4 alignments after lift, stil pulls left
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brockin07, Mar 20, 2013.
  1. Mar 20, 2013 at 6:58 AM
    Brockin07
    Brockin07 [OP] Member
    Gadsden, AL
    Red PreRunner TRD Sport
    Air intake, exhaust, OMU 3' lift, sound system, Headlights, grillcraft grills
    Ive got a 08 DB cab, OME 3inch lift, dakar springs in rear, LR UCAs and it stil pulls to the left after every alingment. He showed me the number and they are all in range. What can i do, its driving me nuts?
  2. Mar 20, 2013 at 7:04 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    I have the same issue... Except to the right. I think it's my camber worn m/t. How are your tires?
  3. Mar 20, 2013 at 7:05 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    What size tires?
    Mud terrains and larger tires can magnify small tracks in the road, and increase wondering. Try swapping tires from one side to the other...
  4. Mar 20, 2013 at 7:10 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    What are your numbers? Get a printout
  5. Mar 20, 2013 at 7:12 AM
    medic2230
    Murph
    Bama! Roll Tide
    Take your truck to a place that sells and installs SPC equipment for the alignment. They can get the specs perfect with the UCA's. I wouldn't accept within range if it pulls. They got mine perfect and I've had no issues with the same kit installed.
    Try Tires 1st in Columbus on Miller road.
  6. Mar 20, 2013 at 7:18 AM
    BamaToy1997
    Bill
    Navarre, FL
    Just a simple test, swap the tires left to right. Both left tires to the right, and both right tires to the left. If it pulls right, then you know it is tires. If it still pulls left, then there is an underlying issue. Perhaps when they did the alignment they did not inspect properly, and you may have worn suspension parts. After 4 alignment attempts, something else is wrong.
  7. Mar 20, 2013 at 7:22 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    I would like to see numbers before I jump to that conclusion. SPC LR UCAs have an adjustable upper balljoint. The alignment techs that I have talked to either think they know what they are doing but don't, or are honest and say that they don't feel comfortable that they can get it right.
  8. Mar 20, 2013 at 7:24 AM
    medic2230
    Murph
    Bama! Roll Tide
    I'm wondering if the UCA's are in the center position? Or maybe the shop doing the alignment isn't familiar with SPC's stuff and doesn't know how to adjust them.
    OP did you give the shop the sheet that came with the UCA's? I think if you take somewhere that is familiar with the UCA's you would get a better alignment.
  9. Mar 20, 2013 at 7:28 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Unfortunately there are not a lot of shops that are familiar with them.
  10. Mar 20, 2013 at 7:32 AM
    medic2230
    Murph
    Bama! Roll Tide
    Yeah that's true. There is one here that is though. Prior to mine and with mine. Everyone there said how they wish everyone with a lifted truck would use them after they saw the specs. I talked to the guy that does the alignments there and asked him before hand if he had ever done a truck with them on it, he said yes and they really helped when needed to get everything perfect instead of just within specs.
  11. Mar 20, 2013 at 7:34 AM
    Tripps2012
    Tripps2012 2014 TRD OR
    NC
    2014 TRD OR
    I would have the tires checked at this point you may have a slipped belt in the tire or any number of other issues. You can swap the tire on the front and check this as mentioned above or you can take it to a shop with a road force balancer and have them check them.
    It could still be an alignment issue though. There is a art to setting the caster to ride the crown of the road that most guys doing alignments do not understand. Having all the numbers in spec can still lead to a pull going down the road. The issue may be in the amount of lift you have. When you raise the the truck the amount of adjustment in the caster settings drops with the factory set up. This is where aftermarket upper control arms come into play and allow for that little extra that's needed via the adjustable upper ball joints.
  12. Mar 20, 2013 at 8:41 AM
    white08gt
    white08gt Well-Known Member
    Al
    Tn
    05 dbl cab 4x4 sr5
    toytec lift, fj rims, a.r.e topper
    could be in your rack and pinion steering. if your front tires aren't showing wear, your alignment is good, this is a possibility. in the old power steering sectors, I have seen unequal pressure which causes this. my father in law bought a new truck and his pulled to one side. never could cure the problem from day 1, after over 165k he replaced the wore out sector with one from a junkyard and cured his problem.
  13. Mar 20, 2013 at 8:47 AM
    jandrews
    '09 FourDubDee TRD OR
    Did you level the taco lean?
  14. Mar 20, 2013 at 8:54 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This would be a good starting point
  15. Mar 20, 2013 at 9:00 AM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    lower control arm bushings, i had the same problem.
  16. Mar 20, 2013 at 9:05 AM
    jandrews
  17. Mar 20, 2013 at 9:15 AM
    jandrews
    No questions and all the answers. Amazing innit?
  18. Mar 20, 2013 at 9:18 AM
    Brockin07
    Gadsden, AL
    The truck has only 52k miles on it. the tires and lift are brand new with only about 2000 miles on them. ive had it aligned 4 times in 2 months. The tires are dick cepek 33 on 17s. The truck drove perfect down the road before i lifted it. Yes fixed the taco lean. Swapping the tires to the other side didnt affect this. I will try to get a printout today.
  19. Mar 20, 2013 at 9:22 AM
    Hambone155
    omaha
    have them check cross camber and cross tow, front to rear. if the cross isnt 0.0 you will pull. with bigger tires it will play you more. IMO
    we run into this alot. i sure hope they dont charge you each time! we have a lifetime alignment at my shop. pay once and get it for life unless you replace suspension parts.
  20. Mar 20, 2013 at 9:28 AM
    Brockin07
    Gadsden, AL
    Okay i will get them to check the torque specs on the LCAs, and look at my cam bolts. I bought the lifetime Alignment thank God!
