4.88 vs 4.56 gears 2.7L
Discussion in '1st Gen. Tacomas (1995-2004)' started by buettnerc, May 23, 2013.
  1. May 23, 2013 at 11:41 PM
    buettnerc
    buettnerc [OP] Chris
    Christian
    Montana/Washington
    01 tacoma 3 inch lift 33in tires
    3 inch pro comp lift, 33 inch KM2's, voolant cai, mass air flow sensor, bullet throttle body spacer, magnaflow cat back system, full audio system, black ultra racing wheels, headache rack, black uws toolbox
    Ok guys i need help, im looking to regear my truck and i dont know weather to go with 4.56's or 4.88's. I have a 2.7 3rz-fe motor with few engine mods restoring power. i have 33inch tires, and anymore I am driving on the freeway but i go out wheeling as much as possible. which should i go with:confused::confused::confused::confused:
  2. May 23, 2013 at 11:43 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    4:56 if you want it close to stock, 4:88 if you want a little more torque.
  3. May 23, 2013 at 11:44 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    manual or auto?
  4. May 23, 2013 at 11:48 PM
    buettnerc
    Christian
    Montana/Washington
    See ive heard both ways, 4.56 is a stronger gear with fewer teeth and thicker gears. with 4.88's i would be screeming out on the freeway losing mpg right?? its a stick
  5. May 23, 2013 at 11:50 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    this.
    factory gears for a 2.7 automatic are 4.56
    if you are actually looking to regear get the 4.88s
  6. May 23, 2013 at 11:56 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    The differences in strength are so small, it doesn't matter. If you're worried about it, get them cryoed.
    What gears are you running now? If they are 4.30s like I had, they kinda suck for torque. Like PcBuilder said 4.56 is going to be close to stock, and not worth it IMO. I'd get 4.88s and have the power/torque when you want it and just go easy with the skinny pedal when you're trying to improve mpgs
  7. May 24, 2013 at 12:02 AM
    buettnerc
    Christian
    Montana/Washington
    Stock 2.7 3rz manual comes with 4.10 gears I believe... At least thats what i've read. that makes sense to go with the 4.88's but you dont think im going to be redlining driving at 75? this is the first time ive looked into gears so i dont know that much.
    thatprerunner likes this.
  8. May 24, 2013 at 12:06 AM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Depends on several factors IIRC. Check your door code. I have a 2.7L 3RZ manual and I had 4.30 gears stock. Pretty sure 4.10s are in V6s/TRD models.
  9. May 24, 2013 at 12:19 AM
    buettnerc
    Christian
    Montana/Washington
    What are you running in that truck now?
  10. May 24, 2013 at 12:46 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Tons of factors. Just gotta look up the door code.
    Since your a stick. I'd go 4.88s. The 3rz will putt along at 3k rpm on the hwy no problem. And if you are getting into offroading it'll be very nice for that.
  11. May 24, 2013 at 1:09 AM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I'm running 5.29s but I also have 35"s:eek:
  12. May 24, 2013 at 1:25 AM
    Stereodesigner
    Stereodesigner Member
    Lifted yota
    Going by my door sticker my 96 2.7 auto has 4.10s
  13. May 24, 2013 at 1:34 AM
    PcBuilder14
    Brent
    Nor Cal
    Hmm, in my 96 2.7 auto they were 4:10's?
  14. May 24, 2013 at 8:42 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
  15. May 24, 2013 at 2:30 PM
    buettnerc
    Christian
    Montana/Washington
    Another question for ya... should I go with 8 inch or 7.5 4.88s gears
  16. May 24, 2013 at 2:32 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    7.5" is for the front diff. 8.4" is the rear. 8" is TRD e-locker rear.
  17. May 24, 2013 at 3:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You'll e need the 7.5 if your 4wd and if your open out back the 8.4 or if you have the locker the 8"
  18. Jul 11, 2013 at 9:38 PM
    buettnerc
    Christian
    Montana/Washington
    Now that I finally have the money to buy the gears I can only find 1 8.25 ring by midwest. I cant find any other maker on 4 wheel parts that make that size... not to mention they are reversed thread... why would reversed thread matter?
  19. Jul 11, 2013 at 9:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Revers thread is for the drive shaft going the other way.
    And 8.25???
    Only 8" or 8.4" diffs man..or 7.5 front diff which is reverse cut.
  20. Jul 11, 2013 at 9:53 PM
    BamaToy1997
    Bill
    Navarre, FL
    Go to Randy's Ring and Pinion (RingPinion.com) and you will find any of the gears you want for a good price. They are my supplier for gears.
