4:88 gears for a 2016 on the way.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JDEMELLO, Sep 6, 2016.
  1. Sep 8, 2016 at 8:38 AM
    #61
    4RNR
    4RNR トヨタ
    Ge
    America
    16 Tundra 1UR-FE | 10 4Runner 1GR-FE | 16 2GR-FKS DCSB 4X4 - sold
    2016 Tundra crewmax
    My truck actually came with 245s h/t and I upgraded to 265s a/t. Mine is SR version
  2. Sep 8, 2016 at 9:36 AM
    #62
    JDEMELLO
    JDEMELLO [OP] Well-Known Member Vendor
    Corona Ca
    none
    Yes I contacted them the second we got ours. Even in stock form it shifted way to much for my likely at freeway speed and I knew with the addition of big tires it would only get worse.
    It does effect the speedo, I can only speak to the cars we've done. Generally and I mean "generally" because results may vary. Our 2015 4runner we run 4:88's in it and the speedo is 4mph off. Our 2013 Tundra is about 5mph with 4:88's and 37's. But realistically all trucks/cars are a little off. For a more exact you could run a GPS and compare it to your speedo. I personally just assume it's a a couple mph off and don't worry about it.
    IMO no. But that has more to do with everything. The Torq curve the engine IMO is at too high of an RPM compared to the older 4.0 tacoma motor. This engine has to rev a lot more to get the same torq. And the higher the revs the worse the MPG. So on paper, on a flat ground the truck technically will get better MPG un-loaded and on flat ground. If you put any weight in it, if you modify the tire size or do anything else to it your milage will suffer. Because you need more torq to move that weight and or over compensate that extra circumference of the tire.
    In the real world what that translates too is I can put 500lbs in the tacoma and it gets 11-12 mpg I put that same 500 lbs in our super charged 7200lb tundra and I get 12-13mpg That's a rough estimate but the point is the tundra has to work way less harder to move that weight because it has the torq to do it at lower RPMS. BUT empty completely stock the Tacoma will get better mileage. I want to say mine got a consistent 17-20 on my trip back from Colorado. I would estimate a stock tundra getting closer to 15mpg.
    Does that make sense?
    4RNR[QUOTED] likes this.
  3. Sep 8, 2016 at 9:47 AM
    #63
    4RNR
    4RNR トヨタ
    Ge
    America
    2016 Tundra crewmax
    Yes and thank you!
  4. Sep 9, 2016 at 9:29 AM
    #64
    catfish37
    catfish37 Well-Known Member
    16' dcsb trd or 4x4
    The auto is way to high geared even stock with stock tires. I run mine in 5th gear always. So if I wanted to go even slightly bigger tires I wouldn't go any higher than the 4:88.
  5. Sep 9, 2016 at 1:38 PM
    #65
    0311K1LL
    0311K1LL The Old Breed
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    OME 887 w/Bilstein 5100's, 1.5 AAL, SPC LR UCAs 285/75/r16 Toyo AT2s!
    any input on the 2016 2.7 4cyl 4x4 auto running stock 4.30 gears?
  6. Sep 11, 2016 at 7:05 AM
    #66
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    It was suggested by another member that it could likely be the backlash, looked into it and talked to a few diff specialist and they all said the same, sounds a lot like its the backlash.
    Problem is the way to usually correct it is just adjust the driveshaft and rack and pinion spacing to factory specs. But if toyotas factory specs are off it will not fix the problem because it will be harder for them to accept they have the wrong spec.
    That being the case it could also just be quality control that some weren't set up to the properly distance.
    It's going to take time to fix this issue. Until someone bites the bullet and pays to do it themselves from an independent shop its going to be a problem. To be fair though if it is the backlash its not so much a mechanical issue just a noise problem.
