4 banger prerunner -ok for a 16-21 ft boat?
Discussion in '4 Cylinder' started by pdrunk, Mar 23, 2012.
  1. Mar 23, 2012 at 2:16 PM
    pdrunk
    pdrunk [OP] Well-Known Member
    2012 DCSB 2.7L
    I've got a 4 cylinder dcsb prerunner.
    My question is: Am I ok pulling a 15-21 foot boat? From reading on here I am not so worried about towing as I am about the lack of 4wd when putting it in and pulling it out of the boat launch.
    I have fears of my 2wd slipping into the water....
  2. Mar 23, 2012 at 2:17 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    ehhhhhhh i need to put my 4 banger in 4wd to get out.
    do you have a rear locker? how steep is the boat ramp? is the ramp mossy from dirty water or is the water clean?
  3. Mar 23, 2012 at 2:47 PM
    pdrunk
    2012 DCSB 2.7L
    I'm not too sure about the different ramps and whatnot. My buddy used to pull the same boat with a 2wd chevy, and he tells me I can do it just fine. Tells me to go back far enough and use the trailer's winch to pull the boat onto the trailer. I'm just afraid of slipping on algae covered launches, though it seems that the launches i plan on hitting aren't that steep.
  4. Mar 23, 2012 at 3:51 PM
    tlh178
    tlh178 Well-Known Member
    terry
    lake huron/sag bay
    2012 4WD reg cab/ 02 SR5 Prerunner/07 FJC 4WD
    like 97yota said, if you have locker you should be fine. i used my 02 2wd all the time to launch. it has a 6 banger, but the 4 should be fine. most of the launches on lake huron are pretty steep. i never even thought about not getting out, but the 02 had a locker. if i think of it, only used locker a few times. you get that algae slick and you need that little extra traction. been using my fjc the last 5 yrs and that walks it out even with snow.
  5. Mar 23, 2012 at 4:06 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    You never mentioned the weight of boat and trailer. If the combo is under the gcwr, go ahead.
  6. Mar 23, 2012 at 4:09 PM
    97yota4wd
    Eric
    Mesa, AZ
    is your truck manual or auto? that makes a difference too, auto you can creep back up the ramp slowly so the tires dont spin, a manual you cant do that.... so its super easy to spin in a maunal. tried it with a 18ft pontoon boat. total with boat and trailer are about 2300lbs in my manual 4 banger in 2wd (no locker) and i had to get out and lock my hubs to even move.
  7. Mar 23, 2012 at 4:18 PM
    pdrunk
    2012 DCSB 2.7L
    Auto. I'm pretty sure I'm ok, but I guess a 4x4 is always better, just in case.
    Again, my friends 2wd chevy was fine. Bigger engine, but I'm thinking displacement isn't as big a factor during the actual launch...
    Edit: i haven't looked at gross weight; I'm still just toying with the idea.
  8. Mar 23, 2012 at 4:23 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    :confused:
  9. Mar 23, 2012 at 4:31 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    x2 You never want to lock the rear when going up a boat ramp especially if there is algae, mud, grime, etc on the ramp because if both tire lose traction the you're going in the water whereas with it open only one tire loses and you still have the ability to stop the truck.
    With good clutch control it's just as easy to "creep back up the ramp". Sounds to me like you need to spend a little time on an empty hill working on your clutching.
  10. Mar 24, 2012 at 5:24 PM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    depends if the boat is 15ft long or 21 foot long and if its aluminum or a bay boat....i tow around my 16 foot xpress with a 50 yamaha on the back and its like i dont even have anything behind me and as for getting out of the boat ramp...no struggles but i have 33in mud grips
  11. Mar 24, 2012 at 6:02 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Tow rating on the 4 banger is what... 3500 pounds?
  12. Mar 24, 2012 at 9:12 PM
    pdrunk
    2012 DCSB 2.7L
    3500 iirc.
    Sorry for the lack of info amd exact numbers, but I'm still just toying with the idea right now. I don't know much about boats either.
    Would love to stock my freezer for a few months, not to mention just the sport and therapeutic aspects of fishing.
  13. Mar 24, 2012 at 9:23 PM
    Warhorseforever
    Will
    Sand Lapper
    IMO you should be fine because I towed this 17ft Key West 1720 Sportsman with a 90hp Yamaha 2-stroke on the back
    with this 2.2L inline 4 cylinder open rear diffs and street tires
    for 3 years without a problem. You just have to be mindful of what it is that you are backing up on.
    Edit: When the boat is setup for a day of fishing it weighs around 1500#'s.
  14. Mar 24, 2012 at 9:30 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
  15. Mar 24, 2012 at 9:39 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    to this day that video confuses me. how does someone fail so hard. it is a freakin wave runner! there is no need to have the trailer fully submerged. and why he just kept flooring it is beyond me.
    op: depending on how much the boat weighs, i think you will probably be fine as long as you creep up and down and dont gas it. IMO, if the boat is over about 2200lbs that would be pushing it with such a light rear end, and needing 4wd
  16. Mar 24, 2012 at 9:39 PM
    JDMcQ
    I have no idea, I just thought it appropriate here.
  17. Mar 24, 2012 at 9:41 PM
    JDMcQ
    Don't forget the deckplate mod.
  18. Mar 24, 2012 at 9:43 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
  19. Mar 24, 2012 at 9:44 PM
    JDMcQ
    Well of course.
  20. Mar 24, 2012 at 9:48 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    My buddy lives on Huntington Harbor.
    Ever since Jr. High, we've always enjoyed going to the launch on weekends to watch the "Boatnicks"
    That video is not the worst we've seen.
