4.88 or 5.29?!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cementtaco87, Nov 13, 2023.
  1. Nov 13, 2023 at 5:46 PM
    #41
    cementtaco87
    cementtaco87 [OP] Well-Known Member
    aaron
    yes i sometimes go up the mountain pass and but I never do crawling or smash the gas pedal going up hills
    71tattooguy likes this.
  2. Nov 13, 2023 at 6:00 PM
    #42
    sloppyTRD
    sloppyTRD Active Member
    Darren
    2016 TRD OffRoad DBLCBLB
    Icon - Stage 6 Suspension & Billet UCA w/Delta Joint Eibach 14in 700lb Front Springs OME Dakar Heavy Rear Stealth Custome Series Stealth 6 - 16x8 3.5BS Yokohama Geolander M003 M/T 315/75/16 Prinsu - Cab rack & Top Rack RCI - 20 Degree Rock Sliders RCI - Aluminum Skids ARE - Z Series Cap Brute Force Fab - Front Plate Bumper Brute force Fab - Rear HC Bumper with single swing out Cheapy TRD Pro Grille S-Tech Pod System Baja Designs Squadron Sport Pod Front Fogs
    5.29 all the way
  3. Nov 13, 2023 at 6:29 PM
    #43
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Absolutely your torque will come back, and maybe even then some (especially if you go with 5.29).
  4. Nov 13, 2023 at 6:43 PM
    #44
    cementtaco87
    aaron
    Going 5.29’s I hear i will lose even more mpg’s lol
    I just want my torque back and mpg’s
  5. Nov 13, 2023 at 6:45 PM
    #45
    4x4junkie
    So Calif. (SFV)
    4.88 then
    cementtaco87[OP] likes this.
  6. Nov 13, 2023 at 6:45 PM
    #46
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Then take lift off, weld cross member back in, and put stock tires back on. Can’t expect to lift, put bigger tires and put gears in a truck to achieve stock results.
    YF_Ryan and KRAMERICA like this.
  7. Nov 13, 2023 at 6:47 PM
    #47
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Dood forget about mpgs. I was getting 14-15 on LT rated 32" Bridgestone Duelers. Those things only weighed around 52 lbs each.
    With your lift and almost 34 inch tires you're doing pretty good at 15-16 mpgs
  8. Nov 13, 2023 at 6:48 PM
    #48
    4x4junkie
    So Calif. (SFV)
    FWIW, I drove around with a lift but still on stock tires for several months... The lift by itself had almost no effect on MPG. It was when I put the tires on that I noticed a drop.
  9. Nov 13, 2023 at 7:38 PM
    #49
    Beckbuilt
    Beckbuilt Member
    Jon
    Salt Lake City, Ut
    2022 TRD Off-Road
    I supercharged and regeared my 2022 Tacoma with auto trans. It is running 285/70R17’s. The supercharger was awesome but the regear almost made as much of a difference. Hands down go with 5.29 is you have an auto. They are so under-geared from the factory. Run the numbers on a manual truck with 4.30s it’ll surprise you. 5.29s with the auto on a 33 is about the same as a manual with stock gearing.
    33yrsoftoys and kas2828 like this.
  10. Nov 13, 2023 at 8:13 PM
    #50
    cementtaco87
    aaron
    That cut crossmember piece is long gone and no one is comfortable rewelding something to replace
  11. Nov 13, 2023 at 8:15 PM
    #51
    airforceb2cc
    Don
    KCMO
    Not many options for ya then.
  12. Nov 13, 2023 at 8:30 PM
    #52
    cementtaco87
    aaron
    I got somehow 15k in positive equity on the Tacoma
    I could trade it in use 10k as a down and the 5k for new tires, wheels and canopy it’s just i would go up in Apr due to the garbage current rates around here.
    not trying go up in payment
  13. Nov 14, 2023 at 3:57 AM
    #53
    airforceb2cc
    Don
    KCMO
    I doubt it once people realize you cut the frame of that truck...not many people are fans of drop bracket lifts...unless you live in Hawaii...then you will sell it instantly.
    TacoGranny likes this.
  14. Nov 14, 2023 at 9:04 AM
    #54
    cementtaco87
    aaron
    Was told so by my bank and my Toyota dealership down the road from me lol
    has just 45k on it.
    2019 TRD off road
  15. Nov 14, 2023 at 9:44 AM
    #55
    airforceb2cc
    Don
    KCMO
    Well the bank wont buy it. And if the dealer is offering you top dollar, I'd sell it and start over.
  16. Nov 14, 2023 at 9:45 AM
    #56
    cementtaco87
    aaron
    i know the bank wont buy it lol they are going off their vehicle value resources
  17. Nov 14, 2023 at 9:46 AM
    #57
    airforceb2cc
    Don
    KCMO
    Which doesn't take into account you cut the frame up.
    YF_Ryan likes this.
