4 banger pics
Discussion in '4 Cylinder' started by beastlytaco, Aug 7, 2008.
  1. Jan 17, 2024 at 3:00 PM
    #3641
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    Will do i think the 235 for the 4 banger should be perfect, i will have them on in a few weeks. This is a 265/75 10.4''W next to a 235/85 9.3''W rolling resistance difference should be felt. I am not sure i know what 225 tire would come in that size. I know ive seen 215/85/16 which is basically factory height tire just thinner at 8.5''. I have a slight lift .65'' front and stage 2 icon pack in the rear so i like the slightly taller tire. The truck does not struggle with the 265 especially after regearing but it could be better i think the 235 will be the ticket, that and OTT has some new changes to the 2.7 tune which i hope can see some decent gains. The tune is already a big step in the right direction as is but some good things in the works.
  2. Jan 17, 2024 at 3:44 PM
    #3642
    barch88
    barch88 Well-Known Member
    Michigan, USA
    2022 Tacoma SR utility package
    Thanks for posting. I was about to pull the trigger until I thought of gearing problems. 265/75/16 is a big speedometer difference but not as bad as 255/85/16 on my truck, compared to stock. Should I just get 245/75/16 and stick with stock size, or would 265/75/16 work okay with not much difference in gearing?
    I’m kind of set on BFG K02’s, they are a little lighter in the 245/75/16 but still load E. I just really like the look of them and my dad swears by them. He’s gotten 70k from his last set and is going on 50k on his current set on his f150
  3. Jan 17, 2024 at 3:46 PM
    #3643
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I miss my 05 5peed extended!!!!:pout:
  4. Jan 17, 2024 at 7:47 PM
    #3644
    Nyrob
    Robert
    2021 SX 2.7 AT 4WD
    A 265/75/16 is not a big speedo difference only off 1-3 at 70-80 and it doesnt help the already bad out of the box gearing on these trucks, in my opinion i think its a little too wide of a tire for a stock auto 2.7 the 5 speed as stated you could get away with 32's no problem. Great tire but it’s heavy for the size a lot of other good options the bfg’s likely look the best but I’d rather better driveability. They weigh 48lbs my bigger 265/75/16 cooper at3 4s are only 41. Cooper in the same 245 size is only 35lbs you will feel 12lbs extra per wheel. I would either go with a 235/85/16 firestone destination xt which is taller but thinner than the stock tire and same height as a 265 that is 40lbs, or a lighter weight 245/75/16 AT 35-40lbs. The stock size tires in a ATs will make the truck drive the best but you can get away with the 235 for a better looking taller tire and thats a tough E rated tire as well.
    barch88[QUOTED] likes this.
  5. Jan 30, 2024 at 10:05 AM
    #3645
    Tester58
    Tester58 New Member
    TN
    2011 Reg Cab 2.7 4X4
    2022 TRDOR Suspension. FN wheels w/ 265/70-17.
    Just completed work on my Timberland Mica 2011 with 135Kmiles. Frame paint, large part list including 2022 TRDOR suspension and FN wheels with 265/70-17s.IMG_2157.jpg
  6. Jan 30, 2024 at 10:16 AM
    #3646
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    Welcome to TW!
  7. Jan 30, 2024 at 10:28 AM
    #3647
    Tester58
    Tester58 New Member
    TN
    Thanks! Have been a consumer of TW information for a few years now. Great site.
    Steves104x4 and Bikinaz like this.
