4.88 or 4.56????
Discussion in 'Off-Roading & Trails' started by LBFD2005, Dec 23, 2012.
  1. Jan 11, 2013 at 7:38 PM
    #141
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
  2. Jan 11, 2013 at 7:39 PM
    #142
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Totally quoted the wrong post out of pure canadian RAAAAAAAAAAGE
  3. Jan 11, 2013 at 7:40 PM
    #143
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    :woot:
  4. Jan 11, 2013 at 7:41 PM
    #144
    MonkeyProof
    SoCal- SGV
    Put the maple syrup bottle down and walk away
  5. Jan 12, 2013 at 11:57 PM
    #145
    Manwithoutaplan
    ID
    well then i Apologize for the name calling and to Spoonman.
  6. Jan 13, 2013 at 12:00 AM
    #146
    Manwithoutaplan
    ID
    May i ask who it was, because what he said was not very nice. Because the coward did not give their name.
  7. Jan 13, 2013 at 2:44 AM
    #147
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    w/ 4.56s and 315s:
    80 - 3000
    75 - 28
    70 - 265?
    65 - 25
  8. Jan 13, 2013 at 6:51 AM
    #148
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i cant give you the name, but i can tell you it wasnt him.
  9. Jan 13, 2013 at 7:04 AM
    #149
    skulltacoma
    skulltacoma Make more better!
    BEN
    Calgary, AB, Canada
    2009 toyota tacoma trd modified
    CAI, dynomax turbo exhaust system,tinted windows medium on the fronts to match the backs, hid kit hi and low beam, pop and lock tailgate, painted calipers red with caliper paint, put 2.25' leveling kit in front and a 1" block in the rear. its now level and rides WAY better (readylift)>way nicer than the revtek my buddy has i think its garbage imo<, hurst "T" shifter, 18 x 10 american racing (can't remember the name) chrome rims with badass 5 inch lip :), 12 inch rockford fosgate punch with rockford fosgate 600 watt amp, bushwacker fender flares (cheaper than replacing the one i wrecked lol) ,kc light bar with kc lights, toyota aluminum stamped skid plate, and a skull front license plate. More mods to come, thinking a 6 inch lift and arb bumper etc etc.
    I just don't know. So I thought I'd ask.
    If you have the tacoma that comes OE with the factory rear electric locker can you still just get gears or is it a pain in the ass?
    What I am asking is am I able to keep the electric rear locker if i do decide to go to 4.88s ?
    Any help is appreciated.
  10. Jan 13, 2013 at 8:04 AM
    #150
    BradyT88
    BradyT88 Well-Known Member
    Yes. I have the OEM E-locker and am running 4.88's.
  11. Jan 13, 2013 at 9:21 AM
    #151
    LBFD2005
    LBFD2005 [OP] Its tha Southern Way
    MS
    11' Trd 4x4 6" pro comp
    procomp 6'' catback dual exhaust flowmaster 44 series
    are you auto or standard??
  12. Jan 13, 2013 at 10:19 AM
    #152
    Manwithoutaplan
    ID
    have you gotten your gears yet ??
  13. Jan 13, 2013 at 11:25 AM
    #153
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    07 Access cab Manual 1GR-FE -- 6 spd
  14. Jan 13, 2013 at 12:42 PM
    #154
    LBFD2005
    MS
    checked tracking they should be delivered thursday.
  15. Jan 13, 2013 at 12:43 PM
    #155
    LBFD2005
    MS
    guess thats y the high rpms?? everyone saying the auto will be lower rpms due to the m/t gear ratio
  16. Jan 13, 2013 at 12:46 PM
    #156
    surf4life1102
    surf4life1102 Well-Known Member
    Kristiian
    Florida
    08 PreRunner SR5 TRD OR
    bedlined rear bumper and front valence, black grill surround, color matched emblem, blacked out all badges, baseball shift knob
    What exactly do these gears do?
  17. Jan 13, 2013 at 12:58 PM
    #157
    Mossy
    Mossy Mechanic for Honda
    billy
    san antonio, TX
    ProComp lift Borla exhaust Borla air filter Nfab bars
    Get back lost power from putting big tires on your truck Imagine running a 37in tire on factory gears! Truck will be so slow and horrible on fuel and will struggle. Change some gears so that those huge tires will feel like factory ones and your truck will gets its balls back
  18. Jan 13, 2013 at 1:00 PM
    #158
    LBFD2005
    MS
    once you put bigger tires on a gas vehicle you tend to lose your low end torque. When you replace the gears you can get back to having stock power or more depending on which way you go with the gear ratio. The higher the ratio the more low end torque you get.
    this gets alot more technical but just a general idea for ya
  19. Jan 13, 2013 at 6:07 PM
    #159
    BradyT88
    It's all a mechanical advantage. For us autos, our 1st gear is a 3.52 to 1 ratio and the factory gears in the diff are 3.727 to 1. Assuming you are in 4Hi, that means that every 3.52 times your crankshaft rotates, your driveshaft will rotate once and then every 3.727 times your driveshaft rotates, your axles and tires will rotate once. So you multiply those two ratios together and your get about 13.119. That means every 13.119 times your crankshaft rotates your tires will rotate once. Gears offer a mechanical advantage. The higher your ratio number is the less force it takes to rotate the tires, but the more rotations you have to apply to get 1 full rotation of the tires. Our V6's put out 266 ftlb of torque at 4000rpm at the motor. So assuming you are at 4000rpm the motor is putting our 266 ftlbs of torque to the tranny. The tranny's gear ratio turns that into 266*3.52= 936.32 ftlbs of torque on your driveshaft. Then your diff gears will turn that into 936.32*3.727= 3489.66 ftlbs of torque on your axles.
    By changing your diff gears from 3.727's to 4.88's you turn that 3489.66 ftlbs into 936.32*4.88= 4569.24 ftlbs of torque. More torque turns the wheels easier but the cost is a higher rpm.
    4Lo works the same way. The transfer case is right behind the tranny so the tranny puts out the same 936.32 ftlb and the transfercase (having a low range of 2.567 to 1 ratio) turns that into 2403.53 and then the diff turns that into 8957.97 ftlbs with 3.727's or 11729.24 ftlbs with 4.88's.
    These numbers aren't perfect for many reasons though. 1 your probably aren't sitting on your peak numbers all the time, 2 not all tacomas will hit the same peak numbers, and most importantly 3 numbers are lost to the rotational weight of the drivetrain and weight of wheels and tires, etc. Like we are rated at 236 hp at the motor but on a dyno you will only get about 180-190 hp at the rear wheels. Dyno's calculate it to a 1 to 1 ratio to factor our gearing and tire diameter and give you a rough idea of how much power is lost to rotational mass of the drivetrain and tires.
  20. Jan 22, 2013 at 6:16 PM
    #160
    Spoonman
    Jamie
    Alberta
    Ordered 4:88. I'll let you fellas know how it feels! Maybe even a video.
