4.88 re gear in a gen 1
Discussion in '1st Gen. Tacomas (1995-2004)' started by TheFelix0418, Sep 23, 2019.
  1. Oct 24, 2023 at 8:12 AM
    ShiftyShank
    ShiftyShank Oof
    Pat
    Northern Colorado
    02' BestGen 5VZFET
    You need a super charger
  2. Oct 24, 2023 at 10:32 AM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    You don't need a supercharger. Use this equation to find what gears you need. If your stock tire size is 265/70/16 (30.6") and your NEW size is 285/75/16 (32.8) the math adds to 4.39 gears. They don't make that gear, they make a 4.30 but the rule of thumb is to go to the next size, which would be 4.56 gears. That will get you close to the stock RPMs for daily driving. I have 4.88's in my truck with 35's and it feels like stock. Now, if you want more power then yes, a supercharger will be best but you're looking at least $3500.
    Also, you do click the overdrive button OFF when you go uphill?
    Demonx13[QUOTED] and ShiftyShank like this.
  3. Oct 24, 2023 at 1:29 PM
    Demonx13
    Demonx13 Member
    Brandon
    2004 toyota tacoma
    Changed the rear output seal of the transmission
    When i purchased the Tacoma the tires were stock size 265/70/16 then i had to get a lift exhaust and bigger tires so ive been using 285/75/16 tires for the last couple years. the gears ive found were 4.56 , 4.88 , 5.2 the guy at the shop said with a automatic transmission and the tires that im running i should do 4.88 also i dont even mess with the overdrive button.
  4. Oct 25, 2023 at 6:53 AM
    2004Taco
    Lou
    California
    4.88's would be good if you're towing, waiting faster acceleration off the line but will kill your top speed and bring your RPM's higher at high speeds. I think 4.56's would be the best all around gears for your setup but just for peace of mind, call Nitro Gear https://nitro-gear.com/ those guys are very helpful and they know exactly what you need.
    Now for the overdrive button, I would try turning off your OD when you're climbing a hill and see if that works before re-gearing. I'm 2wd drive and it cost me about $1000 to regear (parts and labor). If you're 4wd, that will be double.
  5. Oct 25, 2023 at 1:37 PM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    I've read quite a few of these threads and this summarizes what I've learned:
    Common Gear sizes: 4.10 (stock), 4.30 (stock 4runner), 4.56, 4.88, 5.29
    Ideal gearing consensus:
    3.4 Auto on 33's: 4.88
    3.4 Manual on 33's: 4:56
    3.4 Manual on 32's: 4.30 (from my experience, but I was a single cab)
    Go up a size if you wheel regularly or are on 35's
    Hope this helps!
    boostedka likes this.
  6. Oct 25, 2023 at 1:47 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    http://www.grimmjeeper.com/gears.html
    This is the most accurate gear ratio calculator I've found. I used it to regear two different tacomas and the RPMs were pretty spot on what the calculator showed.
