4 Banger - New PCV Valve Rattle Normal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whiteknight4x4, Jan 27, 2024.
  1. Jan 27, 2024 at 1:32 PM
    whiteknight4x4
    whiteknight4x4 [OP] Well-Known Member
    Drew
    Missouri
    2008 SR5 Reg Cab Taco
    2.5 inch lift: Full Dobinson's suspension kit, Freedom Off-road UCAs, 265/75r16 tires on factory Baja alloy wheels. x2 Baja Designs Squadron Sport Led Pod lights. CBI Moab 2.0 Aluminum Bumper w/full hoops, Warn Evo 8k winch. Ultraguage. Midland CB radio with 3ft Firestick Firefly. Tacomabeast/Spyder Headlights. Rear diff breather. Cruise mod. A.R.E. Topper. Prinsu topper roof rack. Hail damage mod.
    Got a new Pcv valve for my 4cyl since it’s never been changed in 195k miles. (Should have changed it when I did valve cover)
    The new valve rattles is that normal?
  2. Jan 27, 2024 at 1:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You mean it rattles when you shake it?
    If so, yes. That is normal.
    winkel likes this.
  3. Jan 27, 2024 at 2:02 PM
    whiteknight4x4
    Drew
    Missouri
    Yes exactly! Sounds like loose or rattle parts when I hold it and shake it
  4. Jan 27, 2024 at 2:03 PM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can. AMP Powersteps
    Completely normal! Theres a check valve inside of it
    davidstacoma likes this.
  5. Jan 27, 2024 at 2:06 PM
    eon_blue
    Azusa, CA
    Normal, if it doesn't rattle when you shake it that's when you know it's bad
    TartanEagle, whatstcp and Squirt like this.
  6. Jan 27, 2024 at 2:58 PM
    whiteknight4x4
    Drew
    Missouri
    3 witnesses is more than enough for me! Thank you all!
  7. Feb 3, 2024 at 10:14 AM
    whiteknight4x4
    Drew
    Missouri
    Okay was going to replace my pcv today but I read in another thread that there’s an also a grommet that needs to be replaced? I don’t have one of those.
    Can anyone chime in? Don’t want to replace anything till I know I have the correct parts
  8. Feb 3, 2024 at 11:04 AM
    eon_blue
    Azusa, CA
    The grommet gets brittle after age and all the heat cycles, easily falls apart when you go to remove it. On my 3.4l I had bits of it fall into the valve cover that I had to fish out with pliers, but yeah you'll want a new one to put in there.
  9. Feb 3, 2024 at 11:11 AM
    whiteknight4x4
    Drew
    Missouri
    Ah I see. Back to Toyota I go!
    Steves104x4 and davidstacoma like this.
  10. Feb 3, 2024 at 11:21 AM
    whiteknight4x4
    Drew
    Missouri
    Nvm I just checked..it has one built in. Hope I can get the old one out carefully
  11. Feb 3, 2024 at 11:30 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Helpful threads like this one are what makes TW so good.
    :hattip:
  12. Feb 3, 2024 at 12:31 PM
    whiteknight4x4
    Drew
    Missouri
    Update: just replaced PCV Valve. Did not need it (at least visibly and audibly). The old valve and gasket/o ring looked great and still had a healthy rattle. Replaced anyway and now I have a spare. Hose was a little cracked on the ends but still fit tight.
    Pretty good for 16 years old and 195k. I think using only full synthetic 0w-20 has been good to this ol girl.
  13. Feb 3, 2024 at 3:01 PM
    Williston
    Williston Unknown Member
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    If the hose is cracked you should replace that as well when you get a chance. OEM part is only about $10. Is the gasket/grommet a press fit into the valve cover? If it is, I'd replace that too to avoid problems removing it and breaking into pieces as mentioned in the thread earlier.
    Steves104x4 likes this.
  14. Feb 3, 2024 at 4:02 PM
    whiteknight4x4
    Drew
    Missouri
    Uhh I hope there wasn’t a seal inside of the valve cover…. All I noticed was like an o ring type seal above the valve threads, I figured that’s what seals everything up once the valve is screwed in
  15. Feb 3, 2024 at 4:32 PM
    Williston
    Disregard: I thought from the comments mentioning a grommet, that it (PCV) might be pressed-in through one in the valve cover. I think my son's 2005 4-cyl is that way but it has been a long time since I have seen it in his truck. I just replaced mine: the PCV is threaded into the valve cover on my 4.0L
    Apologies for the confusion! :thumbsup:
