4.88 or 4.56????
Discussion in 'Off-Roading & Trails' started by LBFD2005, Dec 23, 2012.
  1. Jan 22, 2013 at 8:38 PM
    #161
    BradyT88
    BradyT88 Well-Known Member
    Feel great!:thumbsup: You'll enjoy it:D
  2. Jan 22, 2013 at 9:15 PM
    #162
    Manwithoutaplan
    ID
    what made you go 4.88 instead of 4.56 ?
  3. Jan 22, 2013 at 9:29 PM
    #163
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Nothing inparticular. Id like a little lower 4low. And I may jump to 37 one day, so the 4:88s will be great for that.
  4. Jan 22, 2013 at 9:32 PM
    #164
    Manwithoutaplan
    ID
    Don't you loose up travel with 37 and even 35 with the all pro kit?
  5. Jan 22, 2013 at 9:33 PM
    #165
    Spoonman
    Jamie
    Alberta
    Right now yes, but I do plan on tubbing the front. The tire upgrade would be most importantly for the slightly better ground clearance. I have high center problems.
  6. Jan 22, 2013 at 9:39 PM
    #166
    Manwithoutaplan
    ID
    With 37 you would have huge foot print for the snow. You have high center gravity even when air down?
  7. Jan 22, 2013 at 9:39 PM
    #167
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Why are 4.88's weaker?
  8. Jan 22, 2013 at 9:39 PM
    #168
    Manwithoutaplan
    ID
    The pinion is smaller.
  9. Jan 22, 2013 at 9:44 PM
    #169
    Manwithoutaplan
    ID
    [FONT=.HelveticaNeueUI]http://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/4-88-vs-4-56-a-493815/[/FONT]
    [FONT=.HelveticaNeueUI]Here black Tacoma.[/FONT]
  10. Jan 22, 2013 at 10:10 PM
    #170
    Blacktacoma23
    2011 Mall Crawler
    Cant see it :goingcrazy:
  11. Jan 22, 2013 at 10:11 PM
    #171
    Manwithoutaplan
    ID
  12. Jan 22, 2013 at 10:25 PM
    #172
    Manwithoutaplan
    ID
  13. Jan 23, 2013 at 9:01 PM
    #173
    Manwithoutaplan
    ID
    What is the break in period on new gears?
  14. Jan 23, 2013 at 9:06 PM
    #174
    BradyT88
    1000 miles I believe.
  15. Jan 23, 2013 at 9:07 PM
    #175
    Spoonman
    Jamie
    Alberta
    So chnge fluid after 1000? That's a waste of synthetic oil :(. However I may be able to get away with non synthetic for the break in period.
  16. Jan 23, 2013 at 9:14 PM
    #176
    BradyT88
    Cheaper than a 2nd set of gears. Haha i can buy synthetic gear from walmart for $3 or $4 a qt.
  17. Jan 23, 2013 at 9:19 PM
    #177
    Spoonman
    Jamie
    Alberta
    Cheap synthetic? Damn it's $12/L for Quaker state here.
  18. Jan 23, 2013 at 9:32 PM
    #178
    Manwithoutaplan
    ID
    sounds about right used Lucas oil.
  19. Jan 23, 2013 at 10:21 PM
    #179
    BradyT88
  20. Jan 24, 2013 at 10:50 AM
    #180
    LBFD2005
    LBFD2005 [OP] Its tha Southern Way
    MS
    11' Trd 4x4 6" pro comp
    procomp 6'' catback dual exhaust flowmaster 44 series
    I looked up on Detroit lockers and they advise not to use synthetic oil so be sure you read up before you start using it.
