4.88 vs 5.29 gears?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BeachTaco17, Mar 17, 2022.
  1. Sep 21, 2023 at 6:56 PM
    Carlosky1
    Carlosky1 Well-Known Member
    2018 Wht Tacoma TRD
    Actively modding
    Sounds like you have something else going on. I ran stock gears and 295 tires… (solid 33 inch tire) for a long time…. Power lacked a little but nothing like you’re referring to. I am now geared with 4.88’s and love it… But…. Truck was more than drivable, especially street driving, on any incline, etc…. If you’re revving the engine to 3-4K and then it bogs to 600 rpm and stalls, then you definitely got something else happening. Sorry I can’t help or offer more suggestions without more info from you. Is the truck stock? Meaning tire size? Parking brake off? Dumb question but?
  2. Sep 21, 2023 at 6:57 PM
    Brikan
    Brikan Well-Known Member
    2018 Inferno Tacoma TRD Offroad
    B&M shifter Hood gas strut Injen Intake OSC catch can
    From what I've seen, especially towing, 5.29 is better all around. Best way to figure out if you won't mind 5.29 gearing is just limit your self to 5th gear for a trip and see if the increase in engine RPM will bother you at ~80-90mph.
    5.29 will be most beneficial on the reverse gear since 2nd gear is used for that as well
    But for a stock feel while getting a little bit more torque/power per gear at specific speeds for better drivability, 4.88 will do just fine to increase the general drivability.
    As for the lack of power issue, sounds like you are being light on the throttle, there is no way you stalling out an engine going full bore at 5k from a head stop on a most likely wet boat ramp unless it is unloaded and you are not giving it more throttle while letting the clutch in to keep it at 5k. 3k+ RPM is tire spinning territory from a stop. Or you where holding the brakes a bit too hard while trying to take off and not roll back at the same time.
  3. Feb 22, 2025 at 5:18 AM
    RYount
    RYount Member
    Robert
    2020 toyota tacoma off rd
    Jba control Arms 3.5 vertex front. 3 inch vetex rear total chahos lower control arms. Tack reinforcement tabs. Bison off rd stop cam bolts. 2.75 Daker heavy duty rear leaf springs. Cali raised rock sliders. Hooky roof rack. Off rd lights front and rear on aux beam. 285/75/16 tires. On -25 Rino 16×8 wheels.
    5.29 revolution gears are what you want. 4.88 gears are a thing in the past.
  4. Feb 22, 2025 at 5:49 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    Good thing you chimed in here. OP hasn't logged on in almost 3 years but this is definitely the comment he was waiting on to make his choice.
    yoeltimeisup, TenBeers and auskip07 like this.
  5. Feb 22, 2025 at 7:23 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    The Great TW debate :bananadead:
    IrishRed likes this.
