 at 9:30 PM
    Tdoo
    Tdoo Member
    Terry
    04 taco double cab
    3" lift, rear e locker, sliders
    Hey does anyone have 4:88s with 285/r70/16 tires and auto with v6?? Just wondering if it will be way to low for freeway speeds. I'm about to get some installed.
    Anyone have any thoughts?
  4. Apr 5, 2017 at 9:41 PM
    MO Tacoma
    MO Tacoma Well-Known Member
    Castle Rock, CO
    2014 DCLB with a couple mods
    ADS extended travel, 14" 700 lb springs, Total Chaos UCA/LCA, Dakars. 37/12.50r17 Pitbull Radial Rocker. SCS 17" SR8. 4.56s with f&r ARB lockers. Relentless sliders, full skids, debadged. 35% tint on all windows. Katzkin leather w/ heated seats
    I'm not sure the difference between 1st and 2nd gen but I have a 2nd gen, 35s, V6 and 4.56s. At 60 I'm at 2k rpms and climbs fast from there. I drive a lot of highway and would not want 4.88. Please excuse me if 1st gen is completely different.
  5. Apr 5, 2017 at 9:47 PM
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
  6. Apr 6, 2017 at 7:08 AM
    boostedka
    James
    NM
    Did you mean 285/75/16? If that's the size you're looking at (33's), they 4.88 are a pretty good set up with the V6 and Auto Tranny. That should put your rpm about 260 rpm higher than stock (asumming you have 4.10 gears to Start). You'd be around 2650rpm at 75 mph. If you're starting with 4.30's then it would be about a 150 rpm increase over stock. That should keep your tranny from wanting to down shift so much on the freeway. Especially with the gear it looks like you have added to your truck. Just my $.02
  7. Apr 6, 2017 at 3:03 PM
    stinkyspice
    U guys are the best thanks!!!!!
  8. Apr 9, 2017 at 12:03 AM
    Tdoo
    Tdoo Member
    Terry
    04 taco double cab
    Thats great info Boostedka. Ya 4:10 they are and figured that 4:88s would be a good fit as i tend to pull a small cargo trailer up some long hills from time to time fully loaded and also wanted to be nice and low for off road. Hope its just a tad bit lower than stock.
  9. Apr 9, 2017 at 12:13 AM
    Tdoo
    Tdoo Member
    Terry
    04 taco double cab
    Also looking for some more quick advice on weather getting a crawl box would be the better option instead of spending the money on the lower gears? just another idea i thought id ask. Thanks.
