4.88 vs OVTune?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Plentyogreen, Dec 14, 2019.
  1. Dec 14, 2019 at 9:10 PM
    Plentyogreen
    Plentyogreen [OP] Member
    2017 TRD Pro
    I've read through the mega threads on both topics individually - most guys seem to recommend both together, and are putting lifts/tires and carrying extra weight, or towing. I have a stock 2017 Stock TRD Pro AT with stock tire size @ 265/70r16.
    I'm mostly concerned with commuting performance, drivability, MPG and will only be occasionally towing, skiing at elevation and camping with rooftop tent and associated gear.
    For budget sake I would like to do one or the other for now, I'm leaning towards OVTune for cost.
    Anyone have thoughts, experiences, info, MPG, etc if you had to pick one vs. the other (stock vehicle, mostly commuting, occasional recreation at elevation) - Thanks for the input.
  2. Dec 14, 2019 at 9:18 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Thought - hit the ECT button and save $$$
  3. Dec 14, 2019 at 9:24 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Tune and re-gearing are a completely different ball park than ETC mode, cute thought though.
    I'm doing both. Right now I have OVTune and it helps a lot, still not perfect but definitely adds the ummmf the truck needs but ultimately re-gearing will give it the life the truck deserves.
    Re-gearing is in the very near future for me as I am also about to go up to 285/70/17 tires.
  4. Dec 14, 2019 at 9:51 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I would not regear to 4.88 if you are staying with stock 30” tires size. Too much RPMs on the freeway will destroy your MPGs. At very most 4.56 on stock tires.
    Plentyogreen[OP] and GillyLink like this.
  5. Dec 15, 2019 at 1:25 AM
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    4.88 isnt going to help your mpg or commute performance at all. Its going to shorten your gear range without bigger tires to offset the ratios. Youll be at a much higher rpm cruising at freeway speeds.
    Plentyogreen[OP] likes this.
  6. Dec 15, 2019 at 4:44 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    OVT for sure.
    I cannot comment on MPG change with 4.88 YET. Only because I just had it done Friday and I am trying all the modes of RWD Low only, both lockers etc in gravel and mud and wet etc........hahahaha that kind of driving you just don't look at MPG, but it's around 16 MPG.
  7. Dec 15, 2019 at 5:16 AM
    xxtavixx
    xxtavixx Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    Why not get ovtune and then decide? Its a much less expensive and less invasive decision. Granted, I am a 6mt but it helped a lot.
  8. Dec 15, 2019 at 5:45 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    That's where I was coming from. MT as well. :thumbsup::taco::stirthepot:
  9. Dec 15, 2019 at 7:26 AM
    EchoDeltaSierra
    EchoDeltaSierra Well-Known Member
    Georgetown, TX
    2020 TRD Off-Road
    Nitro 4.88 gears OME suspension ST/Maxx 255/85R16s
    From what I’m seeing running 265/75/16 tires and going to 4.88s is an improvement of about 1.5-2.0 mpg with just gearing. I might do OVTune in the near future, but am really happy with what just gearing provides.
  10. Dec 15, 2019 at 7:31 AM
    xxtavixx
    Jacksonville fl
    2018 6MT
    do a lot of non-interstate driving?
  11. Dec 15, 2019 at 8:02 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    I have 4.88's and the Tune. Did the 4.88's first for towing - made things better. The Tune fixed all the wanky shifting which still existed after TSB's were applied. If I had it to do over I would have added the Tune first and then evaluate. BTW I run stock tire size and it works perfectly - highway rpm is perfect. I use S mode for mountain driving and towing - no issues with the setup.
  12. Dec 15, 2019 at 10:44 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Just drove about 11 miles to Lowe's in 4Hi in rainy wet - 17.5 MPG. Not terrible!
  13. Dec 15, 2019 at 12:02 PM
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    I have OVtune with a MT (4.3 gearing). Seems perfect to me now.
    I think both gearing and tune is necessary for an automatic.
  14. Dec 15, 2019 at 12:19 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    I was the same before. I wish you could drive my truck. I have to say it's perfection, it's smooth. It's 1-2-3-4 like butter with real grunt in 5-6. Designed like this. Matches the powerband like a glove. Well at least with the ADM that delayed clunk is all gone. :bananadance::kona::poking:
    MOC221_ likes this.
  15. Dec 15, 2019 at 12:36 PM
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    In your scenario I would get the tune first and then gear to 5.29. 5.29 is ideal.
  16. Dec 15, 2019 at 2:59 PM
    EchoDeltaSierra
    Georgetown, TX
    2020 TRD Off-Road
    I do a mix of around town and 1-2 longer weekend trips a month.
  17. Dec 15, 2019 at 7:58 PM
    Kamille.bidan
    2017 Blue TRD OR MT
    What do you mean? What did you do to achieve this?
  18. Dec 15, 2019 at 8:03 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    4.88 gears and ADM after OVT
  19. Dec 15, 2019 at 8:06 PM
    Plentyogreen
    2017 TRD Pro
    Pablo8 What is ADM?
  20. Dec 15, 2019 at 8:08 PM
    Kamille.bidan
    2017 Blue TRD OR MT
    Accumulator delete mod = ADM?
    I have a ADM kit, but I haven’t installed it yet.
    OVtune with 4.88 sounds like the ideal setup to me.
    I already bought new rims. Then I want a new shocks. Then I want new tires... when does it end ?
    Gearing sounds great, but I need to stop spending money like rockstar over here