  7. Sep 11, 2016 at 7:36 AM
    #67
    Tacomyles91
    Tacomyles91 Member
    2016 Trd Sport Prerunner 265/70r17 K02 Bilstein 5100 @.85 4.88 Nitro Gears Detroit TruTrac
    Your information is a bit wrong. First a rack and pinion is a steering mechanism not a drive mechanism. Second, you can't adjust a driveshaft nor would it cause the howling. The term ring and pinion is what you're looking for. Improper backlash and preload could definitely be the issue but seems odd that Toyota would not learn how to set up a diff after this many years. Mine is silent but the sports come with the old 8" diff. Only the off-road and MT trucks come with the new 8.75" diff. So maybe the issue is only on those.
  8. Sep 11, 2016 at 9:31 AM
    #68
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Does the new Tacoma with the 8 inch ring and pinion take the old-style 8 inch gears? Is it only the new 8.75" that were waiting for the new gears. So what I'm asking is can we just order 488's for the old 8 inch and put them in our new auto's with the 8 inch rear.
    Thanks
    Chris.taco.2016 likes this.
  9. Sep 11, 2016 at 3:31 PM
    #69
    Tacomyles91
    Tacomyles91 Member
    They now have gears out for both.
  10. Sep 11, 2016 at 5:39 PM
    #70
    Joe23
    sorry ring and pinion was what I meant to say.
    Could just be from the new 8.75 one.
    Or could just be the huge rush for the new tacomas. From what I understand they are flying off the shelves there in the US. They aren't in as high demand here so maybe the canadian spec are having more quality control done?
    Would explain the backlash and preload not being set right
    low transmission fluid
    low fluids in general
  11. Sep 11, 2016 at 7:41 PM
    #71
    Chris.taco.2016
    Chris.taco.2016 Well-Known Member
    2016 Tacoma trd sport mgm dclb
    Can anyone that has installed the 4.88s give us a review!!??
    Sixgun CO likes this.
  12. Sep 12, 2016 at 12:47 PM
    #72
    JDEMELLO
    Corona Ca
    none
    Just waiting for the gear guy to come this week and do ours.
    bajabenny and Stu488 like this.
  13. Sep 17, 2016 at 6:43 AM
    #73
    Taco2017
    Taco2017 Member
    South Carolina
    2017 TRDOR DCSB 4x4 MGM
    Black Grill, Black Overlays, 5100's set at 1.75,18x9 fuel wheels 275 65 18 tires
    Any updates?
  14. Sep 19, 2016 at 11:41 AM
    #74
    dcz108
    dcz108 Well-Known Member
    Central PA
    2016 SR5 DCLB
    a bunch of mods
    im looking for an update as well. im highly considering a gear change in my 2016 sr5
  15. Sep 19, 2016 at 11:44 AM
    #75
    Tacomyles91
    Tacomyles91 Member
    My 3rd member is sitting on my kitchen floor. I'll put it in Saturday and post a review.
  16. Sep 19, 2016 at 11:50 AM
    #76
    OkTacoTRD
    OkTacoTRD Well-Known Member
    Jerry
    2016 Black Tacoma TRD Off Road
    So even running just 265/70/17s you felt the need to regear? I'm considering 265/75/16s but am concerned it will make it shift even worse on the highway. How much of a difference did you notice when you made the change from the stock tire size?
  17. Sep 19, 2016 at 12:11 PM
    #77
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    I had my truck in for regear to 4.88 but came to find out I was told the wrong part numbers. Had to get a new front carrier to fit the set they set me. Can anyone here, with a 2016 TRD Sport that has done it, confirm the Nitro part number for rear?
  18. Sep 19, 2016 at 12:32 PM
    #78
    Tacomyles91
    Tacomyles91 Member
    I thought it was terrible with stock size and worse now. Either way gears are needed.
  19. Sep 19, 2016 at 12:34 PM
    #79
    Tacomyles91
    Tacomyles91 Member
    Tv6-488-29-ng
    pngo121[QUOTED] likes this.
  20. Sep 19, 2016 at 12:35 PM
    #80
    pngo121
    Phi
    Pittsburg, CA
    awesome thanks! thats the one i have. now i just have to get another appt. these guys are booked out a few weeks.