  8. Feb 2, 2024 at 5:45 PM
    #3648
    LunaRover
    LunaRover Well-Known Member
    Tim
    2023 LR DCLB AT V6 TRD OR, 2011 WHT RCLB AT 2.7 BASE
    ARE MX Cap, Bed Rug
    Here is my 2011 Base, still going strong. Love my new 2023, but I still enjoy driving the older Taco. IMG_0968.jpg
  9. Feb 2, 2024 at 7:17 PM
    #3649
    Nyrob
    Robert
    2021 SX 2.7 AT 4WD
    Picked up my new cap today and the 235's in the short distance it drives great, very soft ride for an E rated tire and there is a noticeable difference in rolling resistance id say 45 mph+ im less into the pedal you can feel the engine is under less load highway driving way more pleasant. It feels fine on the highway maybe a little more twitchy but after a few miles youd adjust. Corners just fine i, slightly worse than the wider 265. Its funny how much of a difference is felt especially since i switched wheels back to my sr's which are 6lbs heavier a wheel. So the new tires are 1lb less than my previous cooper 265/75/16 at3 4's but my per corner is about 5lbs heavier than before. Goes to show a few lbs of wheel weight is not a big deal, heck look at stock sr's with steelies which i think weigh around 32lbs that a big hike up from the my stockers 23.5lb. I believe this size is the way to go for the 2.7 who wants a slightly bigger tire without totally killing the drive ability. They look good but since they are skinny with the factory sr offset it sticks in the fender too much for my taste. Im going to be putting on 1.25 spacers that will make it just right, If i didint have fender flares i think i could get away without spacers. Also included a picture of the new tires with my old 265/75/16 coopers.
    monoman, Tester58, TT005 and 3 others like this.
  10. Feb 3, 2024 at 4:33 AM
    #3650
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Great information! Appreciate you taking the time to write it.
    I was thinking more about rolling resistance decrease and traction gains than about any weight changes. Glad the weight wan't my focus I guess.
    Also, lucky for me, I don't have flares, so no spacers needed.
    Thanks again and keep posting observations as you experience them.
  11. Feb 4, 2024 at 8:49 AM
    #3651
    GatorBodine
    GatorBodine Well-Known Member
    Jay
    23' 4 cyl.
    Beautiful truck
  12. Feb 4, 2024 at 8:54 AM
    #3652
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    IMG_3350.jpg. Well, slapped these things on it.
  13. Feb 4, 2024 at 9:23 AM
    #3653
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    2017 SR Utility 5 speed MT, 4 cylinder.
    My dream truck
  14. Feb 6, 2024 at 11:09 AM
    #3654
    barch88
    Michigan, USA
    Here's my 2022 SR 2wd 4-banger. Basic as it comes and I love it. Plan to have this truck forever
    JHP, GTBCKUP, GatorBodine and 3 others like this.
  15. Apr 15, 2024 at 11:00 PM
    #3655
    GTBCKUP
    GTBCKUP Active Member
    Maine, USA
    2023 Tacoma Access SR5 2.7L 4Cyl 4x2
    Here is my 2023 SR5 2WD 4-Banger. I love everything about it!
    JHP, GatorBodine, 09 Redneck and 2 others like this.
  16. Apr 23, 2024 at 10:06 AM
    #3656
    Bradcfi
    Bradcfi Active Member
    Bradley
    Denver
    2024 Tacoma Trailhunter
    2012 2.7L PreRunner URD Supercharger.
    I've had it since 2013 and put the URD SC in it last year.
    Baseline dyno numbers: 128 rwhp, 152 rwtq
    Final numbers: 240 rwhp, 250 rwtq
  17. Apr 26, 2024 at 9:30 AM
    #3657
    Bradcfi
    Bradley
    Denver
    Now for some new wheels. I'm thinking bronze and the brighter rather than the dark bronze. Any suggestions?
  18. Apr 27, 2024 at 9:14 AM
    #3658
    mjs90
    mjs90 Well-Known Member
    Los Angeles
    ‘18 2.7 AC 4x4
    SCS Ray 10’s in copper if you can find them.
    I have the bronze NV305’s from Method and they’re pretty shiny when clean, but the copper Ray 10’s are gorgeous
  19. Apr 27, 2024 at 4:36 PM
    #3659
    Bradcfi
    Bradley
    Denver
    Those both are at the top of my list! Thanks.
  20. May 15, 2024 at 7:42 AM
    #3660
    fishitaco
    fishitaco Member
    jim
    2001 5 speed 3RZ
    stock
